Question about Reddy Heater-30-55,000 BTU Variable
Runs for 10min.thenpuffs 3 times,white smoke,thenPOPS BREAKER
Runs for 10min.thenpuffs 3 times,white smoke,then pops breaker
    President:
  • 4,070 Answers
Good day, you may have a problem on the circuitry, might be grounded wires, have it checked. hope this helps, have a nice day
Posted on Feb 08, 2010
My Intex 603M will only run for 5 min or less before it trips it own circuit breaker.?
That unit has a GFCI breaker installed. Those are made to prevent electrocution. IF there is ANY water leakage from the pump into the area that supplies voltage, the breaker will trip. Make sure that there are no damp areas inside the unit and make sure that you have all the wires that it connects to wired correctly and have ground connections.
Jun 24, 2016 | Intex Pool & Spa
Bosh SHY56A Dishwasher - Loud Pop and Smoke While
Hey Matt,
Dishwashers are not that complicated.. Turn off the breaker, pull the machine out - away from the wall..(there will/should be at lest two screws in the top edge holding it to the counter.. remove them first.. then pull it out until you can turn off the water supply.. When you are able to completely remove the washer, you should be able (possibly)to see what happened.. Check to see if the washer arm (inside the washer) will turn, if not.. replace the motor.., check to see if the pump belt will turn?.. it could be the pump drive motor or the pump its self..(remove the belt), then see if the motor will turn, check to see if the pump will turn.
.. White smoke makes me think that the belt was turning and the pump NOT turning..that will cause the belt to smoke.. and smell like burning rubber..If the pump will not turn. you have found t he problem... Also ..Check to make sure there is not a knife or some other object lodged in the drain or pump
NOW -- With all this.. Sometimes REPLACING the machine is actually cheaper than repairing the old one!!! Your wife deserves a NEW one!!
Jun 28, 2017 | Dishwashers
Triing to install intermatic t103 please help. Source is 3 wire 110v want to run 3 blower 110v 9.5 amps each off the t103 timer. Don't have 220v in house just 110v. I need a very simple wiring diagram I...
T103 has 120Volt clock motor, so we can wire this timer.
T103 timer is rated for 30 amps and 2horsepower and your blowers use 28 amps.
So we're getting close to max on the timer. Hopefully blowers won't all be started at one time since motors draw maximum amperage when they start.
However, you need 30 amp breaker and orange 10 gauge wire for that much amperage >> unless only one blower is turned ON at any given time.
Always match wire size, amperage of breaker and amperage of Load or it will trip the breaker.
If you put 30 amp breaker on size 10 wire it is good. But 30 amp breaker on smaller size 14 or 12 gauge wire is fire hazard.
http://waterheatertimer.org/Color-codewire.html
Add a comment at any time, and I will respond
Look at the basics:
You have 2 cables.
One cable comes from breaker box.
Other cable goes to three 120V plugs (120V is same as 110V).
Each cable has black-wire, white-wire and bare-copper-ground-wire.
How to wire the timer.
Timer has 5 terminals: A 1 2 3 4
A) Cable from breaker box:
White wire from breaker connects to terminal A
Black-wire from breaker connects to terminal 1
B) Cable going to 3 plugs
Black wire to plugs connects to terminal 2
White wire to plugs connects to terminal A
Ground wires connect to green ground screw.
Terminals 3 and 4 are not used in this case.
Here is a wiring diagram that shows 120Volt from breaker box and 120Volt going to Load
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
Nov 27, 2010 | Intermatic T103 Indoor 120-Volt 40-amp...
How do i install a 20 amp double pole siemens breaker? i think the one initially installed in my house was put in improperly and it keeps blowing as a result. i have only had the house a few months and i...
It sounds like he was running something at 200 volts using both sides of the breaker, If not, he is definitely using the white wire someplace as the hot and just waiting for somebody to get zapped on it. The breaker could be bad, might be the problem, they do go bad. Just turn off the main, keep away from the big wires feeding the panel, take off your watch and rings, pop out the breaker, pull the wires off, put the wires on the new beaker, pop it back in, turn on the main, if it still breaks, you gotta chase down that white wire, cause something is wrong, I would check whatever it is that it powers to make sure it is right at the receptacle end. It should be marked. Hope this helps.
I just read the properly grounded part, if he is using the ground for the neutral, that is the problem, most newer boxes are polarized, meaning ground and neutral are separate, check out that wire, and see where it goes. If it is running something at 220 volts, mark the wire with black tape, and you should run a neutral to it to be safe.
Jul 04, 2010 | Electrical Supplies
What could cause my RV air conditioner to "pop" the breaker
Even though you don't specify which breaker is popping, I suspect your main breaker is going as you have 3 appliances that can draw a lot of current if they are calling for power all at once. Try running fridge and/or water heater on propane when using AC, to reduce the load. Many parks and trailers are limited to 30 amp service. Those 3 items drawing power at the same time will usually draw more than that. Add use of a microwave, and your really over.
Jun 01, 2010 | Dometic Rooftop RV Air Conditioner
LG Dryer DLE2516W contiuously trips breaker but only on heat setting greater than low
Your circuit breaker may be bad. Run dryer and if breaker gets hot after 10min or so the breaker is bad.
Higher heat settings draw more amperage thus tripping the bad or undersized breaker. 30 amp 2 pole breaker required.
Ck. the power cord for signs of arching. Replace power cord or outlet if damaged.
Jan 04, 2010 | LG DLE2516 Electric Dryer
Hitachi RAS09UH randomly pops 15A circuit breaker
Two things that you could check: 1) If you have access to an ampmeter, determine if the unit is drawing over over 14 or 15 amps, 2) replace the suspect circuit breaker in case it is beginning to go bad. Breakers only trip for overcurrent conditions or failure of the breaker itself. If it is pulling close to 15 amps, then it could heat up over time and trip.
Jul 09, 2009 | Hitachi RAS-09UH Air Conditioner
30 amp 2 pole GE GFCI breaker pops on hot tub after hrs of use
I have seen circuit breakers trip at a lower amperage. It seems that they are weak. Generally circuit breakers run with 80% load with no problem, in your case 24 amps. I would replace the circuit breaker.
Jan 11, 2009 | Spa Parts Plus GFCI, Circuit Breaker, 30...
Bought a monte carlo ceiling fan. removed old fan and found 3 white and 3 black wires, plus grounds. Cannot figure out how to connect the unit up. breaker controls all ceiling lights in master bath,2nd...
Try this:
* All 3 black together, with black and blue from fan
* All 3 white together, with white from fan
* All grounds (earths) together, with all greens from fan
Apr 28, 2008 | Hampton Bay 24002 Ceiling Fan
Reddy Heater-30-55,000 BTU Variable Logo
89 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
