Question about Brady TLS2200 Thermal Label Printer
Brady TLS2200 printer - error invalid label
Error invalid label
    Problem Solver:
  • 14 Answers
It could either be a faulty smart cell on th elabel cartridge or the smart cell reader on the printer. Confirm by using different types of label rolls. If same problem repeats, the smart cell reader will have to be replaced by a qualified serice personnel.
Posted on Aug 14, 2010
Brady TLS2200. I turn it on and get a error CHKSUM
Once again, first thing in a GOOGLE search!
Brady TLS2200 manual
https://www.cableorganizer.com/images/brady/tls2200/manual.pdf
Page 77 error messages
Error in Checksum
The software was improperly installed on your printer. (or lost or corrupted in the memory.)
Contact Brady Technical support group.
Aug 03, 2016 | Brady TLS 2200 Label Printer
Looking for a part number for the internal battery
Hope this helps this should be the part# for battery pack for you label maker P# TLS2200-BP
Jun 10, 2014 | Brady TLS 2200 Label Printer
Brady TLS2200 won't feed labels. no errors.
Turn off the printer and open the printer back door. Use a spot light and look inside properly. Make sure there no paper. Some times a small piece of paper creates the problem. Then after open the back door, top side turn the printer upside down . So if anything is inside it will come out.
After cleaning again connect it with PC and turn on. Now give a look. If you face same problem then Un-install the printer driver and software from the PC. Then restart the PC and Printer both. Now connect the Printer with PC via USB and install again the driver & software (Check if there are any new drivers on the website) .
Feb 25, 2014 | Brady TLS2200 Thermal Label Printer
Unable to print labels
Turn off the printer and open the printer back door. Use a spot light and give look inside properly. Make sure there no paper. Some time small part of the paper creates the problem. So you can do one thing after open the back door, top side etc make the printer upside down etc. So if anything inside that's will come out. After cleaning again connect it with PC and turn on. Now give a look. If you face same problem then Un-install the printer driver and software from the PC. Then restart the PC and Printer both. Now connect the Printer with PC via USB and install again the driver & software. Then try to print and let me know the result.
Aug 09, 2012 | Brady TLS2200 Thermal Label Printer
Low Battery
Your battery may be losing it's ability to hold the charge or your charger may be fully replacing the charge in the battery. Personally, I suspect the battery.
Don
Jan 13, 2010 | Brady TLS2200 Thermal Label Printer
Error message: codesum: C47B72 memory error
Your printer firmware got corrupted or if yu tried to upgrade, it did not complete successfully. Most probably you will have to do a firmware install
Jan 06, 2010 | Brady TLS 2200 Label Printer
Errors
I believe this is a checksum error. Most likely the CMOS Button Cell Battery is dead and CMOS
memory is now corrupt !.
Replace the CMOS Battery if less then 3.6V. It is located under the Main Battery.
Then reload the latest software !
Hope this solves your problem
Regards
AZSUNS
Nov 09, 2008 | Brady TLS 2200 Label Printer
Brady tls2200 label printer
Go to setup mode
(Func + Setup Keys Together)
"Printer" is first line of text, Press Enter
Scroll down 4 times using Down Arrow
"Burn Temp" is selected, Press Enter
"Burn Temp is 0?" Using the Up/Down Arrow you can increase/decrease the burn Temperature. +2 or 3 should do the trick.
AZSUNS
Nov 01, 2008 | Brady TLS 2200 Label Printer
1,633 people viewed this question
Top Brady Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Bob Rambo
Level 1 Expert
NOEL
NOEL
Are you a Brady Office Equipment and Supply Expert? Answer questions, earn points and help others
