I don't suppose there is any way to repair(glue) a 1/2 tear on the lip of a door gasket on a front loader
  • Washing Mach... Master
  • 19,396 Answers
Hi.
Repairing the old gasket will not work, as after a while the seal will rip again. The seal can be replaced.
the part is available online, with diagrams and replacement instructions.
Here sellers, enter model number as listed on the appliance service tag:
Appliance Parts Pros
Parts & Accessories
Appliance Parts -Research, Repair & Replace.
Posted on Feb 08, 2010
Water leaks apparently from a tear in the circular seal next to the door
This video will show you how to change a door seal on this Bosch front loader washing machine
we have all bosch repairs in our channel
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 17, 2011 | Bosch WAS20160UC Front Load Washer
My front load ge washer model GCVH6260F is leaking past the front door. I have examined the seal and it looks fine. Any suggestions.
the bellow or gasket may need to be replaced. this is a common problem with front loaders as the bellow can be pierced by anything that may be in or even on your clothes. I would visually inspect every inch of the front bellow to see if there is a TEAR or PIN HOLE.
New bellows $150 plus fitting so I use a Bike repair it and used the glue to glue a piece of bicycle tube to the inside of the seal to cover the chip by 1 cm either side and trimmed to the same height as the seal lip.
I then placed a little bathroom sanitized silicon sealant over the repair within the chip, wet down with soapy water on the door glass in the chip area and shut the door. Carefully wipe of any excess with wet finger and repeat. Open the door and let it all cure.
Aug 29, 2010 | GE WSXH208A Front Load Washer
FRONT DOOR SEAL LEAKING
Jun 22, 2010 | Maytag MAH8700AWM Neptune Front Load...
Leaking door seal
May 19, 2010 | Frigidaire Affinity ATF7000E Front Load...
Leaking water at the front by door
May 17, 2010 | Hotpoint Aquarius WF210 Front Load Washer
Washer is leaking water beteen door and seal
Apr 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How does front panel come off (safely) to swap out door switch on kenmore washing machine 41744152400
The front panel does not need to be removed when replacing the door switch. What needs to be removed is the door gasket. Open the washer door. Get a pair of needle nose pliers then look for the retaining hoop securing the door gasket to the lip of the door opening. Stretch the hoop retaining spring at the bottom of the lip of the door opening then carefully pull the hoop out. Make sure not to tear the door gasket or else water will leak through it.
Remove the two screws securing the door switch to the front panel. Peel off the door gasket near the door switch then pull the door switch off the front panel and out of the washer.
Disconnect the wires from the door switch terminals then connect it to the new door switch. Secure the new door switch back to the front panel then put the door gasket back over the lip of the door opening. Properly secure the door gasket to the lip of the door opening with the retaining hoop.
Mar 11, 2010 | Frigidaire ATF6000ES Front Load Washer
When you run a wash there is some water on the tile floor. I found the rubber gasket inside the door is torn.
If the tear is small, try using silicon glue to repair it--clean the surface of the boot and apply the glue. Let dry for 24 hours before using the machine. If the tear is large, the boot must be replaced. It can be done from the front without removing the cabinet, but it's tricky. These tears usually occur when trying to remove jeans and a metal button catches the rubber.
Feb 13, 2010 | GE Energy Star WCVH6260F Front Load Washer
How to change door rubber on miele premier 300, can the front of machine be opened allowing to change the door rubber
I'm assuming you mean the flexible rubber between the door and the drum. Can it be replaced? The short answer is no! However...
I recently repaired a door rubber with a tear that caused the water to flood onto the floor. Here's how:
Yes, you can open the front to get to the door rubber however the rubber seal is glued to both the door and the inner drum lip.
You may have to tilt the machine on it's back to remove three screws from the underside of the front lip. (I forget if you need to take the water pump cover out as well but it wouldn't hurt to do so.) This allows the front panel (including door) to drop down a quarter inch or so and be eased out a little.
This allows *better* access to the drum rubber. To repair a tear - really the only reason you would want to do this - you need glue and some tape.
The door rubber is silicone and will stick with normal 'super glue'. However, bear in mind that these machines can do a wash up to 95C, which is hot enough to soften superglue.
I found a new version of superglue called Repair Extreme by Pattex that copes with temperatures up to 120C. It sets in about 5 minutes.
The glue needs to be flexible. Do not use epoxy resin.
I gave the glue some form by sticking a 10-15cm piece of duct tape - the silver shiny plastic tape plumbers use, readily available from any hardware and most supermarkets - to the *back* of the drum rubber. It's a tight squeeze to get your hands in there but it can be done.
Take the tension off the drum rubber by moving the front panel roughly back in place.
Then squeeze a generous amount of glue along the tear (about 3cm long on the bottom edge; a typical problem) to completely whet the edges to be joined.
Apply a little pressure to the location of the tear for a few minutes to help the glue hold fast. Leave the glue to set for at least half an hour before reassembly.
If you can source a replacement drum rubber the old one can basically be removed by force. A good cleaning and then a suitable glue could stick a new unit in place. However, if this is required, seriously consider buying a new unit. It is difficult to make a good seal that will not leak and may not be worth the effort in the first place.
Feb 03, 2010 | Miele 300 Front Load Washer
Water leaking in front of washer mainly from what seems to be the gasket around front of washer.
Either the rubber boot is damaged in some way, or the door is not locking tight enough. Thoroughly inspect the boot for tears or gouges in the rubber surface. Small imperfections can be repaired with silicon glue, but larger tears will require replacement of the boot--which can be done done through the door opening, but requires patience to do so. Inspect the door lock for damage or wear if the boot looks to be in good condition.
Oct 12, 2009 | LG WM2277H Front Load Washer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
