YIKES! Have a 46 inch 1080p Sharp Aquos. Last night when attaching the S video cable and was teetering the TV, the LCD screen scraped the corner of the stand and now there is 3 small black circles in the bottom left side of the screen with lines of various colour coverring 1/4 of the screens left side. Is there any fix?
    Champion:
  • 206 Answers
This will be horrible news, the screens are fragile and what happened is you broke the screen, And since this falls under customer abuse it will not be covered by warranty, so the cost of replacing that screen will run anywhere from $1200.00 to 1600.00
Posted on Feb 22, 2008
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
NEED BASE STAND FOR A SHARP LC-46SV50U
Go to shopjimmy.com and get a universal stand. It attaches to the back of the TV just like a wall mount.
Mar 30, 2013 | Sharp AQUOS LC-46SV50U 46" 1080p LCD TV -...
TV does not respond to remote
First of all... forgive me me if its a dumb question. But... How long has it been since you changed the batteries in the remote?
Jul 05, 2012 | Sharp AQUOS LC-40LE810UN 40 inch...
I ger AMP error ("Pull out AC cable, check your connection) all the time in all inputs of a new 46" Sharp AQUOS LC-46D85U 1080p 120Hz
I had the same problem with a Sharp Aquos 40". Sound just for a second and the message all the time in the middle of the screen, no more sound.
I opened the TV and found a speaker cable (a black one) with the PVC isolation broken and the wire in contact with the chassis. I just isolated it, the sound came back and no more error message.
Sep 01, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Scratched sharp 46 inch lcd screen can it be replaced
The lcd screen is the most expensive component of the lcd screen/tv/monitor.
It makes no sense to try and replace it as first of all you won`t be able to find the part number required to do that job (e.g. the screens are internally made by sharp // special orders are placed to companies that only start the process for orders greater than tens of thousands of items) and secondly after a lcd panel has been replaced / installed you need to configure the colors, luminosity, contrast, balance etc through a data cable.
I am really sorry for your sharp lcd screen.
Nov 30, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Jun 16, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp LC46SB54U 46-Inch 1080p LCD HDTV Shattered LCD Screen.
it would be very expensive for replacing the screen,even the dealer won't afford that.
Mar 31, 2009 | Sharp LC46SB54U 46 in. LCD TV
Want to change my sharp hd tv from 480i to 1080p
You Can Not Change. The TV Recognize the signal on the INPUT.
If the signal is 480i than the tv shows 480i
If the signal is 1080p than the tv shows 1080p (if supported)
If you try with your areal antenna (for now digital broadcast is maximum 1080i (in USA) The TV itself doesnt "upconvert" lower resolution signals.
Dec 18, 2008 | Sharp AQUOS 52" Flat-Panel LCD HDTV
SHARP aquos 1080p HDTV: VCR image flickers when playback
I have the same model TV and the following worked for me. I am using A/V cables attached to Input1 on back of the TV.
On your Sharp TV remote control:
1. Select the Input (1-5) that is attached to your VCR.
2. Go to the menu and select options.
3. Change your color system to NTSC.
This should stop your picture frome flashing on and off.
You still may have a issue with the screen colors. I don't know of a way to address this, other than to make the picture monochrome.
Hope this helps.
Jun 26, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Help
Best would be hdmi next would be component, both can carry 1080p signal, but hdmi beats component as it can upscale to 1080p.
Jan 21, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
