Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
The cycle doesn't advance prior to the rinse cycle, unless I bang the lid down. Sometimes takes a few trys then it starts up again and finishes out the cycle. Is my timer going out? Is this an expensive fix?? Should we think about getting a new washer? It is approx. Ten or Eleven years old.
    Problem Solver:
  • 7 Answers
Look on the lid. see where the prong is.
look on the washer where the prong goes. try to clean that spot, lots of times it's got a build up of lint . the initial wash cycle will moisten the build up preventing it to function properly.
Posted on Feb 09, 2010
Mommy20255 is spot on to the solution. The prong/latch assembly in my machine is broken. As it is wired into the machine, I will have to call a repairman, but she led me straight to the problem. (The picture is of the broken unit taken upside down.)The cycle doesn't advance prior to the rinse - 95f4aba.jpg
Posted on Feb 10, 2010
Top loader washing machine stops mid cycle and won't finish rinsing or spin cycle. Any ideas?
Check the lid closure switch. This keeps the unit from spinning if the top lid is open, as a safety interlock. The switch gets a lot of abuse, as the lid sometimes slams down and damages the switch. If the switch is damaged, the washer will stop before the final rinse, or spin, depending upon the model. This can be repaired, but takes a bit of work. I did mine myself, with great results. If you are not inclined in that direction, have it repaired. It costs far less than a new washer.
May 10, 2017 | Washing Machines
What's wrong with washer that won't start again?
Check the door safety switch. Sometimes you can rock the lid left and right and close it back it might clear what's blocking the switch. Make sure you have the washer on.
Dec 20, 2017 | Roper Washing Machines
Washer stops before rinse cycle
Check the water level sensor.
Nov 25, 2013 | Maytag Washing Machines
My Kenmore washer is not draining or rinsing
Check the lid down safety switch. On the lid there is a small spike that goes through a hole when the lid is down.
Under the hole is a switch that allows the timer to advance and the washer to spin only when the lid is down. Two screws hold the switch in place and the plastic switch will sometimes break and be hanging by the wires.
In other words, it is the timer. That is stopping the advance. You may have to replace the timer.
How to replace the timer in Kenmore top load washer
Aug 27, 2017 | Kenmore Washing Machines
Kenmore washing machine model 110 wash cycle stops
DOES IT DO THIS ON EVERY WASH OR SOMETIMES? IF SOMETIMES, CHECK LID SWITCH( THERE'S A LITTLE HOLE WHEN YOU OPEN THE LID, ON THE LID SHOULD HAVE A LITTLE PLASTIC PIECE THAT GOES IN THAT HOLE. THE SWITCH IS UNDER, INSIDE THAT HOLE. YOU CAN GET A PEN OR KEY TO SEE IF IT'S BROKEN.)
BOYNISMO@YAHOO.COM
Aug 21, 2009 | Kenmore Washing Machines
Maytag SAV5910aww will not always drain. Fills and agitates fine but will go through entire cycle without draining. Will sometimes give end of cycle buzz sometimes not. If I am in the room and lift the lid...
"I have found spinning the timer back to begining of rinse cycle first helps". The timer only rotates clockwise; counterclockwise rotation can destroy it.
May 18, 2017 | Maytag SAV5910 Top Load Washer
Washer Doesn't move from cycle to cycle
this washer has a problem with the lid hinge screws coming loose. check the left hand hinge and you will find the screws loose.
this cause the lid switch to not engage and then nothing will happen until it thinks the lid is closed.
try to tighten the screws and listen to see if the switch "clicks" when you open and close the lid.
that should fix it until the screws come loose again.
Jan 30, 2009 | Whirlpool LSR6334LQ Top Load Washer
Kenmore 80 series washer wont rinse/spin
I fixed the same problem by using this site: http://forum.doityourself.com/archive/index.php/t-156215.html
Mar 17, 2008 | Washing Machines
Kenmore 80 series heavy duty super capacity plus
Check the lid switch when you lower the lid you should hear a small clicking sound.
Sep 22, 2007 | Kenmore 22422 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
101 people viewed this question
Dan Webster
Dan Webster
Sal De
