Question about Hilti 285359 SF 121-A 2.0 NICD Cordless Drill/Driver
Smoked when you puting a batery - Hilti 285359 SF 121-A 2.0 NICD Cordless Drill/Driver
Smoked when you put the batery
Posted on Feb 08, 2010
Connected batery wrong post On my tractor.smoke came out . I am not getting power on ignition to turn motor.
When you get smoke coming out you have severely over heated the wires an need to replace the as they are melted together or burned completely off
Jan 25, 2016 | Garden
My car suddenly started showing the check sign and then bring out black smoke from the exhaust. It also hesitates in acceleration
It will have to be scran, To find out what codes come up, All so if it is puting out black smoke end hesttates, It should not be driven to far, It should be taken in to be check out As soon as (Possible) Before damage is done to the motor,
Nov 08, 2012 | 2004 Lexus RX 330
1998 xr80 smoking after puting freash gas in
Did you put in 2-cycle mixed gas? If putting gas in it was the last thing you did before it started smoking then I would start there. Oil causes smoke and there's only 2 ways oil can get into the cylinder; mixed with gas or bypassing the piston rings. Lets hope its the gas.
Jun 09, 2012 | Cars & Trucks
My laptop was shut down, then when I was start it again it doesnt work anymore...What should I do?..please help me, aside from this those keyboards does not functioning correctly in their corresponding...
First thing you do to power your laptop on again try removing the battery and the charger complitly leave it for 10 sec without power then press the on off switch for 2 or 3 times without puting the power or batery later try not to put the battery and put only the power adapter and start your laptop dose it starts if yes good shut it down and put the batery in and start the laptop if its starting and leave it running for cuppul of hours and then again remove the power adapter and let it run the system with batery power if it stays on and fine you are ok and fine there was just a power dump but if it fails in any case like fails to boot with power adapter and so you have adapter issue need to be checked if dosent work with batery it self its a batery issue and needs replacement .
regarding the keyboard issue you can open the kay board and clean it with contact spray if posible.
Dec 12, 2010 | LG NB E500-JAP51A Notebook
Single Loud Beeps every 15 to 20 minutes followed by a sentencein French?
hello, your batteries may be to low, this happens to warn you that you need to change the batery normally thats what this will mean unless the unit is fualty, get a fresh set of batterys and see if that helps.. if not get a new detector, good luck hope this helps..
Jun 05, 2010 | Kidde DC Voice-Alert CO and Smoke Alarm
Barttery light is on, when starting to drive not gettig power to move then car dies
the batery or more likly the alternator isent puting out a charge
Jun 04, 2010 | 1995 Saturn Sl
It was running fine then just started to smoke out the exhaust making a fog behind you didn't know where to start before ai tear it down puting new piston and rings it is low milage 7100 miles have qany...
I would do a compression test first and determine if there is an adequate seal.. if the smoke blue than that could indicate blow by.. also did it loose power when this happened ??... take a look @ the plug for oil indicating incomplete combustion.
Dec 08, 2009 | 1991 Suzuki DR 350 S
Replaced battery, test button will not work
hello make sure that the cover is on properly or the button will not reach the inside contac also make sure you have a fully charged batery sometimes sitting in the store so long they go dead or they are old stock with very little charge left.
if all else fails replace the unit better safe than sorry.
good luck
Nov 29, 2008 | First Alert SA302 Dual System Smoke...
Hilti 285359 SF 121-A 2.0 NICD Cordless Drill/Driver Logo
76 people viewed this question
Top Hilti Drills Experts
woodzowl307
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
