Question about Canon PIXMA MP830 All-In-One InkJet Printer
Printer turned off while computer on. Won't turn on again. I checked plugs and disconnected for 5+ minutes. Still will not turn on
    President:
  • 2,306 Answers
If the carriage is not locked into th right side, you can try removing the printhead. First you remove all inks and then take out the printhead by lifting the handle. If it powers up without the printhead you need a new printhead, don't put the old one back in as it will ruin the logic board.
Posted on Feb 08, 2010
Ir400s error code
Could you provide a printer brand and model number? Without that information it is nearly impossible to give you good advise. I would disconnect the USB cable from the computer then turn off the printer and disconnected the printer power cord from the electrical outlet. After about 1 minute plug the printer back into the outlet, turn the printer on and reconnect the USB cable to the computer. If you are lucky the printer might reset and start working again.
Oct 15, 2014 | Office Equipment & Supplies
Computer won't detect printer
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/nJ7AgN. Select your operating system, download and execute the file.
Feb 10, 2012 | Lexmark X1290 All-In-One InkJet Printer
Lexmark X1190 problem communicating with computer
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
Dec 20, 2011 | Lexmark X Office Equipment & Supplies
Lexmark x7550 won't communicate with computer to scan
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/ngaKcu. Select your operating system, download and execute the file.
Oct 19, 2011 | Lexmark X7550 InkJet Printer
It want print anything!
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print again.
Sep 12, 2011 | Lexmark C533DN InkJet Printer
Lexmark X4650 prints fine & used to scan to computer, now when press scan>scan to computer>downloading application list & seems to freeze.
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
Aug 31, 2011 | Lexmark X4650 InkJet Printer
Wont print
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 21, 2011 | Lexmark X4550 AllInOne InkJet Printer
Why won't my printer print after I installed the software? It says its ready but nothing will print
4. Reboot your pc.
Aug 18, 2011 | Lexmark PhotoJet Z705 InkJet Printer
"Communication Not Available" message is displayed
2. Unplug and re-plug the printer into the power source to reset it.
4. Reboot your pc.
You may also try to update your printer driver by visiting the Lexmark website at . Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 16, 2011 | Lexmark X2670 All-In-One Printer
After installing new drum in my MFC=7420 the computer does not recognize the printer. what can I do?
Turn off your computer. Turn off the printer and disconnect the usb cable. Turn on the computer allow it to boot up fully. turn on the printer, then plug the USB cable into it. The computer will soon say 'found new hardware' Give it a minute and the computer will have recognized your printer again. Make sure your 7420 is set as the default printer.
Jul 04, 2010 | Brother MFC 7420 All-In-One Laser Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
63 people viewed this question
old marine
old marine
