Question about Astar LTV-2701 27 in. HD-Ready LCD Television
AstarLTV-30-MA power supplie board
Repairman said it's the power supply, but can't find any. He said if we had the schematic's for it he may be able to use power board from another brand. Same problems turns on for split second astar pops up then black screen.sometimes sound then nothing. And of course the company is out of bussiness. HELP!!
    Problem Solver:
  • 3 Answers
If the problem is the power supply sometimes is not an easy fix. the easy ones are swollen electrolytic capacitors which are easy to spot because the top of it tends to swell up. However when there is a short circuit, this is another story. A blown fuse is an indication of a short. Fuses blow for two reasons, one overload or a dead short. In this supply there are two stages. In the first stage there is a bridge rectifier which is always connected to the AC line thru a fuse. Check this bridge with an ohm meter in Rx1 and make sure is not shorted.
Posted on May 25, 2014
Just fixed my own by replacing the capacitors in the power supply board, cost for parts $51.00. info on this site was great!
Posted on Mar 12, 2008
  • 2,336 Answers
If the problem is with the power supply, that is an easy fix; even without the schematic diagram.
Is normally some leaky capacitors that failed on the majority of power supplies on these TVs.
Posted on Feb 22, 2008
How to fix no picture on samsung tv m/n: pn51e550d1fxza the red light flashes but no picture or audio, also no clicking like in many of the youtube videos ive watched.
Try the power supply board first. There is also a chance there is a failure on one of the other boards that can cause the supply to go protect mode, or can be damaged.
Without proper diagnostics, schematics, support info, and spare boards for testing, it would be overly difficult to service your set.
Mar 10, 2017 | Samsung Televison & Video
Schematic atx diagram
I give up! Why would you need a schematic for a computer power supply? I've been in the computer business for over 30 years and have never needed a power supply schematic. Just curious!
Sep 18, 2013 | Antec BP350 350-Watt Power Supply
I would like to know if you can supply the schematic diagran for LG32LH20R-MA power supply board E247691
I've the said diagram, but it can't be send to you by this window. It is in PDF.
Apr 30, 2013 | LG Televison & Video
Model # TH-42PX80U tv was on when a storm hit 'lightning' , on lite only blinks... is it a fuse ? or mother board?
You are better off replacing the power supply board. Usually the mother board will output a power ok signal to turn on the TV only when the power supply is working correctly (all voltages are within specs), similar to a computer, having said so, if you have the schematics you can verify those voltages being output from the power supply upon depressing the power button. The +5v stand by voltage is most likely ok, since the mother board is at least providing you with the blinking light. It is the +12V and +24V which are not being output, along with any other auxiliary voltages. I would suggest either having a replacement board (power PCB) installed or otherwise feeding the needed voltages by substituting those missing ones with a variable DC power supply, just to verify it. Follow above only if familiar with electronics and electricity. safety first!.
http://www.HDalacarte.com guy audio/video/computer technician for over 30 years
May 26, 2011 | Panasonic TH-42PX80U Plasma TV
I am looking for a schematic for a Dell Optiplex GX280 power supply. The supply is model HP-U2106F3.
I just replaced my GX280 power supply (mini-tower) with the following 400W for $30.
http://www.cputopia.com/hp-400w-dell-optiplex-gx280-mini-tower.html
The only place I can think you will find an actual schematic for the PSU is from the manufacturer.
Feb 13, 2011 | Hi-Pro Refurbished HIPRO POWER SUPPLY FOR...
Unit is dead I need power supply schematics
U will not find schematic,the tv corporation don't release them.Just take the tv aparts.Tries Websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.Just compare the power supply board in ur tv and the website that selling the power supply board.The picture look alike,ask the seller questions.Just buy and replaced it.U know how to solders?Just searches around the power supply board for those bulges and puff up capacitors.Replaced these capacitors will get ur power back.Most just reqiure replaced these capacitors to get the power back.
Apr 21, 2010 | RCA L32WD26D HDTV/DVD Combo
LG TV (LCD) power supply schematics
Service manual from SAMs does not include a schematic of the power supply board
Aug 03, 2009 | LG Televison & Video
Power supply bad on Sharp Aquos LC - bad board - schematic to ID?
Buy the green light going on means Standby is ok. Next, would be to locate the plug coming from the main board to the power supply and find the post that says PO which means power on. With your meter on that post, press the power button as see if the reading goes High, if it does then the main board is able to turn on the power supply. Next, find the plug on the power supply that goes to the inverter( the long board on the side) remove it and see if you have 24 volts coming out of the power supply when you press the power. If you do, then the inverter board is bad, if you don't have 24 v, then the power supply is bad. There are NO diagrams available for these set other than a flow chart if you can find one. A regular svc tech does'nt need a manual for these anyway.
Let me know how you do Kathy ?
May 17, 2009 | Sharp Televison & Video
Have a 30" SHARP Aquos LC30HV2U that has a bad power supply. Nothing happens when I turn on the LCD - though it is getting power confirmed by green light going on but nothing on LCD. Visual inspection
You did try the CLEAR button on front of the box?
One possible idea is the cables going the box to the TV. ( might be bad )
If your sure about the problem, you can get your Service Manual here:
http://www.nodevice.com/manual/newmans/upsharp/LC30HV2UPDF/get53718.html
This with have all the schematic, diagrams, part number, and test points you need.
Longitudional lines on my monitor...
It could be your power supply, your monitor, your graphics card or a software problem.
Try to reinstall your graphics card drivers, if that doesnt help try another monitor.
If that also doesnt help I suggest you temporarily install another graphics card. If that also doesnt fix your problem, you should go buy another power supply.
Feb 18, 2009 | HP nVidia GeForce 8400 GS, DH PCI Express...
Astar LTV-2701 27 in. HD-Ready LCD Television Logo
141 people viewed this question
Top Astar Televison & Video Experts
Jaime Hernandez
ted dux
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
