i have a sony xe-mk90II 9 band eq. i do not know what pins are for what wires. i do not have the harness for it and am making one. does any one know what pins are ground power and remote? also, the buttons for choosing what freq and sub on or off fell off and the clear plastic inserts that make the button rock are missing. where can i get extras?
i just got the wiring for the sony xe-mk90II eq, heres a picture :
top right is the ground , bottom right is constant power, blue is the remote turn on. if you have a old wire harness around you can pull out the blue ,yellow, and black wires with the metal clip on and make than fit right where the wires should go. but make sure u rap the metal clips with electrical tape so the wires dont touch or you will fry it.
Comments:
Sep 27, 2008
- ps.. the blue wire goes in the middle on the bottom row.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Aug 25, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i was told three pins left to right are constant hot yellow with 1 amp fuse, black ground, and blue control
I am building an exerciser for a brake control module. I need the schematic for the Delpi ABS module...
(More)
I am building an exerciser for a brake control module. I need the schematic for the Delpi ABS module for a 2002 Corvette
I have a eq 6500 pioneer but nothave the the power supply conector, only can see the pines in the...
(More)
I have a eq 6500 pioneer but nothave the the power supply conector, only can see the pines in the componet. apreciate any help thanks you .
Good Day Everyone, I am in the trailer manufacturing business and I have a request to wire up some...
(More)
Good Day Everyone, I am in the trailer manufacturing business and I have a request to wire up some trailers for 12 & 24v trucks. The lights that I am using are 2'' Round for Clearance and 6'' Oblong for Brake/Signal in the rear. It's all LED and I found 2'' Round that can handle 12 & 24v but I can't seem to find any 6'' Oblong. What would happen if I just put strictly 24v in there??? Then, if it was hooked up to a 12v system the light output just wouldn't be as great, correct? By the way these trailers are just for 1/2-1 ton trucks. Thanks
