Question about Boss AUDIO SYSTEMS BASS600 Car Audio Amplifier
BOSS BASS 600 - No Sound .
I bought a new BOSS BASS 600 . I presume I have done all the wiring correctly , power,remote,line-in and ground. The Amp turns on with the green light ,so does the control box light comes on. But there is no sound from the woofer , what can I do ? How can I check if there is a signal from the head unit line out and remote line ?
  • 47 Answers
ITS BEST TO HAVE A SOLID REMOTE WIRE WITHOUT NE SPLICES WAT SO EVER
Posted on Feb 28, 2010
On my amp both my red and green light are on at the same time and won't play any bass. How can I fix this?
First make sure your amp is grounded good to the frame of the car..
If it is.. Try unplugging everything except your power wire, ground and remote wire. Turn amp on and see if both lights are still on.. If they are then it's most likely you have a blown capacitor inside the amp(little battery looking things on motherboard).. This normally happens from over heating.. Or wrong size wires.. But both lights coming on is normally from your positive and negative touching somewhere
Jan 24, 2015 | Car Audio & Video
I bought new boss bass600. I presume that I wired everything correctly, but whenever any metal part of RCA cable is touching the input receiver unit (even before plugging all the way in) the red light...
Not wired correctly and there is a short being created when you do what you described. Have someone other than yourself go over the wiring to resolve the issue.
Aug 27, 2017 | Boss AUDIO SYSTEMS BASS600 Car Audio...
I have a boss bass 1200 low profile amplified sub that isn't working. my power wires connected and receives juice, my ground is grounded, and my remote is hooked up. also my rcas are connected and the...
+ positive from battery ground is of course - anywhere on body put it on last.to avoid sparks if + is powered up! U can put a link between remote and positive it should then be on. Led normally goes blue rca s need a signal from stereo make sure its a amp out or sub out not an input on stereo set all knobs to middle and if speaker is connected to amp speaker + - it should be on, try an mp3 player with jack to rca for testing a known signal.amp may have loop rca make sure its on inputs.some have high inputs too using speakers wire stick with rca
Jan 17, 2018 | Boss Car Audio & Video
Boss bass 600 Amp comes on but does not have sound
yes and also moisture. i have had plenty of amps die like this on me! needs repair
Jan 06, 2010 | Boss AUDIO SYSTEMS BASS600 Car Audio...
Red light flashes on amp when you turn the ignition key.
It really sounds like a grounding problem. Recheck it make sure where it's attatched to the chassis is scraped to bare metal, an you used a clean, shiny bolt to attach it. Also us a voltmeter to check your power wire just to be sure it's not that, you should get 12-15 volts. Also just make sure none of your fuses are blown. And Use the voltmeter to check your REM wire, your should also be getting 12-15 volts there. If this doesn't fix your issue i'm at a loss to explain it..... Buy a new amp, and don't buy Boss, i've had lots, and lots of problems with them in the past.
Sep 12, 2009 | Boss gt580 - GT580 1000W 2 Channel MOSFET...
2005 Dodge Neon SXT Kicker Amplifier
if its a new amp there should be a problem. make sure you have your remote wire hooked up to your radio(its blue). make sure your fuse on your amp wire isnt blow and make sure you have a good ground. if your runnin the ground off the car make sure the paint is scratched off that area
Mar 08, 2009 | 2005 Dodge Neon
Amp light is neither green or red
have u connectted the remote wire from head unit to turn amp on? have u got + and - the rite way round.hope this of use.
Mar 05, 2009 | Power Acoustik PS2-1250 Car Audio...
Prot. light at High vol. (forget Bass CD)
You may have the speakers wired for the wrong impedance.
How many ohms per voice coil?
How many voice coils per speaker?
If the speakers are DVC, are the coils of each speaker wired in series or parallel?
Are the speakers bridged on the amp or one per channel?
Jul 06, 2008 | Lanzar VIBE266 Car Audio Amplifier
Boss AUDIO SYSTEMS BASS600 Car Audio Amplifier Logo
365 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
