I am trying to hook my PC to my HDTV. I both a cable VGA/SVGA cable to do that. I am having problems trying to see my pc screen on the tv, what can I do to make it work.
    Problem Solver:
  • 6 Answers
Check your TV manual to see which EXT to output the signal, use a TV set up wizard such as the one in windows media center or simply right click on the desktop and enter display properties and set up your external monitor.
Posted on Feb 08, 2010
    Guru:
  • 239 Answers
First turn off TV+PC. Then switch on TV only.Press TV/AV on your remote to AV2 or .. Now switch on your PC. It will detect your TV as a new hardware & install the drivers automatically. You can use options from your graphic card later such as dual monitor or clone monitor..
How do i connect my hp2560p to tv
You can use a VGA cable to connect from your laptop to your TV.
10FT 15 PIN BLUE SVGA VGA ADAPTER Monitor Male To Male Cable CORD FOR PC TV
Just make sure you have a connector on your TV....If you only have RCA inputs, you can buy an adapter. just plug it into your laptop and run the Red, White and Yellow to your TV with RCA cables.
VGA SVGA to Video 3 RCA AV TV Out Cable Adapter Converter PC Computer...
Thanks Hope this helps!
Please rate
Gary
Mar 17, 2014 | HP Elitebook 2560p Notebook 12.5" 2.5gI5...
How do I hook up my hp computer to my lg flat screen tv
You can use the TV's VGA port which needs a VGA cable which you can get from a computer hardware store. It's called RGB in on your TV. This is also called PC input.The max resolution you will get is 1,366x768 off your PC.
Jan 25, 2011 | LG 32LG30 32 in. LCD HDTV
My toshiba S300m has a VGA socket and no S cable socket. I want to connect the Tosh. with my TV. Problem is that the TV is an older one and has a S video (female) and it also has three (Yellow, white,...
try to lower your video/screen resolution down to what your older tv can take as an input. (try 800x600 or lower) first if that does not work search on eBay for
VGA SVGA TO S-Video 3 RCA Composite AV TV Out Converter Adapter Cable PC Cord
Jun 04, 2017 | Toshiba Satellite Pro S300M-S2403 Laptop
Samsung LN-T4661F will not display PC; displays 'mode not supported'. Using a VGA cable to connect laptop to tv
Look in the manual for the TV and determine which platform is supported. VGA, XVGA, SVGA etc. Set your computer output to the proper mode and the unit should work. Let me know how you make out.
hardrocko
Jan 31, 2010 | Samsung LN-T4661F 46 in. LCD HDTV
How do I connect my pc the my HDTV via the VGA cable? I have plugged it in and changed the rez on the pc. I want to know how to set the tv to recognise the pc. Regards
i have my pc hooked up to my 42" lcd tv and all i did was run the vga cable from pc to tv and put the tv on pc setting and all works great
Sep 20, 2009 | Samsung HLN437W 43" Rear Projection HDTV
Using a vga cable to hook up my pc to the tv and doesnt work
did you change the imput --use the remote--push imput, change to component
Mar 12, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Connect Macbook Pro to Component input
you should be able to use an SVGA to component rca connector on any component input - i have a wd-65513, and thats how I have my pc hooked up to it. I could also never get a clear picture using the SVGA plug on the back of the set.
Jan 12, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Laptop to TV
I dont believe that you can hook that model up to a TV you have to have a certin video output and it also would depend on your tv as well. But i am about 100% sure that series does not have the output you need you usally can connect via S-cable
Dec 04, 2008 | Dell Inspiron 2200 PC Notebook
Hooking up hp pavillion dv9000 to48'' LG HDTV with vga/svga cable
Any settings for resolution are fine but ideal setting are 1024x768 or 1024x800. To change the resolution just right-click on your desktop background>properties>settings and then use the slider under screen resolution to whatever you want and click on apply then ok
Hope This Helps
Nov 20, 2008 | Computers & Internet
Computers & Internet Logo
108 people viewed this question
David Payne
David Payne
