Question about HP Officejet 5510 All-In-One Thermal Printer
HP 5510 Faxing problem
I have had a HP 5510 Officejet all in one for some time now and i have had no problems with it at all.
Until now.
I am after this long only now looking to send / receive faxes. I have connected the telephone cable into Lin 1 and the machine see's that my other DECT phone in the house in being used and also links to Fax mode if i have incoming faxes but after that nothing. It does not even attempt to print and if i try to send a fax it dials but haas no attempt at sending.
I need help
Thanks Jeremy
  • 4 more comments
  • Laheta May 19, 2008
    i could not send the fax after i dail no and i do not get the dial tone foe fax..
    i could no get the fax tone while faxing the page.
  • hale18 May 21, 2008
    My machine will not receive a fax. Phone rings but it will not receive the fax. I can fax out but can not receive fax. HELP_____Help
  • Anonymous Jun 13, 2008
    I HAVE LOST THE CD TO INSTALLE IT IN MY CPMPUTER . IS THERE ANY WAY I COULD GET IT FROM THE WEB.
  • fayster Jun 24, 2008
    Help, I can send faxes but can't receive them. I have a distintive ring on my phone so I know its a fax, but it just rings, and rings. does not p/u fax
  • Anonymous Jun 28, 2008
    i can write a fax but they dont recive the fax when i try to send it.
    Guru:
  • 1,463 Answers
Hello jeremy
some guides and help from there site here see if this will help you .
riz.
Posted on May 15, 2008
Error message printhead missing HP photosmart 5510
This indicates that your head is not correctly installed.
Clean the contact surface with a tissue paper then try to insert it until it snaps in place. On hp printers the ink cartridge is the print head.
hope it helps
Nov 05, 2011 | HP Officejet 5510 All-In-One Thermal...
HP OfficeJet 5510 All-in-One print slowly -
Hi
you need to replace your cartridges
one of it will stop printing and a message will come in
you monitor "cartridge error" and it must be replaced
In case I had help you pls vote me
Nov 06, 2010 | HP Officejet 5510 All-In-One Thermal...
Printer # 5510 - How do I open to replace ink cartridge?
If you mean HP OfficeJet 5510 then the following tutorial is for you:
HP OfficeJet 5510 Replace Ink Cartridges
If you do NOT mean HP OfficeJet 5510, please do not fail my solution. Instead, start a new thread with your make, model clearly defined.
Jan 13, 2010 | Office Equipment & Supplies
Where is the sensor located on an OfficeJet 5510?
Hi I suppose its would not be advisable for you to remove the sensor unless you know about the printer status. Please give it to a service provider who can diagnose and replace the sensor, Mostly sensors are basically for paper trays to pick up and print the printouts
Jan 05, 2009 | HP Officejet 5510 All-In-One Thermal...
Paper jam hp 5510
Look in the rear of the machine for an access door.
Jan 04, 2009 | HP Officejet 5510 All-In-One Thermal...
Faxing
all three lights on , and cannot send or receive a fax?
Aug 30, 2008 | HP Officejet 5510 All-In-One Thermal...
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
  5. Close the print-carriage access door.
Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
Printer installation
ok how is the computer hook to printer ,
(usb? or serial cord) ?
what operating system are you using
and what software are you using for print drivers
let me know and i can help you in greater detail but here is a link to hp for your printer
i hope this is somewhat helpful
feel free to reply back if you cant get it working im shure i can help
http://h10061.www1.hp.com/ccsearch/search?pname=HP+Officejet+5510+All-in-One&opname=HP+Officejet+5510+All-in-One&qry=I+am+having+trouble+with+the+computer+recognizing+the+HP+Officejet+5510.++What+can+I+do%3F&method=prodFinder&ctry=us&lang=en&dlc=en&sni=311255&search=0&submit.x=0&submit.y=0
Oct 31, 2007 | HP Officejet 5510 All-In-One Thermal...
HP Officejet 5510 All-In-One Thermal Printer Logo
220 people viewed this question
Seeker5211
Seeker5211
