Question about Medical
What is HiMEM Error in Cardioline delta 1 plus and how can i fix it?
2 Suggested Answers
SOURCE: my Cardioline Delta 1 Plus EKG Machine is reading
First of all, the Cardioline Delta 1 if defective would require shipment to Italy for repair, parts and technical information is at a premium this sid eof the atlantic on that particular model. In this case you might be able to resolve your problem by clearing your directory. Acording to Cardioline technical support, that *may* refer to a directory full situation. If you have a copy of your operators manual, refer to it regarding clearing your patient directory and deletion of all the patient data files. Note that doing so will permanently destroy any saved patient data, so print out anything that is important first. I cannot personally vouch for the accuracy of this information, as we have not sold a Delta 1 in many years, and ill admit to being rusty. In fact the tech support engineer was also unfamiliar with your error message, so this amounts to a *very slightly* educated guess. I hope it helps.
Posted on Dec 05, 2011
My Cardioline Delta 1 Plus EKG Machine is reading message " himem error" what does that mean?
Nov 03, 2011 | Schiller Welch Allyn Cardiovit At 2...
I NEED A NEW FLOOR PLATE
I checked with multiple suppliers and Delta website There must be a problem with the pricing the bench base is over $800.00 and the floor base is over $900.00
Here is a link to delta's parts.
Two suggestions
1 I would call delta at 1-800-223-7278 and see if they have an error in their parts book
2 If your base is just broken I would find a local welding shop and have it fixed
Thanks for using Fixya.
Please remember to vote for any solution that helps you out.
Dennis
Jul 01, 2011 | Delta 15 331 15" 115/230V Variable Speed...
When I try to charge the battery in my Cardioline delta 1 Plus machine, it says "supply failure" and it also will not run on outlet power.
hi,
You have to check the power supply of you machine. Normally it will be a SMPS (Switch Mode Power Supply). If the SMPS is faulty then the machine will not work on outlet power and also will not charge the battery. That's why it displays supply failure. Check the SMPS if available then replace the same. For repairing the same can only done by an experience person in electronics. Because there are high voltage areas in the SMPS. So if you need to repair the same consult some one who is experienced in it.
ok
Apr 26, 2011 | Medical
Is there any way to fix the Delta Martinique 5-in-1 Crib so the side can no longer drop down or do I need to get rid of the crib all together?
Delta will send you the repair kit to fix a crib that was recalled. Click this link to go to the Delta Recall website, and enter the model number to start the process:
http://www.cribrecallcenter.com/step2.asp?recall=2&co=1
If you have any trouble with the online entry form, you can email them directly at:
questions@DeltaEnterprise.com
Jan 27, 2011 | Delta Martinique 5-in-1 Crib
The table on my ti 84 has the X's counting be .5. how do i set it to count by 1
Press 2ND [TBLSET] and change the delta-Tbl to 1. "delta" is an up-pointing triangle.
Nov 12, 2010 | Texas Instruments TI-84 Plus Calculator
WhAT IS AN Ma error
It is an abbreviation for mathematical (calculation ) error:
You did not actually ask about how to cure the problem, but here it is.
1.Calculation exceeds calculation range.
2.Calculation outside the input range of a function
3. Illogical operation (division by 0)
4. Poor precision is Sigma calculations (stats)
For all the above check input values.
5. Poor precision in differential calculation results (derivatives:decrease the delta, the step)
6. Poor precision in integral calculation results ( integrals: Change the tolerance tol)
7.Cannot find results in equation calculations (Check coefficients of equations
Take your pick of the above:Only you know what you were doing before the error condition arose.
Hope it helps satisfy your curiosity.
Oct 19, 2009 | Casio CFX-9850G Plus Calculator
ThinkPad A21m won't boot into Windows
Did the laptop you got come at least with a windows XP cd? If so boot the laptop off of that and try to install Windows XP and see if it goes thru. Just make sure during the installation you tell it to delete the partitions first and then let it go thru that way you know for sure the hard drive is clean at that point.
Feb 02, 2009 | IBM ThinkPad A21m 2628 Notebook
Missing or corrupted file C:\windows\himem.sys
If you are running Windows 95, Windows 98, type:
copy himem.sys c:\windows <press enter>
If when typing any of the above commands you receive a prompt that the file already exists, ensure to overwrite it.
Reboot the computer; if the issue continues to occur, verify that the config.sys is properly setup. The line himem.sys should read:
DEVICE=C:\Windows\HIMEM.SYS
or
DEVICE=C:\DOS\HIMEM.SYS
Additional information and examples of the config.sys can be found on our autoexec.bat / config.sys page.
Dec 27, 2008 | Compaq Presario Notebook
Error - Kernel32.dll
Microsoft defines Kernel32 errors as follows: "The Kernel32.dll file is a 32-bit dynamic link library file that is found in Windows 95, Windows 98, or Windows Millenium Edition (Me). The Kernel32.dll file handles memory management, input/output operations, and interrupts. When you start Windows, Kernel32.dll is loaded into a protected memory space so that other programs do not take over that memory space. On occasion, you may receive an invalid page fault (IPF) error message. This error message occurs when a program tries to access the Kernel32.dll protected memory space. Occasionally, the error message is caused by one particular program, and other times the error message is provoked by multiple files and programs."
Sep 21, 2005 | Polaroid PhotoMax MP3 Digital Camera
Medical Logo
493 people viewed this question
Top Medical Experts
Electro Med Services...
Rhonda Webster
Rhonda Webster
Are you a Medical Expert? Answer questions, earn points and help others
