Question about Mitsubishi LT-52148 52 in. LCD HDTV
My Mitsubishi LT-52148 has suddenly stop receiving digital singles from my aerial antenna, but still get singels from my Dishnetwork. What is going on?
2 Suggested Answers
  • 8457 Answers
SOURCE: Mitsubishi LT-52148 lcd tv turns on for 2 seconds
The lamp LED indication flashes?When was the lamp replaced?The lamp has not been replaced 1 1/2 or 2 years.The lamp life is over.Require a new lamp.
Posted on Sep 01, 2010
How do I get an antenna for the FM connection?
You can use an old rabbit ears style antenna or go to a radio shack and get a flat ribbon style. If you're close to the radio stations a single section of wire about 2 feet long connected to one of the antenna screws will work too.
Jan 03, 2016 | Kenwood Av Surround Receiver Vr-307
Fm aerial connection ?
Both of my Marantz receivers use a 75 ohm coax input. The receivers included a single wire antenna that simply plugs in. The plug is suitable for coax cable going to an external antenna. You can also get a small 75 to 300 ohm transformer that will allow you to use a dipole or other common indoor FM antenna.
Feb 11, 2015 | Marantz Audio Players & Recorders
Can a soundbar an sub woofer be hook to Lt 52133, 07 model. if so how and what product #.
Yes! Use the digital audio output from the Mitsubishi TV to the soundbar! You need a digital audio cable that usually comes with the soundbar!
Dec 30, 2014 | Mitsubishi LT-52148 52 in. LCD HDTV
Blue vertical stripe on the right of the screen
The panel is bad. Contact mitsubishi . Some of these units have 5 year warr on the screen.
Sep 01, 2011 | Mitsubishi LT-52148 52 in. LCD HDTV
Hi,just want to know where fuse for electric aerial is situated as aerial is damaged and makes terrible noise when i start my truck and turn it off.my vehicle is a 1996 mitsubishi challenger
Ussually the fuse is in the aerial motor connector or comes with the radio fuse.
If ur annoyed by the antenna, just disconnect the electrical connector in the antenna, not the antenna wire!
U could buy the rod of the antenna only it is chepaer than buying the whole assembly!
Order it in ur nearest parts dealer!
Apr 11, 2011 | Mitsubishi Mighty Max Cars & Trucks
Mitsubishi LT-52148 lcd tv turns on for 2 seconds with sound and shuts off.Tried resetting.What could be the problem?
Sep 01, 2010 | Mitsubishi LT-52148 52 in. LCD HDTV
No dishnetwork signal
OK here we go .the most common problem with dish network and directv is that any cable connections you have that are on the outside of the house are a HUGE weak point in the system.what you want to do is go outside and locate the dish once you have start following the cables until you find any of these cable connections or splices.once you have located them get a 7/16 wrench and remove the cable ..What your are looking for is corrosion in the cable connection.it will look like rust.What happens is your dish system sends 13 and 18 volts down the line to switch channels.When any water gets in these connections it will start to short the connection BUT,you will still get TV for a long while eventually this small short will start to damage the cable connection and you will lose signal all together.make sure to check all of these OUTSIDE connections.Once you find one that is bad you can go to radioshack and buy a cable prep tool that STRIPS the coax"COAX STRIPPERS" to its correct lengths.simply cut off the old connector and replace it.There is a GREAT tutorial at satellitescoop.com that shows you how to do this the right way for under 10 dollars make sure to follow the directions on that site and you should be watching TV in no time.
Dec 29, 2007 | Televison & Video
Mitsubishi LT-52148 52 in. LCD HDTV Logo
32 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
