Question about GE WSM2700D Top Load Stacked Washer / Dryer
I have a GE WSM2700 stackable washer/dryer combo. The washer's main control know when pulled out to start the washer will not rotate to progress through the wash cycle. When you pull it out to start the washer starts up but the know just sits in place and without it rotating to go through the phases it will be in wash cycle forever. What could be the problem and/or how would I go about troubleshooting it? Thanks!
  • 6 Answers
SOURCE: final agitation and spin do not happen, timer does not stop
check your knob and sleve on the timer to see if they are the right ones or if they line up. if they doit might be the pin in side the timer.or it might be faulty. another suggestiion is check everything out twice. good luck
Posted on Feb 11, 2008
  • 1894 Answers
SOURCE: TThe pull-push stop-start knob does
i think the knob is faulty
may be a small misplacement of some some support ring
Posted on Jun 25, 2008
SOURCE: Washing machne problem
The help that you gave me was completely wrong. The support ring was okay. I solved my problem by buying a new timer and control knobs. The teflong 'gears' were worn out so the knobs rotated freely.
Ronald Nelson
Posted on Jul 13, 2008
  • 130 Answers
SOURCE: Broken knob on GE washer
There are four separate parts that make up the knob dial. You can pull off the knob if you use a screwdriver/pliers to remove the clip holding it on. Check if the mounting areas appear stripped or broken. There should also be a compression ring in the mounting hole on the back of the knob. That's what may be broken or stripped. These are all parts that you can get from a local parts store (check the phone book) and you can do it yourself. Any of those parts should cost less than $10. The bad news is if you stripped the pole coming out of the timer assembly. You would need to replace the entire assembly which costs about $130. If you call a GE repairman, you are looking at $89.95 or more just to have them show up. If it is still under warranty, there is no charge. You can call them to verify this:
1-866-383-3933
Posted on May 03, 2009
  • 767 Answers
SOURCE: when wiring the 3 phase plug for power is the
If it is 3 phase it would be sensitive to phase rotation. After hooking up the machine I would check the rotation since it is 3 phase it could be running backwards.
Posted on Jan 14, 2010
I have a stackable Frigidaire washer/dryer combo and the problem is that when you push the start button, you hear an electrical buzzing but the dryer won't start. When you take the panel off it st
Hello Mike Brady - From what you have described it seems like the dryer is experiencing a wiring failure or a communication error with the control board. Contact a professional to move forward accurately.
Jan 08, 2013 | Frigidaire FEX831CS Top Load Stacked...
I have a GE Model WSM2700 WSM2780 Spacemaker Laundry stacked washer/dryer combination which is about 8 years old. It worked perfectly until the dryer no longer would turn on. I opened up the unit and...
i had something similar, did the cleaning and double checked to make sure all the wiring was hooked up and not frayed. i then "jiggled" (technical term) the dryer door button and some sand came out. it has been working ever since.
Apr 14, 2011 | GE WSM2780DWW Unitized Spacemaker Washer...
I have lse7806ace (stackable) and problem with water leak. I live in condo and this washer/dryer stackable in small closet. I can't reach locking tabs. This stackable is also on the pan (bottom). 'BTW,...
Remove the 2 screws which hold the lower front washer panel , lift out from the bottom and remove the panel.You can now run the machine and use a flashlight to see where the leak maybe. Usually the top tub seal under the plastic tub cover will leak. The other possibility is the main tub bearing and seal on the main tub where the transmission goes up through tub. Hope this helps.
Feb 11, 2011 | Maytag LSE7806A Top Load Stacked...
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
I have a GE Washing/dryer Stackable machine combo. The speed maintain normal speed even with the Delicate Clothes option. How to trouble shoot? There is a Siebe Control that is connected to the timer Knob...
The speed change voltages are selected by the timer contacts. Try rotating your timer clockwise rapidly through several revolutions then select a delicate spin cycle and see if the speed is still too fast. If it is then the most likely suspect is the timer itself.
http://www.appliancepartspros.com/part_details.aspx?part_id=2045983
Model number used: WSM2780WAWWW
The timers are the same.
Thanks for using FixYa.
Kelly
Mar 18, 2010 | GE WSM2780W Stacked Washer / Dryer
I WANT TO KNOW IF THE MODEL DVLR223 CAN CONNECT TO 110
THE ONLY DRYER I KNOW THAT CAN CONNECT TO 110 IS A FEW STACKABLE washerr and dryer combo, if its a 220 dryer no you can not connect to 110, it has to be 220,
Feb 19, 2010 | GE DVLR223 Dryers
GE Spacemaker Washer/Dryer wont start only washer or only dryer
Did you figure out a solution to this problem? I just bought a brand new Frigidaire and it is doing the exact same thing, except it never worked properly. I thought it was the unit and had HH Greg bring another out but the 2nd one did the same as the first.
Feb 09, 2010 | GE WSM2700W Unitized Spacemaker Washer and...
Water under stackable washer dryer
The front panel comes off and you will be able to trace the water source. These combo units spin immediatly and if the drain is slow the water will spin up over the edge of the tub during drain.
Eric
Dec 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
Ge spacemaker washer and dry stackable.
if you have a broken belt... remove the back. and the drum support. then you can remove the belt... and replace it with the new one...pull back the pulley and them loosen the belt... let me know
Sep 16, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
GE WSM2700D Top Load Stacked Washer / Dryer Logo
199 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
