Question about Canon imageRUNNER 2270 Copier
My Canon ImageRunner 2270 has a continuous paper jam in right panel door. Seems like the cartridge in the door jams the paper as it sends through the printer at lower bottom. What can I try to reslove this issue?
  • lunda_jackso Feb 10, 2010
    Hi, I'm not sure what the problem was but I went in and cleaned it with a soapy towel (rollers etc) changed out the paper and now the machine copies well.
  • 11,896 Answers
Your best bet, and really not the easiest is to take apart as much of the machine as possible. You can try a paper clip or pipe cleaner or anything else you can try to remove the jam. It could be on the roller, in the gears, on the slide, or on the head or cartridge itself. If you have any jagged edges in the machine, try to file them down so paper does not catch. If needed, dismantle the machine but take pics of different parts so you remember how it goes together.
Posted on Feb 08, 2010
  • Nate Stansfield
    Nate Stansfield Feb 10, 2010
    cleaning the heads, rollers, and guides should make a difference as stated above. They could be sticky or have a paper stuck in them.
IR 2270/2870g photo copy machine ,paper jam at the time of double side copy
Clean the vertical path rollers .they are located in the right door. check for obstructions. inspect your right door for broken parts and missing pressure springs that keep pressure on those vertical rollers. Make sure the right door is shut firmly.
Apr 11, 2014 | Canon Ink Cartridge GPR15 for iR 2270, iR...
Every time i print it keeps getting jams
You'll have to open up the printer and remove any paper pieces that are blocking paper delivery. There's usually a panel on the back of the printer that removes easily, maybe with a twist of a lever, and you might look in the front too. I couldn't find a troubleshooter manual online, but you should have one in your documentation; It should tell you where to look for jams.
Dec 05, 2013 | Canon ImageRunner 2270 | IR2270 |
Hello , i have cannon IR 2270/2870g photo copy machine ,paper jam at the time of double side copy
There might be an issue with the feed clutch or fuser. It depends on where it jams in the machine.
Sep 27, 2013 | Canon Ink Cartridge GPR15 for iR 2270, iR...
Open your developer unit and check sensor , refix it an close unit see........your problm solved
Apr 22, 2013 | Canon Ink Cartridge GPR15 for iR 2270, iR...
Canon ir 2270 having a problem of paper jam but it doesnt show any error code can you help me solve this problem. by Fredy Gabriel
if it has a paper jam. it should show on the display/panel which the position jammed.
then you open up the cover of it..
Jun 08, 2011 | Canon imageRUNNER 2270 Copier
Paper jam will not clear
you have a stuck or broken sensor
Jul 02, 2009 | Canon Office Equipment & Supplies
Paper jam
Hi usually paper jam at paper input area a or transfor section(photo drum area or fuser unit area, so you may try:
1) take out paper tray and open the cover that you can change toner cartridge there (see manual) looking for any paper inside paper input area or around the cartridge, then take out jam paper.
2) open fuser unit at paper output area ckick a locker at somewhere (see maanual) looking for any paper jam
Dec 22, 2008 | Canon imageRUNNER 1310 Printer
Paper Jam
Did you open the smaal door on the lower left to try to remove it from there.Or is it stucked in the fixing area.
Jun 07, 2008 | Canon IMAGERUNNER 6570 Copier
Canon imageRUNNER 2270 Copier Logo
53 people viewed this question
old marine
old marine
