Question about Dell Wireless 2350 Router
Hello, I have just added the crypto function for my router. It worked fine for 5-10 min then router started to reboot. I tried to power off and on, nothing happened. Tried to reset. Now the router seem to be stuck. The lamps for Lan1-4 and the internet lamp is light continously. The lamps for power and wireless are not light at all.
  • 4,281 Answers
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Feb 08, 2010
Problem with cisco 2513 routers
Check what version of software do you have. Do "dir" command and look at the file name. If it contains "K9" in the name, then it has "crypto" functionality, if it doesn't, then you need to find it (however it will be quite a challenge, as these routers are end-of-life for a decade...)
Good luck,
Mike ' CCNP, CCDP, CCSP, CCVP, etc.
Cisco Compatible Headset Adapters for 7940 7960 etc
Mar 30, 2017 | Cisco Computers & Internet
Hi! i was playing call of duty online when the electricity went off. after some time it came back and when i tried to reconect to PSN it dosnt let me. it does get the IP adress but there is an error in the...
Hello
Try a router reboot.
Unplug all wires to the router.Including power.
Let sit for 3 min.
Plug power back in first.Then plug ethernet wires back in.
Now try playstation again.
Aug 01, 2011 | Computers & Internet
My Linksys WRT160N router is only partially functional. After working fine for several months, it now connects only maybe 1 time in 10 - and most of those connects are very slow and unstable. Occasionally,...
Please be sure your router is not too close to your cordless phone.
They both works on similar frequencies and the router can become unstable.
regards
Mar 19, 2011 | Linksys WRT160N Wireless Router
Internet went out on the wireless router and it will only stay in local only
Hello
First check with your internet provider if any outages are reported in your area.
Next try a reboot of the router.
1 Pull all cables ot of router,including power.
2 Find reset button,usually in the back use a pen tip or paper clip to hol it in for 1 min.
3 Reconnect cables,power last. Then power up router.
4 Turn on pc.
May take a minute or two to find the internet again.
Jan 08, 2011 | Computers & Internet
My problem is that on my daughters computer it says connected with limited access. yet on the main computer where the modum is placed the internet works fine. my daughter has claimed she did not do...
Hello
Try to reboot the router.
1 shut down all pcs connected to router.
2 Unplug all cables from router,mark them if you think you will forget.
3 Unplug power from router also.
4 In the back of the router there is a small reset button hold this in for 1 min with a pen tip or a paperclip.
5 Replug everything back into router,power up router.
6 restart your pcs.
Nov 29, 2010 | Linksys Wireless-G WRT54G Router
My WRT54G router has been functioning flawlessly for three years... until today. All of a sudden, neither my laptop nor my Blackberry don't see the wireless network... although the 2 PCs that are...
If you have a modem unplug it then unplug your router, wait for 2-5 min then plug in your modem then router. It always seemed to work for me. If it dont work call Linksys.
Oct 15, 2010 | Linksys Wireless-G WRT54G Router
Error105 (net:ERR_NAME_NOT_RESOLVED)The server could not be foun
Hello
Try a router/modem reboot.
1 turn off pc/and power off router
2 unpug all cables on router
3 leave off for a min 60 sec
4 plug all cables back into router and turn on
5 restart pc
Apr 23, 2010 | Microsoft Windows XP Media Center Edition...
Dlink router, Dell laptop - no connectivity - won't renew IP
resetting netsh was a good start. I would suggest starting with pulling the power on the router for about 5 to 10 minutes and then plugging it back in. give it a couple of minutes to reconnect to the modem and then try connecting to it again wirelessly. I had an issue with my dlink gigabit that stumped me and a cold reboot was the only thing that worked
Jul 15, 2009 | D-Link AirPlus DI-524 Wireless Router
WRV54G Linksys router right out of box setup and for 5 min no prob then...hell broke loose neither computer had internet access(2 comps and an iTouch) connected via bypassing router and worked fine...
Do you have DSL or cable? Try resetting your router. Press the reset button on the back of the router and hold it it for about 5 seconds. When the router comes back up type in the router address: 192.168.1.1. If your ISP is using cable, make sure that you have DHCP enabled. If DSL, you will have to put in your username and password given to you by your ISP and you will have to enable PPPOE on your router.
Jun 11, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
Dell Wireless 2350 Router Logo
26 people viewed this question
Alun Cox
