Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
How do I remove top cover to remove wash tub - Kenmore 3.2 cu. ft. Plus Top Load Washer
  • 744 Answers
The top is clipped down with spring clips. You can pry them up by placing a pry bar with a cloth under it so you don't mar the finish at the two front corners, about an inch back from the front. Be careful and don't get too rough.
If you get down on your knees and look between the top and front/side panels, you should be able to see about where they are located.
Posted on Feb 08, 2010
Remove maytag inner tub
Remove top cover, take out the bolt remove the small cover to expose the plate with several screws,remove the screws and lift the inner tub up. Usually this requires two people to get the tub up and out as it is very hard to pull up as it kind of sticks to the shaft
Jul 02, 2015 | Maytag Atlantis MAV6000 Top Load Washer
Code f51
If its under the agitator, simply unscrew the top of the agitator, pull up the agitator and remove the Necklave. If its under the tub itself, you need to access it from underneath, which means you will need to take off the entire outside cover, starting with the top. Once you have removed the entire cover, then you will need to remove each piece that is blocking you from getting to the Necklave. This process is better done by an appliance repair person.
Jul 03, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
How do I remove the drum on my aav7000aww
To remove the inner tub
remove front panel
remove screws holding top to cabinet
raise top
remove hoses from tub cover
remove tub cover
remove agitator
remove bolts holding inner tub to hub. 5-6 hex head bolts
lift off inner tub
Aug 20, 2011 | Maytag Washing Machines
CAN I PURCHASE A BEARING FOR THE TUB
You can replace bearing for the tub.Instruction are here. disconnect the wire remove front panel top panel and pull cover out remove the screw need a spanner nut wrench to unscrew turn cloclwise remove the tub cone and spinning drum remove the screw .
Jun 20, 2011 | Frigidaire GLWY1343AS Top Load Washer
Model-WHDSR316GOWN. Sounds like the drum is banging against the outer wall during wash cycle, not spin. Drum also seems to move too easily around the interior. Is there a bracket that may be broken? Is...
3 things can do this,there is a shock absorber mounted from the "platform" assembly up to the tub cover on top of the tub that has become dislodged,broken,etc., also there is a "Spring/Suspension rod" also connected in the same manner that can do the same as above shock can,otherwise,there also are 4 "tub dampening straps" located around the top of the tub and they can break off the tub cover and aid in the first 2 issues,you need to remove the front cover by taking a flat blade/putty knife between the top and front cover near the sides and pop the clips holding the front panel on,then you can remove the lid-switch wires and remove the top cover to inspect all above possibilities
Apr 11, 2011 | GE Washing Machines
GE washer will not spin or agitate. Belt is intact machine is a 2009 model #WJRE5550K1WW
replace the lid switch located under the switch as most likely a wire has broken off this switch and is usually not repairable,remove the front cover by using a putty knife near the top of the front cover to dislodge the clips,then remove front cover and the wires to the switch will be near the right side of the tub leading to the underside of the tub and you can then remove top cover to replace this switch
Apr 10, 2011 | Washing Machines
Wash machine shakes and bounces when operating with a full load.
you need to remove the control panel and 2 clips that hold the entire cover on then tilt cover toward you to remove outer cover then check the tub springs 3 of them if one broken it will be loose and bounce,also the drive block could be worn under the inner tub,the shipping straps or bolts need to be removed if the machine is new otherwise it will also bounce around
Jan 01, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a Maytag LAT2500AAE top load washer. The
check the balance ring on the tub just below the tub cover and tub cover gasket which can be done from the top of the machine by removing the top cover,while doing this pull and push tub from side to side and see if it moves easier in certain directions, if it does you may have a tub spring broken on the tub leading to an un balance condition cause the springs stabilize the tub like a shock absorber on an auto, if this is it then you need to access the lower unit area by removing the front cover of the unit there are screws at the toe kick panel to remove this panel
Dec 08, 2009 | Kenmore 24032\24036 Top Load Washer
Cleaning the drum of the Whirlpool 3 LSR 6233 EQO (get it out)
Remove two screws that hold the control panel,pull forward and lift ,tilt back. Unplug door switch and remove the gold clips that hold the back to the top of washer cabinet. Lean cabinet towards front and remove. Unsnap tub ring at top from outer tub. Remove fabric softener dispenser cup at top of agitator. Remove snapped in plastic cover and seal underneath. Remove bolt under the cover. Remove agitator. Remove spanner nut that holds drum in and remove drum.
May 13, 2009 | Whirlpool LSR6332K Top Load Washer
Leaks water frim front of the machine
make sure the tub is pushed back , not leaning foward. this fills from back of tub possible splashing on and over the tub rim, anorhersource of leak could be from pump assy removing front cover and lookng at pump will tell (if its been leakin its quite obvious)
Feb 24, 2008 | Whirlpool LTE6234D Top Load Stacked...
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
43 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
