Question about Dell Dimension 4600 PC Desktop
I want to install a aSATA HARD DRIVE IN MY 4600, IT SHOWS IT HAS ATA CAPABILITY BUT WHERE DO i PLUG IN THE DRIVE
  • 744 Answers
As I recall the 4600 uses EIDE hard drives so you won't have SATA plugs. You may be able to get an adapter but it would be easier to install another PATA drive that will fit natively.
Posted on Feb 08, 2010
I have placed this hdd into an external case to use as a portable drive but when i plug it in to my laptop (mac book pro) it starts to beep. Windows is installed on the portable drive i was hoping to plug...
at ATA hard drive there is no master or slave, if you want to make it master connect it at ATA slot 1 at mother board, and if you want to make slave connect it at ATA 2 at motherboard
i hope this helpfull
Jan 19, 2011 | Seagate MOMENTUS 5400.2 - HARD DRIVE -...
Can i install a philips dvd8801 in my dell dimension 4600? if so, what do i need to download and/or install for it to function?
Yes, you can install it. The drive is a standard size and will fit the drive bay in your Dell. You'll just need to set the master/slave jumper to whichever your new drive will be. If you're just replacing the optical drive, or it's connected to the first plug on the data cable from the motherboard, set the jumper to master (MA). If you're installing this as a slave, connected to the middle plug on the data cable, set the jumper to slave (SL).This drive comes standard in some Dell systems and they have this user's guide which shows the connections.
You don't need anything for Windows to be able to use the drive. It's seen as a standard drive type and Windows will work with it straight away. But you'll need some kind of burning software to make CDs or DVDs. Windows does have built-in burning capability but it's pretty limited. A good free disc burning application is CDBurnerXP. There are commercial programs like Nero as well. If you want to make DVDs that you intend to play in a regular DVD player, or want to make DVDs with menus and other features like the commercial releases, you need DVD authoring software. The commercial programs with all the bells and whistles are pretty costly. DVDStyler is a free program that offers a lot of functions.
Have fun, and thanks for using Fixya!
Jan 14, 2011 | Dell Dimension 4600 PC Desktop
Xp installation problem
“No Hard Disk” error displayed on XP install (SATA drive versus ATA/IDE drive) The two most most popular types of hard drives in personal computers are ATA (also known as IDE hard drive) and SATA hard drives. Many newer computers have SATA hard drives installed, but your computer may have either an (older design) ATA/IDE hard drive or a (newer design) SATA hard drive installed.
After removing Vista, when you reboot your computer, a “No Hard Disk” error may be displayed if your computer has a SATA drive installed. To fix the “No Hard Disk” error, you may need configure your computer’s BIOS settings so that it can recognize the SATA drive installed in you computer. Reconfiguring your BIOS is typically not required if your computer has an ATA/IDE hard drives installed.
Step 1: Activate your computer’s BIOS menu. The first or second screen your computer displays on status may display which key (or keys) you must press to activate your computer’s BIOS menu. You can also look in the index of your computer’s manual for “BIOS” or you can try passing the [Del] or [F1] key when text is first displayed after powering on your computer.
Step 2: BIOS menus vary by computer, but there are seldom more than a few menu categories. Review the “Main” and “Advanced” menu categories to locate your hard drive setting. When you locate the hard drive setting, be sure to note the original drive setting in the bios so that you can restore the original drive setting if your new configuration doesn’t work.
Step 3: Change the drive setting to “IDE,” then save the BIOS settings (usually by pressing the [F10] function key then restart your computer.
If changing your BIOS hard drive setting to IDE doesn’t work, return to step one and restore the original hard drive setting
If it is ok , Please vote for me...!!!!
May 31, 2010 | Computers & Internet
Hard disk ST9120822AS ATA Device
If the computer cannot Bootup with an error message that hard drive nor detected or no boot device then you could have a faulty hard disk.
Go into the BIOS configuration and see if the BIOS detects the hard disk. If it is not detected then it is probably faulty.
Next reset the ATA data cable on the hard drive and at the motherboard. Bootup the computer again, also check the BIOS configuration again to see if it detects the hard drive.
If it still does not find the hard drive then remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer does not detect it as an external hard drive then this proves the hard drive is faulty.
To get your computer working again, replace the hard drive and install Windows together with the device drivers and your programs.
Nov 06, 2009 | Dell InspironTM 1501 Notebook
Hard Drive, 80GB, I, 8M, 7.2K Serial ATA, Maxtor-Calypso I want to upgrade and I can't find specs on my hd. can you help me find them?
http://episteme.arstechnica.com/eve/forums/a/tpc/f/24609792/m/219000534831
cut and paste this link and you will find some usefull information.
Sep 26, 2009 | Dell Dimension 4600 PC Desktop
I am trying to install a Maxtor Basics 500GB External Desktop Hard Drive and cannot see the drive on my PC. I'm assuming it is not installed. I operate a Windowss XP Platform. Help!
Right click on my computer and go to manage, then go to storage, disk manager and see if the disk shows up there, you may need to partition it first, you can make one partition of that hard drive. If it is not in there, check the jumpers and make sure it is not the same as the main HD. The main drive should be master and the second drive should be slave, or make it cable select and do it in the bios.
Jun 21, 2009 | Maxtor MaXLine Pro 500 500GB 7200rpm...
IDENTIFYING THE HDD
No this will most likely not recognize the drive to it's fullest capability. It might not recognize it at all or be compatible with it.
Mar 03, 2009 | Seagate 160GB STM301603N1AAA 7200RPM 16MB...
Is this hard drive sata or ide
It is SATA - Serial ATA (DELL Dimension 4700)
Jan 17, 2009 | Dell Dimension 4700 PC Desktop
Slave drive into Dell Dimension 5100
Yes it does. It may not have an IDE cable if using SATA hard drive, but it does have a port on the motherboard to plug in the cable you take from your 4600.
Don't forget to rate your answers please!
Jun 07, 2008 | Dell Dimension 4600 PC Desktop
Help regarding laptop harddisk
the motherboard for that unit MAY NOT have SATA capability. check for that at the acer site.
Mar 08, 2008 | Acomdata HybridDrive E5 Hard Drive
Dell Dimension 4600 PC Desktop Logo
105 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
