Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
It is no longer sucking up the water
It is no longer sucking up water
    Problem Solver:
  • 6 Answers
Make sure the cartridge is in where you use the attatchments...i had the same probleb..that was why .its a sqare plasti thingy,it must be in the shampooer to **** up water..hope this fixes ur prob..
Posted on Feb 08, 2010
My son accidentally sucked up some water with my dyson animal and now it has stopped working. Is this permanent or will it come back ?
It depends how much water and how long the motor was run after sucking up water. If it was just a little water, most of the water should have been caught in the dust compartment. If there was enough water that it was able to suck it past the filter and into the motor it could cause motor failure.
Nov 30, 2016 | Dyson Vacuums
Will not **** the dirty water back in.
check for clogs in hoses and head.mine gets clogged up all the time.
Jun 06, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Hoover carpet cleaner blowing not sucking
While the blower has different source that the sucking of water, the passage for the sucking of water needs to be cleaned to eliminate any blockage within the passage.
Apr 12, 2010 | Hoover SteamVac F5914-900 SpinScrub...
My Bissell is no longer sucking up water when shampooing my carpet.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
hjdgh
Feb 27, 2010 | Bissell 1699 ProHeat Clear View Upright...
My bissell proheat is not sucking up water, the solution comes out but when I went to empty the water holder I only had about one fourth of the water that I had in their and the carpets feel very wet.
this is easy. remove the plastic top that snaps to the part that holds the water bladder. Instide that top piece is a red door... and behind that flapping door is an air filter.... remove all the crud stuck to it and you should be good to go. No tools required, my finger nail did the trick. Once the air flow is no longer restricted the machine is back to sucking as usual.... and that's a good tihing
Nov 11, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
My bissell flip it no longer sucks up water i think the ruber seal ha perished
check for clog first. if the rubber gasket is still there then it shouldbe fine. the small area can get clogged easily where the water travels through the nozzel. clean that really well and make sure there are no clogs in it. if i still is not sucing up wet stuff check and see if it sucks up dry. if it dosnt **** up dry either you can try and clean the filter and get all the debre out of that. if none of those fixes the problem chancs are the hepa filter needs replaced
Nov 30, 2008 | Bissell Vacuums
Carpet shampooer
hi, I used to sell these, and can tell you that they are not designed to suck up the water. They are made to put a limited amount down and then the brushroll scrubs it. Then it drys and ideally you would vacuum up the dried residue that is left. I own one myself, and admittedly the shampooer is not as good as the ones that steam clean and suck it up, but it does ok. The longer you sit in one area, the more water is going to go down, so keep it moving. And remember that it is going mostly at the middle of the unit, so it's good to overlap a bit. If you have troubled stains, I can suggest spraying some type of cleaner on it and going over it with the brushroll--like windex. My buddy also used to sell them, and that worked for him.
Sep 02, 2007 | Kirby Heritage II Vacuum
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
368 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
