Question about Epson Stylus CX5400 All-In-One InkJet Printer
I have an epson nx300 stylus. It keeps saying there's a paper jam. in the middle of paper when it starts to go through..a small krinkle shows on paper...have tried air blasting cleaning..nothing helps. Any help would be appreciated TY
  • Epson Master
  • 12,061 Answers
This is indicative of a sensor fault, or the sensors circuit board.
Posted on Feb 08, 2010
My printer keep saying out of paper when it has paper
There is normally a small sensor flag in the top of the paper entrance area. This tells the machine when there is paper in the tray. Check that the sensor arm is not broken or out of position.
Mar 05, 2012 | Epson Stylus NX300 All-In-One InkJet...
Why does my Epson Stylus NX300 print a rainbow color band at the bottom of vertical 4x6 pictures
DOES THIS COLOR SHOW UP ON YOUR PRINT PREVIEW?
IF NOT, THAN GO INTO PRINT CARTRIDGES ON YOUR COMPUTER AND CLEAN THEM UP!
THAN DO A TEST ON A SEPERATE PIECE OF PAPER THE SAME PICTURE TO MAKE SURE IT HAS STOPPED WITH THE RAINBOW PROBLEM YOU'RE HAVING.
YOU MAY ALSO HAVE PICTURE SETTINGS WRONG ON YOUR COMPUTER, YOU CAN CHECK THESE UNDER PRINT PREFERENCES.
IF NON OF THE ABOVE WORK, THAN TAKE YOUR PRINT CARTRIDGES OUT AND CLEAN THE CONTACTS WITH SOME RUBBING ALCOHOL AND A Q-TIP.
Aug 25, 2011 | Epson Stylus NX300 All-In-One InkJet...
My espon nx300 printer keeps feeding the paper crooked. It crinkles on the right side of the paper, causing the paper to jam each time.
This seems to be fault in the transport of the paper in the rollers. So if you have used any adhesive sticker printing, it is possible that some glue has got clogged into the rollers. If not there can be some jammed paper in the rollers or the mechanism.
So start this work only if you are mechanically able with the right tools.
Remove the covers to get access to the mechanism . Remove the motor drive assembly , the fitting of the motor to the mechanism. Once this is removed the rollers can be turned manually so that you will be able to feed a paper to see the progress of the movement while studying if there is any obstruction or damage to the paper.
There is a in-detect sensor, usually an opto-coupler , make sure this is not clogged or dirty as this IR detection feeds the signal to the processor for starting the motor drive feed.
Reassemble but make sure the rollers are aligned to be in equal gap to feed the paper without a side pull. Now you must print and see if the fault has changed. If not repeat the above work to confirm the area of obstruction.
Nov 03, 2010 | Epson Stylus NX300 All-In-One InkJet...
Printer says there is a paper jam but it does not appear that there is any paper jamed in printer
Check for traces of paper at rear door and restart the printer after closing the door.
Jun 27, 2010 | Epson Stylus NX300 All-In-One InkJet...
I have a new Epson Stylus NX300 Series. When I
Diane,
We try to steer people away from new Epson printers unless they plan on purchasing a professional model. The new Epson cartirdges have little ink and finicky. I would try power cycling the machine with the cartridges removed (unplug it for 30sec.) then reinstall the cartridges. If the problem persist call Epson and let them know what you think. If they don't help you, buy an HP. But but an HP that takes integrated print head cartridges or you'll be in the same situation.
Pat.
Feb 02, 2010 | Epson Stylus NX300 All-In-One InkJet...
Epson stylus cx6600 alll in one roller crimps and stops paper from rolling. My computer says it is working properly. It all started with a paper jam, which I cleared, hit "color" and thus my problem.Ally
Clean the machine, the rollers also and follow these steps to clear out any paper jams it might have
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jul 03, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Epson RX500, Paper Jam - printing couldn't start
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button, applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time. Worth a try. I have fixed a number of printers this way saving costly repairs. Bud
Jan 06, 2009 | Epson Stylus RX500 All-In-One InkJet...
ERROR SAYS PAPER JAM
Its already a hardware issue. go to support.epson.com and look for a service center
Feb 01, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus CX5400 All-In-One InkJet Printer Logo
206 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
