Question about Cobra Radio Communications
Wiring Cobra CA-72 to 4 pin end - Cobra Radio Communications
    Problem Solver:
  • 5 Answers
Check this out http://www.hamtechnet.com/techtips/mikewiring/11%20Most%20Popular%20MIC%20Wiring%20Diagrams.html
Posted on Feb 23, 2010
I have cobra ca61 desk mic i need it wired to my cobra 142 gtl home base. the base has 5 pins so i need my mic to be wired for 5 pin... any ideas?
cobra 5 pin to 4 pin adapter on ebay around $5.00
http://www.ebay.com/itm/WORKMAN-C4P5C-CB-RADIO-MICROPHONE-ADAPTER-5-Pin-COBRA-TO-4-Pin-COBRA-/121655850211?hash=item1c5340f4e3:g:e0AAAOxy2YtRsJ8n
Apr 10, 2015 | Cobra Radio Communications
I have a 5-pin cobra power mic model ca-76 and i need to make it a 4-pin power mic
most 5 pin with wires can and will work for a 4 pin--you just need to know the pin out versus the wires in the mic you are trying to wire it to.
Apr 13, 2012 | Radio Communications
I'm trying to wire a galaxy desk mic to a cobra 200 10 meter mobile
  • The Galaxy desk mic (power mic) is already wired four pin and the Cobra 200 is a 4 pin already as well. So unless someone has messed with them the mic will plug right up to the radio as is.
  • But if someone has repined the mic then follow the pinout I listed below to get it rewired for the Cobra 200
  1. Pin #1 on mic connector - Black wire.
  2. Pin #2 on mic connector - White wire.
  3. Pin #3 on the mic connector - Blue wire.
  4. Pin #4 on the mic connector - Red wire.
  • If you look on the end of the mic connector it will have the imprint of the number for each pin on the mic.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 02, 2011 | Cobra Radio Communications
I have a general lee cb with a 4-pin standard mic. the wires in my mic cord broke at the plug. does wnyone know how to wire this type of mic back and what color wires go to the correct pin?there are 6...
Here are the Pin outs for different mics that will work with your radio. If a wire is not listed then you cut it off. It's best to keep the wires as short as possible no longer than a half inch is suggested. Normally the Cobra pin out is standard for most radios.
Stock - 1- Shield (Ground) 2- Yellow (Audio) 3- Red (Transmit) 4- White (Receive)
Astatic - (4 wire) 1- Shield 2- White 3- Red 4- Black
Astatic - (6 wire) 1- Shield & Blue 2- White 3- Red 4- Black Yellow NC
Daiwa EM-500, Cobra, CA Series - 1- Shield & Black 2- Red 3- White 4- Blue
Galaxy DC-521S - (4 wire) 1- Shield 2- Yellow 3- Red 4- Black
Galaxy CB-660EI - 1- Shield & Black 2- White 3- Red 4- Blue
Sadelta - 1- Shield 2- White 3- Brown 4- Green
Turner - 1- Shield & Red 2- White 3- Blue 4- Black Yellow NC
Jul 12, 2011 | Magnum DeltaForce CB Radio
I need the wiring for the mic
Here is the wire diagram for several common mics in relation to a 4 pin CB. Most recent 4 pin CB's such as Midland, Cobra, Connex, Uniden, etc can use 4 pin mics. The wiring is actually depending on the mic rather than the CB so long as the CB's are 4 pin as well. Once you go back to late 80's the 4 pin design was a little different. Anything new it is simpler.
Stock Mic 1- Shield (Ground) 2- Yellow (Audio) 3- Red (Transmit) 4- White (Receive)
Astatic - 4 wire 1- Shield 2- White 3- Red 4- Black
static - 6 wire 1- Shield & Blue 2- White 3- Red 4- Black Yellow NC
Daiwa EM-500 Cobra CA Series 1- Shield & Black 2- Red 3- White 4- Blue
Galaxy DC-521S - 4 wire 1- Shield 2- Yellow 3- Red 4- Black
Galaxy CB-660EI 1- Shield & Black 2- White 3- Red 4- Blue
Sadelta 1- Shield 2- White 3- Brown 4- Green
Turner RK56 Road King 1- Shield & Red 2- White 3- Blue 4- Black Yellow NC
Regards, Tony
Apr 07, 2011 | Connex Radio Communications
Superstar DM 452 echo mic wiring for a 4 pin cobra 2000 gtl ?
Note: The pin numbers are marked on the end of plug.....#1.shield, #2.white, #3.red, #4.black.....that means #1.shield, #2.audio, #3.transmit, #4.recieve..........hope this helps.........
Feb 16, 2010 | Cobra Radio Communications
I have a Cobra 148GTL with a 5 pin side mount mic. My problem is that the radio powers up and all I get is a static type noise but no recieve and when I key the mic the meter shows I'm sending a signal but...
sounds like a bad mic....At the 5 pin end u will see a small screw take out that screw and slide the pin cover back and you will see the 5 wires going to the pins my bet 1 or more of those ends are broken all you ned is re sod. them and all will be good .....I buy alot of broken mics and all i need do is fix the wires easy fix .....
Nov 13, 2009 | Cobra Radio Communications
NEED HELP WITH MIC WIRING FOR COBRA 25 LTD ST
1 Shield 2 White 3 Red 4 Black if the radio keys up as soon as you turn it on reverse 3 and 4 I am not familiar with that mic.But the way I actually should have given you the wiring order is as follows:1Shield 2 Modulation 3 and 4 key up I hope this helps.
Feb 18, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
Magnum delta force
pin1 = mic audio,pin 2=receive, pin3= push to talk or transmit, pin5= shield.
cobra usually is white= mic audio, red= ptt, black= receive or speaker complete
Dec 21, 2008 | Radio Communications
Mic wiring problems.
I have one for a Cobra CA50 may work
pin-1 shield or ground
pin-2 audio lead
pin-3 tx
pin-4 rx
there are one more
pin-1ground
pin-2 audio
pin-3-rx
pin-4 -tx
Nov 18, 2008 | Radio Communications
Radio Communications Logo
191 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
