Question about HP PSC 1350v All-In-One InkJet Printer
Cannot get my printer to scan.
When I first turn on my computer I get TWAINtrackerWindow:apdroxy.exe
This application has failed to start because CoachUsd.dll was not found. Re-installing the application may fix the problem. I do do know what it is talking about or where to find it. The other thing when I try to get my printer to scan something I get this message. An unexpected internal error has occurred. Click ok to close the program, and then try one of the following: Restart the program, restart the Pc & then try again, Reinstall the Photo & Imaging software and try again. I Did the 3 things. I restarted the program, restarted the PC and tried again, and Reinstalled the software. When I try to scan something I get the picture of the scanner and the above message.
  • robertpons May 06, 2008
    cannot locate the printer
How can i fix my printer
Posted on Oct 28, 2010
I have a Veratec desktop computer and am having all kinds of problems with it. It is one year old. Will not communicate with my dell printer A920 and is difficult to operate otherwise. Please help.
Well what operating system do you have on it? Windows7 doesnt like some printers. check online for print drivers and update them. Follow this link to help you with that... http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&l=en&s=gen&docid=DSN_FA36C542525D975EE030030ABD621881&isLegacy=true
you can also try this approach... First, let's make sure your computer has the latest Windows Updates, especially .net framework, needed to run many applications and the latest Java.
Disconnect your printer.
Download and run this patch (***WARNING*** The patch for this printer also removes other Dell applications, like Dell Dock, Dell QuickSet and other Dell applications)(These applications can be downloaded at Drivers & Downloads and can be reinstalled) to completely remove the printer from your computer. Run the patch(A MUST on Vista Machines) until it prompts you to restart your computer.
If using Windows 7 also try...Manual Printer Driver Removal
Restart your computer.
Download the proper drivers.
XP Drivers
Vista 32-bit Drivers
Vista 64-bit drivers
All other drivers
Install the proper drivers. You'll be prompted when to connect your printer(powered on)
***To install drivers, sometimes the file unzips and does nothing. You have to look for the setup.exe file, right click on it, then left click run as administrator***
If using Windows 7, use the Vista drivers in the compatibility mode.
Right click on the setup.exe file, left click properties, left click compatibility. Change the compatibility to Vista(Try Vista SP2). Then install the proper drivers. You'll be prompted when to connect the printer(powered on)
As for scanning, if you have the disk that came with the printer, then insert the Printer disk and stop it from running. Go to My Computer and double click on it. Look for the drive with the Dell disk in it. Right click on it, left click explore. Look for the OCR Folder. In the OCR Folder, there is an Abbyy Folder. right click on setup.exe, that's in the Abbyy Folder and left click run as administrator. This will install the OCR program.
Scanning
Scanning using USB connection, open the Dell All-In-One Center, click on scanning and copying and scan from there.
Scanning wirelessly, use the scan buttons on the printer.
Mar 04, 2011 | Computers & Internet
Lexmark X4580 (all in one wireless)
HI,
You can try out these two options one by one to fix it up:
A)
1 Unplug the printer.
2. Uninstall the drivers.
3. Reboot the machine.
4. Go to the lexmark site and download the drivers.
5. Install the new drivers.
B)You will get the "CANNOT RETRIEVE APPLICATION LIST" if your pc blocks the communication from the printer. This can be configured in your personal firewall. This can be Windows Firewall (found in Control Panel, Security Center), Symantec Client Firewall or similar. Depending on the configuration of this firewall you might or might not get pop-up messages from the firewall during installation. These pop-ups will allow you to permanently allow for this incoming communication. But your firewall might be set not to let you decide anything which will typically mean that the calls will be blocked out. This will often be the case if you have a company laptop configured by the company IT dept. You might then have to ask an admin to add exceptions the applications used by Lexmark as the configuration might not be open for you to change.
I think this is the complete list of applications:
Job Status Window Interface: C:\WINDOWS\SYSTEM32\SPOOL\DRIVERS\W32X86\3\lxdijswx.exe
Lexmark Communications System: C:\WINDOWS\SYSTEM32\lxdicoms.exe
Lexmark Connect Time Executable: C:\WINDOWS\SYSTEM32\SPOOL\DRIVERS\W32X86\3\lxditime.exe
Lexmark Device Monitor: C:\Program Files\Lexmark 3500-4500 Series\lxdiamon.exe
Lexmark Imaging Studio: C:\Program Files\Lexmark 3500-4500 Series\App4R.exe
Printer Communication System: C:\WINDOWS\SYSTEM32\lxdicfg.exe
Printer Status Window Interface: C:\WINDOWS\SYSTEM32\SPOOL\DRIVERS\W32X86\3\lxdipswx.exe
Goodluck,
Please don't forget to rate the solution.
Apr 17, 2008 | Canon MultiPASS F50 All-In-One InkJet...
When I touch the Scan Menu button, and choose scan to computer I get a message that states: No Scan Options I have been scanning for a year. This happened suddenly and I can't figure out why
Hi
Thanks for using FixYa. Due to any reason when the HP Communications process fails the HP Scan application won’t work. To resolve the issue you’ll need to follow the procedure as given below---
  1. Force Quit HP Communications (if running)
  2. Force Quit HP Scan (if running)
  3. Turn the printer off
  4. Turn the printer on
  5. Select Scan Picture from the HP Director application
  6. When the HP Scan application complains, press Reset
  7. HP Scan will then hang, but HP Communications will restart
  8. Force Quit HP Scan (again)
  9. Select Scan Picture from the HP Director application (again)
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Nov 28, 2009 | HP Office Equipment & Supplies
When i log on, and windows loads i get a logon.exe and it says "this application has failed to start becuase the application configuration is incorrect
Hi, A Virus or Spyware may have caused this and i recommend a Virus scan. Viruses causes Windows files to fail to start. A Virus has probably configured with logon.exe and has stopped it from working. If your Anti-Virus scan does not work then a Virus has stopped your scan from working and then that means that you will have to reinstall Windows.
I really hope this helps and please let me know on how it goes.
Take care
Oct 27, 2009 | Dell Inspiron 6000 Notebook
Nerror rundll32.exe
most likely due to a virus infection scan your computer for viruses with latest virus definition updates
and
use system restore to restore sytem to a previous date when it was working properly
Jul 11, 2009 | Computers & Internet
I just tried to scan with my Lexmark X1270 that worked fine the other day now it says AIOC exe has encountered a problem what has happened t change how it works
You need to update the driver for your printer. Using your install disc, just follow the normal install process which will work as an "Update Driver".
If you do not have your original disc, follow the steps below:
  1. Make sure you have the regular printer driver installed. If you don't, you can grab it from the Lexmark website and install it.
  2. Next, keep your USB cords plugged in but turn your printer off.
  3. Download the All-In-One Center Software here.
  4. Unpack the archive, open the "Applications" folder, and double-click Setup. This will install the application - it can take a bit.
  5. Once the application is installed, turn the printer on and try a test scan. If it works, you're good and can quit reading.
  6. If you get an error when running a test scan, don't panic. Reinstall the regular printer driver, using the "Update Driver" option that appears.
  7. Restart your computer.
  8. Do a new test scan. This should bring up the All In One Center's loading screen, which will start searching for programs (this can reallllly take a while). When it's done, everything will be working beautifully again!
Feb 22, 2009 | Lexmark X1270 All-In-One InkJet Printer
I am unable to do anything on my computer
you got virus, and Trojan on your laptop.
need to go buy a good antivirus software. i.e. symantec, McAfee, etc..........
ask the sales person in the store.
scan the laptop.
Nov 14, 2008 | Toshiba Computers & Internet
Application missing
Generally caused by 2 things
  1. spyware/malware/trojans/viruses
  2. Installed Printer software needs updates.
Download Avastfree and sched a boot time scan.
uninstall/ reinstall printer software.
May 04, 2008 | Dell Inspiron E1505 Notebook
Lexmark 2500 Scanning
my lexmark 2500 scan wont work I get App4r exe problem...
Sep 04, 2007 | Lexmark All-in-One Printer with PictBridge
HP PSC 1350v All-In-One InkJet Printer Logo
159 people viewed this question
Ben Johnson
