My Philco washer/dryer model RWD 1042 is not drying cloths very well. When new it did a very good job drying. Now it gets the washed items hot in the dry cycle but does not effectively remove the moisture. The machine takes in cold water for the condenser but it seems as though the condenser surface must be covered with lint. I have no data as to where the condenser is and how to clean it of accumulated lint. I need advice as to how to access the condenser or clean same.
  • 2 more comments
  • altos43 Feb 13, 2010
    The "Guru" apparently does not understand anything about my machine. It does not have a duct. It uses cold water in an internal condenser to collect the moisture from the washed items that are heated in the machine. This moist air is circulated over a water cooled surface where the moisture condenses and is collected and pumped out of the machine into the drain pipe. There is no duct used by this particular model.
  • altos43 Feb 21, 2010
    Sorry I havn't got back to you sooner. I've been out of town for a few days.
    Wit respect to your solution, I think you are addressing a problem that might occur with a vented machine. This washer/dryer uses cold water circulating through an internal condenser. Moisture from from the heated cloths condense on the cool condensor surface and is pumped into the drain together with the condenser circulation water. There is no external vent as other machines have.
  • altos43 Feb 22, 2010
    All your experts seemed to think that this machine is vented. It is not! It is a condenser drying machine and does not use an outside vent hose. It uses water to cool an internal condenser and the condensate is pumped out with the water used for cooling.
  • altos43 Feb 26, 2010
    The answers given by all do not address my washer/dryer. They either reference standalone condenser dryers or vented washer/dyers. None of the responses provided a useful solution to my request.
  • Washing Mach... Master
  • 2,605 Answers
Hi, I see you've been having some challenges finding a solution, I think I can help. **turn off the power or unplug the "combo" from the wall** If you are capable of removing the top you'll soon notice there is not much elbow room in there to work...fortunately for this issue you won't need much. On top, directly behind the timer on the right hand side top of the tub, is a "condensor housing" ( usually made of "white metal" or "pot metal" as some refer to it ) with a blower fan motor fastened to the top. Remove the fan motor wires and then the motor itself from the housing via four hex head screws around the perimeter of the fan motor bracket. This is where "elbow room" may be tight, but with persistence and careful manuvering you can do it. You may be able to move the tub to the back and left While backing out the fastener's/screws to give you a little more room. Pull the motor assembly up & out ( careful of wires and sharp edges ) and examine the blower wheel and housing. By now it should be obvious of the problem. These unit's because they are so compact are vulnerable to lint build up in the blower wheel and housing hence, the unit will not perform well in the "dry" cycle. Hope that helps move you forward. Let me know if I can assist you further, I'll watch for your reply here. Thank's for visiting "fixya" for your repair inquiries. Good luck, Macmarkus :)
Posted on Feb 26, 2010
  • Mark MacDonald
    Mark MacDonald Feb 26, 2010
    Hello again,
    I just wantrd to add to my first reply. When you have the blower out I find running hot water from the sink tap ( or anywhere...I don't think it matters, ha ha ! ) over the blower wheel cleans it thoroughly. Cleaning out the condensor housing is a nother matter...by hand is the only way I do it. It can be cleaned via a garden house, but be careful not to overfill the tub or flood your place. Normally it drains when plugged in, but since your's is not plugged in ( Right ? ) that won't happen. If it is in a basement, you can lay the drain hose down to the floor drain and it will run right through though or...Hope you have small hand's. ;)
    Once again good luck.
    Regards,
    macmarkus :)
  • 2,418 Answers
The condenser unit is behind the vent louvers. Lean your mach. over on a bucket or against the wall, so you can SAFELY look under there and remove the rear panel to access and try to clean the coil with your vacuum cleaner, using a extension you make out of paper roll tubes or just what have you and duct tape. Now this may not be the problem, You may have a small fan that is not working. You may have to set the mach. up so you can turn it on to the dry mode in this leaned position to check. Feel free to reject and repost or leave here for others to answer.
Posted on Feb 14, 2010
  • John Fourteen Six Feb 16, 2010
    Hello Altos43, Have you fixed your washer/dryer? I was wanting to know, how is working today? Did you find the condenser? Let me know.
    Brigadier General:
  • 3,917 Answers
First, check the exhaust pipe in the back is not being crushed. Dryer manufacturers require a metal duct from your dryer, but a lot of people who install their dryers themselves use a white vinyl hose. This is not an approved installation and can be dangerous. If you do have a white vinyl flexible hose you should have a professional install solid metal piping. If you already have solid metal piping on the exhaust it might be blocked with lint. This can be a fire hazard, so you should have a professional come in and clean the exhaust duct and the dryer itself. If the exhaust gets blocked the dryer takes longer to dry and can overheat and cause a fire. If you do all those things and the dryer still takes a long time to dry it is possible that a thermostat or the heating element has malfunctioned. In this case, you'll need a repair person to come to your house to fix it. It is not suggested to do the above mention things by you. There are professionals that can help you.
Let us know if you were looking for something more else please accept the suggestion.
Thank You for contacting Fixya.com
Posted on Feb 08, 2010
  • 3,740 Answers
The condensor should be on the bottom of you machine. Take a look at this link: http://www.squidoo.com/keep-your-condenser-dryer-running-efficiently
A shower head works great for cleaning the condensor but you need to screen the drain. Otherwise take it outside and clean it ' seriously hose it off " I looked for an hour for users manual with no luck.
Kelly
Posted on Feb 22, 2010
  • 10,865 Answers
Hello. The problem is that there is an accumulation of lint in your dryer's vent pipe to the out doors. pull the dryer out from the wall and remove the vent pipe. look into the rear back of the dryer to see if there is lint buildup there, if there is remove it. Also check the pipe, and out doors the little trap door area.
Finally be sure to always remove the lint in the filter after each and every load. Regards, Joe
I want to know how hot my dryer gets. I do not have temp. controls on my model
Good Morning Tabitha,
I see that you are looking to see how hot your Frigidaire dryer, model# FER311FS, actually gets, due to you not having temperature controls on your particular model. Being that you have just the timed dry cycle, it provides up to 100 minutes of drying time at high heat for regular and permanent press items. When drying permanent press items, turn the cycle selector to 40-50 minutes. This is the average time needed to dry most loads of permanent press items. The load tumbles without heat during the last 10 minutes of the Timed Dry cycle. Use this setting to refresh clothing, pillows or blankets or to dust draperies. Heat-sensitive items such as plastics, foam rubber or similarly textured rubber-like materials or items containing feathers or down should be dried only with this setting. Hope this is helpful.
-Best Regards-
Mar 17, 2014 | Frigidaire FER311FS Electric Dryer
Maytag model #: med5770tq0 won't dry. Please help
Dear Emily.
Several problems.
First, did this dryer ever work properly hooked up as it is?
I mean hooked to the roof event?
If it used to work just fine, then I suspect the vent to the roof is clogged with lint and is not allowing the heat to escape.
If it never did work right,(for example: it is new to us) then I'd venture dryers are not supposed to vent their hot air that far away, they do not have a strong enough blower to push that air that distance.
Then, you might try to find another place to vent the hot air, with a total distance of only 10 feet from the dryer, even if you only vented it while you were actually drying clothers.
I doubt if the last item is for you, but I have sometimes seen where the washing machine did not spin all the water out of the clothes, and then the dryer needed all day to get the clothes dry.
Be blessed.
Apr 17, 2013 | Maytag Dryers
Dryer not heating very hot. need to run two cycles to dry
Dryer is not drying properly, In order to resolve try following things.
  • Check the exhaust hood outside the house, does it open and close freely, Clean the lint filter and exhaust duct.
  • Do not overload, 1 wash load = 1 dryer load. Sort heavy items from lightweight items.
  • Large, bulky items like blankets or comforters may require repositioning to ensure even drying.
  • Check the washer to be sure it is draining properly to extract water from the load.
  • Clothes load is too small to tumble properly. Add a few towels.
I hope this will solve your problem.
Good luck and have a nice day.
Jul 04, 2010 | Frigidaire GLGQ332A Gas Dryer
It takes a long time to dry a load of clothes
sounds as if you may have an issue with a blocked/clogged ventin, perhaps wher it leaves the home, a unit that is not able to expell the heat will tend to not dry the clothes properly, 2-3x to dry a good sign of venting issue
Jan 14, 2009 | Kenmore 98702 Stacked Washer/Dryer
Clothes wont dry but gets really hot
make sure your exhaust line is clear and not kinked
Oct 24, 2008 | Washing Machines
Hotpoint bwd129 washer dryer won't dry my clothes.
my Hotpoint dry will not dry my clothes. It will run for hours and the clothes still haven't dry just felt hot.
Oct 05, 2008 | Washing Machines
How do you DRY with the Haier washer/dryer
Have you tried lengthening the dryer cycle or running it at a higher temp? The usual culprit for wet clothes is not running a dryer long enough or hot enough. (I remember some stand-alone dryers (coin-operated with a fixed drying time per coin) that needed two cycles to dry stuff.
Jul 12, 2008 | Haier 14.3 lb. Washer/Dryer Combo
Cloths not getting dry
id look into a clogged and or kinked exhaust vent. perhaps where it leaves the home theres a screen over the housing thats clogged itself w/lint. its generating heat, thats good now just needs to release it somehow
Mar 16, 2008 | Washing Machines
Neff washer/drier
soap drawer is just a slide fit - give it a good yank. for the dryer, take the top off and there should be a mainifold across the top with stats mounted on it. one or two may be re-settable stats ie have a little button in the middle which press to reset. if this works, cause of stat popping out is usually a lint blockage in the dryer manifold
Apr 28, 2007 | Neff V4380X0 Front Load Washer / Dryer
Heating, draining water(enough?) but not drying clothes, they're just HOT, so is top of machine
You have a problem with the condensing duct.  Possibly clogged with excess and lint and needs to be cleaned out.  This requires disassembly of the unit to get to it.  Not a difficult job but not easy.
Oct 22, 2006 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Washing Machines Logo
173 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
