Question about Lakewood Oil-Filled Electric Radiator Heater
Heater stopped working
I have had this Lakewood heater for a number of years. Recently it just stopped heating eventhough I had not turned it off or adjusted the setting. How can I determine what has stopped working?
Thank you.
  • 12,061 Answers
Use a multimeter set to Ohms, then check for continuity from the Phase to the switch, then to the Thermal fuse, < thats a good candidate for replacement, it should read a "Short" across it, OPEN circuit means it has failed. then from Thermal fuse, if OK, to Element(s), these should have resistance of about 12 - 15 Ohms...from one side to the neutral. When ON, there should be a Resistance reading on the Meter, of up to 20 Ohms measured across the 3 pin plug.would be OK.
Essentially with Neutral, as common, the Phase comes in to one side of a switch, the "Other" side of the switch goes to the Thermal Fuse, the "Other" side of that Fuse, goes to the "Hot" side of the Element. and the "Other" "Cold" side goes to Neutral, common. So essentially with the switch in the ON position, we should get a resistance reading on our meter. The reading is in accordance with Ohms law. IE: To get the resistance of an appliance, we take the Wattage, & divide it by the Voltage, Taking the answer from that, we then, divide the Voltage by that result, and we have our resistance. EG: 1000 Watts, divided by 112Volts = 8.9Amps. Therefore 112Volts divided by 8.9 = 12.4 Ohms. That is your resistance or Load. Hope this helps.
Posted on Feb 08, 2010
Our Lakewood 5101 oil heater gets warm, but over the last few days, it is not getting hot like it used to. It seems like it has slowly been getting colder over the last week or so. I can feel the heat...
Appears you have a heating element issue. Many of these elements are segmented for temp control. If one part goes fubar the heater will work but not put out the heat it used to unless you replace the element with a new one that has no burnt out sections.
May 03, 2017 | Lakewood 5101 Oil Filled Radiator Heater
Want to buy a new heater' the lakewood is the best on the market i own one for 20 years and it just broke would like to buy another one need how to contact your store telephone number address and most...
Hello Teresa,
I am sorry to inform you but Lakewood heater company filled bankrutcy in 2009 and no longer is in bussiness. However, I have found a website that still has Lakewood patio heaters in many different styles that you may want to take a look at, the follow is a link to that site http://www.heater-home.com/category/lakewood.aspx
Thank you for choosing FixYa.com
Justin
Mar 09, 2011 | Lakewood QT1 Patio Heater
Lakewood radiator heater model number 5101. The heater just stopped working all of a sudden. The buttons still light up when switched on but there is no heating. please help as I dont have any other...
Sounds as if the element is burnt out or the tstat is broken. the tstat is the more common as they use very cheap ones. Unfortunately you can't get these. My suggestion is to buy a new one.
Jan 27, 2011 | Lakewood Oil-Filled Electric Radiator...
Model 707 Lakewood portable heater stopped working
I don't know how to make your heater work again, but I do know (from long experience with Lakewood 707s) that the setting knobs often fail to function properly even if the heating element still works. My solution is to plug the heater into an adapter with an on/off switch on it and use that to control the power. I leave the setting knobs on the heater itself in the position where I usually use them (max heat). These are excellent heaters except for the knob problem.
Apr 06, 2010 | Lakewood LAK707 Utility Heater
Lakewood heater 792 will not work
The bottom switch is bad. Unplug bottom wires and touch them together, if heat and fan comes on your switch is bad.
Feb 11, 2010 | Lakewood 792/JR Utility Heater
LAKEWOOD HEATER DOESENT HEAT UP
take it apart they should be aglass fuse inside
Dec 24, 2009 | Lakewood 792/JR Utility Heater
Lakewood oil-filled heater not heating up
It is quite possibly the thermostat. Dont risk your health these heaters are not very expensive and I would suggest going to buy a new one from your local department store.
Feb 02, 2008 | Lakewood Oil-Filled Electric Radiator...
Model 7096 heater
http://www.ul.com/media/newsrel/nr041405.html
Concerning Lakewood Model #7096
RECALL
May cause electric shock!
Nov 20, 2007 | Lakewood Oil-Filled Electric Radiator...
Lakewood 792/JR heater running w/o heat
Hi Spybotics. I have the same problem and I traced mine down to a burned out over-heat fuse link. Check out my recent post. My guess is that you are having the same problem as me. It's not hard to tell - just take off the rear panel and test the link (looks like a small resistor in line with the element) with an ohm meter. Open circuit means burned out fuse link. DO NOT bypass the link, as an extreme fire hazard will exist without it.
Apr 14, 2007 | Lakewood 792/JR Utility Heater
Lakewood Oil-Filled Electric Radiator Heater Logo
420 people viewed this question
Top Lakewood Heating & Cooling Experts
Mack Baxter
Paul Carew
jdthefixer
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
