Question about Dell E173FP 17" LCD Monitor
When I turn on my system the monitor display the normal windows start up screen. Once the system has booted up the screen seems to slowly pulsate from a black screen to a normal screen.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 61 Answers
Update ur monitor dude~! :/
Posted on Feb 08, 2010
Mode not supported
this happens when the output resolution on the Graphics adapter from the CPU is to high for the monitor. you will need to reduce it.. if you have already set it well there may be an issue here.
1.) boot the system in safe mode, keep pressing F8 just before windows starts and enter safe mode.(it will boot in a low res allowing you to see whats going on)
2.) right click on your desktop and and click personalize or properties.
3.) under display settings lower the resolution to 800, 600
4.) shut down and reboot
5.) now it will boot normally and look like bad.
6.) go back into the display setting and slowly send up the resolution until it looks good, If you go to high dont worry, the screen will go blank for about 30 seconds and your previous settings will then be restored. just remember to click apply first to test the settings,, then click ok once it works and your satisfied.
Dec 29, 2012 | Proview PL916S2 Monitor
Screen in two parts, just during boot
Don't worry about it. During boot time, the input to the monitor is set to a different resolution (640X480 for plain text). The monitor remembers settings for different resolution inputs, and the position is wrong but it's not a monitor problem as such. You could adjust the position and the display would be properly centered, but it's not worth the effort. Once the system starts Windows and the resolution switches to your normal settings, the display looks right. Once in Windows, you can't even set the resolution low enough to adjust the monitor; Windows won't go below 800X600 pixels.
Feb 06, 2011 | HP Pavilion F1703 17" LCD Monitor
I have an Emachines W3609 desktop with windows vista. One day i powered it on and the fan ran hard and i got three beeps and no display in the monitor. I went into the case removed the ram and found 1 ram...
i seem the power supply gone bad, it is hard to say what is the problem actually, you need to check all of your devices(processor, ram, video card, motherboard and power supply) to some other system one by one for confirmation.
Nov 05, 2010 | Computers & Internet
When i turn it on it says out of range and i have a black screen
Hi, The reason behind the out of range (frequency of monitor) because the video display adapter is trying to set resolution more than what the monitor (screen) is capable of. In this case, try to boot your computer in Safe Mode using F8 function key while starting your computer. Once you are in safe mode, try to decrease the resolution of monitor to the lowest resolution level and apply the settings. Now try to boot computer in normal mode once again, you will get the settings which you have applied in safe mode. Adjust the screen resolution accordingly till the settings work with the monitor (screen).
Cheers!
Mar 01, 2010 | Microsoft Windows XP Home Edition
I have a Gem gl-190z2 monitor that displays over range after boot
Just lower the screen resolution
Boot into safe mode first by repeatedly pressing F8 and select safe mode
once booted click on an empty area of the screen and take it from there. 800x600 is a good starting point
Re-boot and adust as needed.
Your monitor was just telling you it was too much for it to handle thats all.
Sep 22, 2009 | Systemax Scanport Gem GL-190Z2 (Black) 19...
I was playing online games on my sony vaio. Suddenly I got blue lines on the screen and the laptop stopped responding. So I tried restarting the laptop but I get blue thin vertical lines before the laptop...
Blue thin lines before it boots will rule out an operating system or driver fault. So it would appear something in the machine has failed.
Do you have a VGA monitor you can connect to it and see whether it shows the fault? This will show that if the fault also shows on the external monitor, it is likely an electronic fault on the main board, whereas if it works on the external monitor but not on the built-in monitor, my guess would be the cable that goes from the main board up through the hinge of the screen into it, or a connector, or an actual fault with the LCD display.
Windows booting normally once the display drivers were disabled indicates to me that Windows is no longer detecting the faulty display and therefore boots normally - possibly pointing to failed electronics in some way. It could even be corrupt BIOS that controls the video or something along these lines, though that's unlikely.
Good luck, either way it sounds like it's off to a computer repair shop. Is it under warranty?
Apr 27, 2009 | Sony VAIO VGN-SZ460N/C Notebook
Start up screens are off to the left.
There's nothing wrong with the monitor. Monitors remember the settings for different video modes, including horizontal position. The video mode used when the splash screen displays is a size almost every monitor can handle. Then the mode switches to whatever you've set once Windows finishes startup. As long as the display is normal once Windows is running, you really don't need to be concerned.
If you want to correct the problem, you need to put the monitor into the same resolution and use its menu functions to adjust the size and position. Try pressing F8 when the machine boots to get into the Windows startup menu. This will probably also be shifted, so you can adjust the settings while the menu is being displayed.
Apr 16, 2009 | Computers & Internet
I have a Dell GX60 and I changed the display resolution and
So, with The computer, completely turned off, Turn it on, Can't you see the BIOS screen? , or a Dell LOGO?
It is when you see this BIOS or Dell logo Screen that you Need to:
  • PRESS F8
  • Press F8
  • Press F8, again, and again right when your computer turns on.
Then You should be brought to the Window that allows you to boot into SAFE MODE, DO NoT PICK SAFE MODE.
Pick: ------------ENABLE VGA (basically safe mode) Only!.
Once booted, log in and change the resolution to let's say 800x600,
then restart your computer normally.
You should then be able run windows normally, (Without F8 Key) where you can then change the resolution to what you want.
IMPORTANT! Remember this, if you set your display to a resolution that it Does Not
support, and the screen goes blank. DO Not Turn off your computer: ALL YOU DO IS PRESS
the (Esc) ESCAPE Key within 15 Seconds and your monitor's resolution will be set to it's
previous state again.
I Hope This Helps.
Jan 30, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Blank Monitor
Start pressing F8 at boot
When the Windows Startup menu appears, select ENABLE VGA MODE
This will boot the system in 640 x 480 resolution but the video driver will be installed. Once at the desktop, either reset the display to the normal resolution settings or reinstall the video driver.
Aug 06, 2008 | Relisys RLT1720 17" LCD Monitor
Toshiba satellite A100 Monitor problem
LCD issue it needs repair..call tosh if your laptop is still in warranty
Feb 01, 2008 | Toshiba Satellite A100-ST3211 Notebook
Dell E173FP 17" LCD Monitor Logo
75 people viewed this question
Alun Cox
