Question about Toshiba Satellite M35X-S149 Notebook
Does not power stay on
Hello, I am checking my nephew's toshiba satellite m35sx-s149. When the power button is pressed the fan starts and run for about 5 seconds, then shuts down. The screen never comes on. The light around the power button stays on but there is no indication that the laptop is working. When I hold the power button in for several seconds the unit turns off.
I tried connecting an external monitor to see if a windows splash screen would appear, but got the same result. Are notebooks known for poor quality?
Thanks, Robert
  • 5 more comments
  • BobFY Feb 22, 2008
    Thanks, I tried it with just the ac power and the battery removed but got the same results. The fan shut off after 5 seconds or so.
    It is out of warranty. Thanks for your help!
    It was purchased in Dec 2004. There have been other problems over the past few years and it has gone back and forth to Toshiba 3 times. Their experience with Toshiba tech support was not very favorable. From what I can see replacement mother boards run from $150 - $400 with no guarantee.
    Thanks again for your help!
  • Anonymous Mar 29, 2008
    fan runs 5 seconds and nothing happens. light still flashes
  • jpadgett324 Jun 23, 2008
    I'm having the very same problem. Fan runs for 5 seconds and the unit never comes on. Till it gets good and ready.
  • bigmsalt Aug 09, 2008
    I have the same problem. I found that if you push down firmly above the keyboard where the heatsink and cpu are that it will turn on and run when you press the power button. The problem is that it doesn't always work, and when you move the laptop at all, it goes back out. I also tried reseating the cpu but same problem.
I am having the same exact problem. I have tore the system down all the way to memory, motherboard, and LCD. The fan stops spinning after about 5 seconds. Sometimes the system will post (with the fan stopped), but as soon as I touch the keyboard, the video goes out and the system freezes. I am a certified technician with years of experience. I personally believe this is a motherboard issue. The portable is out of warranty, so I am not going to know for sure until I replace the motherboard. Since this is such a common issue, Toshiba should replace the motherboard (regardless of warranty status). I will never purchase a Toshiba again.
Posted on May 08, 2008
My computer comes on stays on for a while then shuts down,if i hold the cord in the back with my hand while pushing it in it stays on, get this,this is a new ac/dc cord. it is not the cord. can you help?
Posted on Mar 01, 2008
    Genius:
  • 3,587 Answers
Try this with just the ac plugged in and the battery removed. Sometimes the battery, when fully discharged, can cause the system to shut down.
check your warranty here for Free
Posted on Feb 22, 2008
  • 1 more comment
  • Patrick Michaels
    Patrick Michaels Feb 22, 2008
    ok..so fan is off...and nada on the screen, right? sounds like an unhappy motherboard..this thing under warranty? if not, use my link to check warranty conditions
  • Patrick Michaels
    how olds the machine?
  • Patrick Michaels
    right..that's too bad, since usually Toshiba is a good product...
Recently I cleaned cooling fan of my Toshiba L300 laptop. When press power button to start, fan runs few seconds and stop. Is his normal or any other problem? I dont know how it work originally before the...
the fan is used to keep the motherboard cool. if the motherboard dosnt reach a high tep the fan will not kick on. it's a good thing. means motherboard is staying cool.
Oct 26, 2013 | Toshiba Satellite A135-S2276 Notebook
Hello my toshiba satellite m35-s149 dos not boot power button stays on I can hear fan and also hearr it beep. but theres nothing on screen if u can giv me some advice appreciate it thanx
If you can hear the startup music, try plugging the laptop into a regular monitor and press FN+F5 to view your operating system. This will mean that your backlight has blown and you need to replace the screen. If not, oh boy, it could mean that your motherboard may have taken a dive. Before you trash it replace the meory chips, just in case they have become defective.
Aug 08, 2010 | Toshiba Satellite M35X-S149 Notebook
When pressing start button light comes on and fan starts but after 5 seconds stops and nothing happens it will not start up.
Remove the battery and press the start button for 5 to 10 sec. connect the battery and try to start. . .
If its still not working then Remove the RAM and Reconnect them and check.
Remove the Hard Drive and reconnect it and then check
Jun 03, 2010 | Toshiba Satellite M35X-S149 Notebook
The system will not power on from battrey.when i plugin the a.c. power the fan come on but the system will not boot up
Please try the following steps:
1 Disconnect the battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Connect the charger (don't connect the battery yet) and try to start by pressing the power button.
Let me know if everything remain same.
Feb 19, 2010 | Toshiba Satellite M35X-S149 Notebook
I have a Toshiba satellite M35x-S109 Laptop won't start up
Any luck getting this fixed?Please let me know.Thank You very much!
Tyler
Jan 12, 2010 | Toshiba Satellite M35X-S149 PC Notebook
Computer does start up
Does it not seem to get power? This is a common issue with the S149. If you have a charged extra battery or one from a similar Toshiba laptop like the S311 you can see if it starts with a charged battery. If it does the problem is likely the soldered connection on the motherboard for the power cord. This commonly breaks and causes the laptop to not run off the power cord and not charge the battery, but it will run from a charged battery. If this is the case you will need to resolder the power connector to the motherboard. The laptop must be disassembled to make the repair. If you do not have the tools, knowledge or experience to do this or the solder job then you will need to locate a technician that can.
Sep 24, 2009 | Toshiba Satellite M35X-S149 Notebook
NO VIDEO OUTPUT FROM LCD OR EXTERNAL MONITOR ON TOSHIBA SATELLITE L20 LAPTOP
you may do follow steps
1) eheck memory : reseat all RAM or change other same model RAM
2) take out wireless card at back of laptop MINIPCI. try it
3) still nothing run, your otherboard hardware damaged, need to change the motherboard. the parts please reference here
http://shop.ebay.ca/items/__Toshiba-Satellite-L20-motherboard_W0QQ_kwZToshibaQQ_kwZSatelliteQQ_kwZL20QQ_kwZmotherboardQQ_ckwZlaptop?_trksid=p3286.m104.l1200
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
May 22, 2009 | Ultra Computers & Internet
Toshiba laptop m35x-s149 does nothing.
Probably a shorted wires. You can open DVD ROM using paper clip. GOOD LUCK
May 15, 2009 | Toshiba Satellite M35X-S149 Notebook
Toshiba Satellite P200 doesn't boot
Try pressing FN/F5 keys simultaneously, or the key that toggles internal/external Display. Look for the double screen Icons on the keys.
Tap the Pause Key.
Restart and press and hold F8 key when Toshiba logo appears. When the boot Menu appears, select Last Known Good Configuration.
If all else fails ther should be a reset button on the side of the LT. Consult owners Manual for location
Aug 15, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite M35X-S149 Notebook Logo
160 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
