Does the Venturer CD-1282 boombox have a repeat all function for the CD player?
3 Suggested Answers
fairlane
  • 50 Answers
SOURCE: Boombox CD player
Hi Could be bad spin motor, but the first thing to try is load the cd and put your ear to the unit and listen for a ticking sound...if there is, then the laser is trying to focus. If not ticking, there is likely a serious problem, and the whole unit should be replaced. If you hear the lense bouncing up and down, then it is likely a dirty lense or bad laser. To clean it, use a cotton swab and wet the end with at least 70% USP rubbing alchohol(99% better). Touch the swab to the lense and a drop should form on the lense, gently move the drop around to loosen any debris, and then use a dry swab and touch it to the lense to absorb the drop. Try the unit, and if it was dirt on the lense, it should work, if not the boombox should probably be replaced. Good Luck!
Posted on Sep 27, 2007
simplemitch
  • 752 Answers
SOURCE: CD player on boombox
The laser is dead or damaged. Try swabbing the laser with rubbing alcohol on a Q-Tip, then IMMEDIATELY blowing dry with canned air. If this fails, the laser is dead. If it is a Sony KSS-2xx series laser (try to peek in the laser slot to see the decal on it) you can get replacements online. If not, it's junk.
Posted on Aug 04, 2008
Cd player only shows
You will need to check the swith that change from Tape to CD to other functions. If the switch is good. Then the next thing is to check for tape function. Can you try to fast forward, reverse. If these functions are working properly then the pinch roller ( the little wheel that is pulling the tape need to be replaced). If nothing moves then you need to replace the belt and the wheel and possible the motor at the same time
Nov 17, 2011 | Lenoxx Electronics CD-102 Cassette/CD...
I can't get any volume from the boombox. It's like the volume is muted for all functions. Any suggestions?
Please make sure that you have selected the correct function.Press the Function/Standby button to select Radio,Tape or CD mode in the boombox.Press the volume +/- buttons to increase or decrease the volume on your RCA RCD135 Cassette/CD Boombox. Also check the display and make sure that the volume level is adjusting when pressing the buttons.
Hope you are satisfied with my solution.Thanks for choosing Fixya.
Jul 03, 2011 | RCA RCD135 Cassette/CD Boombox
I have a model CD510G boom box that will only repeat the last song, using the repeat button. Is there a way to make it repeat the whole CD over and over?
Most CD players have a repeat function for a single track or for the entire CD. If you press the button once, it should repeat the whole CD, if you press it twice, it should repeat the specific track.
May 13, 2011 | Jensen CD-500 CD Boombox
How do you start a tape to play ok..i turn on...put in a tape....now, how do i get it to play
Look for a symbol that looks like this >I. or just this>, and push. Make sure you have selected "tape" function
Apr 10, 2010 | Sony Boom Box With CD Player & Cassette...
How do i get one song to repeat continually?
If the CD player has programablilty set it to repeat the current song. If yours won't repeat then you're SOL.
Nov 25, 2009 | Sony CFD-E55 Boombox
Insignia NS B2110 boombox CD not playing
Try an audio CD which has been purchased. I think you have MP3's on your cd and your boombox maybe does not support MP3
Mar 07, 2008 | Insignia Sport lDM9700-2 Personal CD...
The antenna is broken at the base eye, and repeated attempts to re-attach the eye have failed.  How can I purchase a replacement antenna?
It's possible to get the same antenna on ebay...
You can check here:
http://item.express.ebay.com/Consumer-Electronics_MP3-Players-Portable-Audio_Boomboxes_Boombox-Radio-Replacement-Antenna-12-Inches-Boom-Box_W0QQitemZ120194279381QQihZ002QQptdnZBoomboxesQQddnZConsumerQ20ElectronicsQQadnZMP3Q20PlayersQ20Q26Q20PortableQ20AudioQQptdiZ493QQddiZ945QQadiZ500QQcmdZExpressItem
or here
http://item.express.ebay.com/Consumer-Electronics_MP3-Players-Portable-Audio_Boomboxes_Boombox-Radio-Replacement-Antenna-12-Inch-Sony-RCA-Coby_W0QQitemZ120194280040QQihZ002QQptdnZBoomboxesQQddnZConsumerQ20ElectronicsQQadnZMP3Q20PlayersQ20Q26Q20PortableQ20AudioQQptdiZ493QQddiZ945QQadiZ500QQcmdZExpressItem
Dec 02, 2007 | Jwin (JX-CD512D) Sports Portable CD Player...
How do i get the track to repeat without a remote control
on your boombox it should have a repeat button when you click it there will be an arrow showing on the screen.
Jun 14, 2007 | Panasonic RX-ES20 Cassette/CD Boombox
CD player not working
Insert Lens cleaning Disk, after cleaning the disk If the CD is reading change the lens.
Nov 10, 2006 | GPX C984 Boombox
165 people viewed this question
 Grubhead
Grubhead
