Question about Vizio L32 32 in. LCD HDTV
Vizio L32 Issue: Vizio replaced our 9 month old 32" last week due to a 'failed' repair for an annoying humming. The new tv has the same annoying humming. What should I do? I really don't want another one from Vizio as I think this is a design issue they need to fix.
  • ranchwood Feb 09, 2010
    To Anthony1967: Should I request a refund from the seller (Walmart) or from Vizio since it is still under factory warranty? Note: My extended warranty with Walmart takes effect is about 5 weeks. Should I wait and deal with Walmart on the issue? Thank you!
    Sergeant:
  • 226 Answers
It is still under warranty then you could ask for your money back as replacing it has made no difference.
You will have to search the internet for more advice on this.
Regards - Anthony
Posted on Feb 08, 2010
  • Anthony Feb 09, 2010
    Hi, I'm not sure on American laws, but over in the UK, if it is still under the normal warrant you need to get in touch with whome you bought it from. I live Close to Asda ( Walmart ) and I have bought from them a few electrical items in the past as in a dvd player and 19"lcd and they have gladly changed the item for the same one or a different one. I have bought routers ,where they have failed , I have returned them and they have given me my money back. Asda are normally pretty good that way, but I can't guarantee it with yourself.
    Go Back to Walmart and explain to them, I'm sure they will help you out. I bought an LCD from Tescos and it was the worst tv I have seen, it suffered so badly of motion blur, that I took it back.
    I really don't think you have anything to worry about, other than choosing a differen set.
    How Much did you pay for the Vizio? It might be worth sticking to a well known brand, but then again I had an LG42pg6900 that lasted about 5 months and none of the engineers that came round could successfully repair it, in the end they gave me my money back and I purchaced a panasonic which has been brilliant - so far!
    Good luck on the exchange and let me know how you get on.
    Regards - Anthony
I am having an issue with my rgb connection, it was working one night the next it says no signal.. what could be causing this? the tv is only 6 months old the cables are brand new as well..
Tries take out and plug in RGB cable back in/out for a couple times,should solved this connections problems mishap.Dose not solved the problems.Return the tv set and get a new tv replacement tv have cold soldering in RGB joints connections somewhere.
Aug 20, 2011 | Vizio L32 32 in. LCD HDTV
Hey there, I have a 6 month old vizio 32" LCD 60hz
LCD inverter module may have encountered a failure. Most common is an electrolytic capacitor failing in the power supply. Examine the board to see if any of the caps have a bloated or raised top, they should not be swollen or leaky. If so find the replacement capacitor # on line and replace. You will require a modicum of soldering skills. You indicate the tv is 6 months old.
Return it for warranty service, do not open your tv or you will void your consumer warranty.
Mar 26, 2011 | Vizio L32 32 in. LCD HDTV
Vizio L32 stopped working.
I have seen this many times. The tv most likely has run its course. It could be the power supply or a lamp. Sounds more like a lamp, as you still have lights on your set. check around and get some prices on a lamp. you can have a local shop install it for you. or just replace the set.
May 03, 2010 | Vizio L32 32 in. LCD HDTV
Vizio 32" Plasma Freezes up
A lot of picture freezing issues are signal based. Check the signal strength and quality.
Jul 24, 2017 | Vizio L32 32 in. LCD HDTV
Wavy red lines or red pixelation, not sure what it is
Go to Vizio website and buy the extending warranty, you need to have your TV replaced since the problem is with the screen itself.
Dec 15, 2008 | Vizio L32 32 in. LCD HDTV
Vizio L32 HDTV - Blew Out, No Power
Yes, I do in home warranty work on vizeo, it sounds like you need a power board and perhaps a main board. The power board is what pooped.
I’m happy to assist further over the phone at https://www.6ya.com/expert/lou_afa492c634393790
Nov 13, 2008 | Vizio L32 32 in. LCD HDTV
Vizio L32 HDTV 10A - Won't Turn On
Bad capacitors in the power supply. Open it up and look for swollen electrolytics.
Sep 22, 2008 | Vizio L32 32 in. LCD HDTV
Vizio L32 32 in. HDTV LCD HDMI input not working
I recently had the same problem with my vizeo hdmi port # 1 going bad. Tried everything to fix and called vizeo. There solution for a master reset was turn off tv and unplug from the wall. then hold down the power button for 30 secs and let go. plug the tv back in and hold down the volume down and input select buttons down on side of the tv for 15 secs. release the buttons and turn the tv on after powering down all the components connectd to the tv. If this does not work they told me you need to have it sericed for a bad hdmi input. Hope this info helps anyone out there. It didn't work for me. Its a bummer cause the tv is well taken care of and only 18 months old. Best of luck to all others.
May 14, 2008 | Vizio L32 32 in. LCD HDTV
Vizio L32 32 in. LCD HDTV Logo
454 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
