Question about Mitsubishi WD-52631 52" Projection HDTV
Wd52631 will work for awhile and then it goes blue. Sometimes it will come back but most of the time I have to turn it off and let it cool down and the picture will come back. R
  • Chaz theSpaz Feb 09, 2010
    No error messages the screen just goes blue. If it does not come back in awhile the TV says that it is going to shut off because it is not receiving a signal but yet the receiver still shows the HDMI signal and we are hearing the sound coming out of the receiver. R
    Vents are clear air is circulating. I even keep a small auxilary fan behind the tv and the cabinet is well ventilated. I replaced the lamp 6-20-08.
  • 1,476 Answers
This is a DLP tv so the reason it would lose its picture is because it lost video drive to the display mechnism. That would be on the video board. You probably are not going to be able to find it and a tech would just replace the board. If you are not familiar with electronics you probably should get a reputable shop to fix your unit. It should not be more than several hundred dollars. Let me know how you make out.
hardrocko
Posted on Feb 10, 2010
  • 212 Answers
This, unfortunately, is a fairly common problem with this TV. Fortunately it shouldn't be too expensive.
As you say, it's ok when cooled down, and therein lies your problem.
Check that the fan is working first of all. This fan draws in cool air and the warm air is expelled from the vents (you should be able to feel warm air coming from one of the vents). These vents need to be clear of dust. If they are blocked, you need to clear them with air. Do not use a hoover as they can build up static and zap your tv components.
These tvs don't like being in cabinets by the way, as they can't get enough cool air and often **** in the warm air they've just expelled.
If none of this helps, then it's likely you have a defective thermistor, which is reasonably easy to replace and shouldn't cost too much; certainly cheaper that a new tv set!
Regards
Zahc
Posted on Feb 09, 2010
  • 566 Answers
Hi chaz
I have a question for you;
Before it shuts down, does it display any messages?
Posted on Feb 08, 2010
Shows incorrect depth suddenly and Erratic displays
MY XD510c works fine then flashes 2.5 and fills the screen with black red blue white vertical lines...then after an amount of variable amount of time goes back to working for awhile
Jun 23, 2010 | Lowrance X510c 5" Screen Color 200 Khz...
Is the fan suppose to keep going off and on after the vehicle has been turned off awhile it goes off then comes back on
Yes it has a temperature sensor and through convection of the hot water moving to the top of the cooling system as it cools off, the sensor is seeing the temp rise and turns the fan on to cool it back down
Sep 02, 2009 | Jeep Grand Cherokee Cars & Trucks
Tv pictures suddenly goes dark blue
the tube could be going out. Do you have a warranty on that?
Nov 01, 2008 | Televison & Video
Set turns off randomly
there is a capacitor right behind hori output transistor it most of the time goes bad 1200pf 2k volts,yours could be on its way out,when it does set will not come back on.
Jan 09, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
KAC-8401 Shuts off Blue light still lit
HI RLF,
You might want to turn your Gain setting down a little. Also Look to be sure you have enough air flow around the amp. If it cannot breath, the heat from the amp will build until it wigs out. Use your Ingenuity to get more air to the AMp.
Nov 05, 2007 | Kenwood KAC-8401 Car Audio Amplifier
Mitsubishi WD-52631 52" Projection HDTV Logo
78 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
