Question about ASUS P4VP-MX Motherboard
Can't locate hd led on the board
On my board I can't seem to locate where to connect the hard drive led can you help ? thanks
    President:
  • 2,351 Answers
Click the link below & download your manual. You'll have to fill in the three windows to get to your board.
Motherboard
Socket478
P4VP-MX Click search. Than open the + sign for manual.
http://support.asus.com/download/download.aspx?SLanguage=en-us
Go to Pg.1-22 section
11. System panel connector (10-1 pin Panel 1)
See the diagram at the top of the page.
You might need a flashlight if the board is in the case!
please vote...
Posted on Feb 23, 2008
Hi, I'm facing following problem, can any one help me please? Seagte external hard disk GoFlex Desk 1TB (STAC1000300) with USB 3 adapter STAE 106 is not working. When the USB 3 cable is connected to...
just install seagate free agent using this link
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=goflex-software&vgnextoid=11c1fab114b48210VgnVCM1000001a48090aRCRD
then try again if problem not solved, mail me to tsnp@ymail.com
Apr 19, 2011 | Seagate FreeAgent GoFlex Desk Desktop...
How do i store movies?
just copy an paste at your hard drive
Dec 03, 2010 | Seagate 500GB USB 20 5400RPM Portable 500...
I connect my hard drive with another computer when other computer is running when i connect with them one ic is burn on ciricut board and get burn smell from hard drive. Plz help me in this regards.
if you plugged or unplugged a HD to a computer when the computer is running, you have quite probably fried the HD *unless it's an EXTERNAL HD with a USB connection, which could be more resistant to this type of abuse).
I suggest you download SeaTools from Seagate and check the HD, but I think it;s pretty sure to say that it's gone
Mar 23, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Where does the pwr sw plug go to on the motherboard
There is no way to tell you exactly where it goes without knowing the make and model of the motherboard. However all motherboard label the connection point on the board itself. What you are looking for is usually located in the lower right hand corner of the board and in most cases it will be labeled "F_PANEL" for front panel. There will be one or two rows of metal prongs if there are other items located on the front such as LED's or a reset switch simply follow the wires because all the front panel displays and switches are located in the same place.. These prongs will be grouped in 2s 3s and 4s.
The tricky part is reading the small print located near the prongs. They will be abbreviated such as +PW-(power switch), +RES- (reset switch), +PWR LED- (power led indicator), +HD- (hard drive activity indicator).
The + and - don't really apply to the power switch so you don't have to worry about that.
Hope this helps. Please let me know if you need any other info or are just unclear about anything.
Oct 15, 2009 | Gateway DX4200-09 PC Desktop
500GB FW400 Porsche drive Appears to power on (LED lights) makes soft noise but no HD spin. Opened drive and seems that everything is seated properly.
their can be a issue with the drives controller board. when a controller board fails their will be no s.m.a.r.t information reported back to the system. S.M.A.R.T is used to check the temperature disks spindle speed as well as specific parameters set bu the disk manufacturer. if smart fails then the controller is probably bad. google check hard disk s.m.a.r.t for info on checking the drives states. and good luck.
Oct 01, 2009 | Computers & Internet
Hello, My PC suddenly stopped running. Thought it was the power supply, so just purchased a new one and connected it. LED on board in on, the CPU fan kicks and stops after a couple of seconds and PC...
could be a bad motherboard or bad processor. have had both in the shop several times. only way to troubleshoot is with a known good replacment for either.
Jul 13, 2009 | Computers & Internet
Is they a connection to fit a sata hard drive to my motherboard ga-8s650gxm thank you
I guess you have an ide/ata motherboard. There are pci converter boards to connect internal sata
hd's and adapters to use sata hd's externally via
usb.
Jul 03, 2009 | Computers & Internet
How to connect the front panel sould device?
Do you mean speaker or front panel audio? The front panel audio connector is located at the rear of the board, behind the PCI connectors - the speaker connections are in the panel connector block (2x10 pin header) located at the front left of the board.
With the board in it's normal position, the speaker pins are on the right hand side of that block, on the pin nearest the front and the one 3 positions behind that
<back of board>
| HD LED + | | Power LED +
| HD LED - | |
| | | Power LED -
| Power SW | |
| Power SW | | Speaker
| Reset SW | |
| Reset SW | | Speaker
Front of board
Jul 03, 2009 | ASUS K8V-MX Motherboard
How to connect front pannel
How about a picture? Pg. 46 in your manual.
Need manual, download from Intel. (Click on link).
http://www.intel.com/support/motherboards/desktop/RC440BX/sb/CS-013608.htm
Intel RC440BX Specification
Pg. 46
Basic rules case wiring. The color black is considered ground -. Power wires + can be any other color including stripped wires. (This is standard but case Mfg change to their own specification).
Pin 1 is + power for LED Hard drive green LED, Pin 2 is -/ground for Hard drive LED.
(Pin 3 is + power for LED Hard drive yellow LED, Pin 4 is -/ground for Hard drive LED).(See more options on pg. 47).
Pin 5 is + power for case On/off button, Pin 6 is -/ground On/off button.
Pin 7 is + power for Reset Switch, Pin 8 is -/ground for Reset Switch.
Once positive & negative pins has been located each connector follows in suit.
The Intel RC440BX front case connector is in an odd location.
The user will find it hard to connect front case LED connectors while the board in installed into the case.
Good Luck!
Mike
Apr 25, 2008 | Intel Desktop Board RC440BX...
Asus a8v fail
does the power supply fan run when switched on.
does the hard drive spin up .
Have you reseated the video card.
Jan 26, 2008 | ASUS A8V Deluxe Motherboard
ASUS P4VP-MX Motherboard Logo
93 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
