Question about Garmin iQue 3600 GPS Receiver
Garmin ique 3600 hot sync issues
I am unable to hot sync. I receive the following error message " The connection btw your handheld computer and desktop could be be established. I have checked all the connections, made sure USB is selected and tried Com 1 and Com 3. Tried loading the software again but, it will not allow me to fully install until a hot sync connection is completed. I hope you can help.
  • EMFPDA Feb 25, 2008
    I had the very same problem. I tried to reset the PDA and then I got a lighted screen equivilant to the blue screen on a PC. No display of icons or applications just a lighted blue screen. Anyone know what to do for this error?
  • Rod22 Feb 27, 2008
    Thanks so much the hot sync is working great now!
    Novelist:
    Scholar:
  • 100 Answers
You have to have a HOTSYNC ICON in your Quick Start menu. If not, then CLICK ON YOUR HOTSYNC ICON in your PC and "THEN" push the HOTSYNC BUTTON on your Cradle. Make sure it is set for PC CRADLE CABLE, both the PC and the Unit itself. If one is turned off, it will not transfer. Works the same for IR too..
Good Luck,
Kindly,
JIm
Posted on Dec 31, 2009
I had the same problem. Obtained no help from Garmin - $200 to repair.
I purchased a $7.00 IRDA (infra red) - USB device; set my Connection to IR - PC and have been able to sync without any problems. However even withupdates I have not been able to get the cradle - PC connection to work. This is not a problem however since I now use the IR connection all the time.
You must touch the screen hot sync logo not the cradle button to start the sync process.
Posted on Feb 26, 2008
If your unit has a memory card installed, remove it and hot sync again. Follow reset prompts and everything should reappear. Good luck.
Posted on Sep 19, 2008
Hot sync problem for Garmin iQue 3600
If reinstalling on the same computer with your original cd doesnt' work then I suspect that your registry has gotten corrupted somehow.
I'd find another computer and try a totally new install to see if that works. This registry stuff is a headache.
If it works on a different computer then I'd go into the registry and remove all traces of Palm and ique and start all over. Always make a backup of your registry before messing around with it. If the original CD worked before then there's no reason to download newer versions unless you are wanting to solve some other problems.
Don
Jan 27, 2010 | Garmin iQue 3600 GPS Receiver
Garmin hotsync issue
Hey uninstall the program, download the newest one available and try again.
Sep 08, 2008 | Garmin iQue 3600 GPS Receiver
Is there a way to use ique 3600 with windows 7? ique does not syc.
I am using Windows 7 Ultimate 64 and the iQue did not work. There is no USB driver and as far as I know there isn't going to be one. However, I did get it working by installing Windows XP mode and the Windows Virtual Machine on my XP system. You need to check if your computer can run XP mode and there are Microsoft tools to do that. After you get XP mode installed and running, there will be a virtual XP window on your desktop. Plug the iQue in its cradle and plug it in to the USB port. Use your iQue setup CD to install the Palm desktop in XP as you normally would. At some point, you have to tell XP to attach your iQue to the USB port. Near the XP title bar, there is a USB pull-down menu. Use this to attach the device. It will ask for a driver. Just say to use the Garmin-supplied driver. Wait until this finishes successfully. Before trying a sync, open the Palm desktop and go to Hotsync/custom and change everything you can to "handheld overwrites desktop" and save this. Push the hotsync button on the cradle. If it doesn't connect, go to the USB pull-down and click attach. It should work!
Dec 08, 2009 | Garmin iQue 3600 GPS Receiver
It says i have no connection between my handheld and my computer when i try to hot sync
If you are trying to HotSync to a Macintosh, you need to install Lycestra's PDiQue software available at http://www.lycestra.com/ique.html before HotSyncing is enabled. PDiQue enables a USB conduit between your Mac and the Garmin iQue 3600.
Oct 23, 2009 | Garmin iQue 3600 GPS Receiver
I have the same problem as above it starts to install and then says you must turn garmin on - its only and contect to usb it is connected, did the property thing it shows local. checked garmin FAQ did what it said and got same answer HELP!!!!!!!!!!!!!!!!!!.
Jul 16, 2008 | Garmin iQue 3600 GPS Receiver
IQue 3600 sim card problem
from Garmin:
Question: Why wont the PC recognise my the SD card in my iQue 3600?
--> Answer: Go to My computer and look for the following directory:
  • C: > Program Files > Palm > (user name) > file called 'sync'
  • Double click on this file and delete the four bottom rows that will look something like this:
"SlotId=0
MediaType=1935960423
DisplayName=SecureDigital (SD) Card
InstallDirName=Slot-SD"
  • Then try a HotSync as normal, it should then 'see' your SD card.
  • If all fails delete a second user name as sometimes this interferes.
Mar 14, 2008 | Garmin iQue 3600 GPS Receiver
Sync problems with windows vista
I got a Vista computer in April and have problems also. You need a special program to install the maps. email Garmin and they will send you the link. An SD card reader/writer is MUCH faster than the sync.
I didn't have syncing problems until after I tried to install Documents to Go. I had to remove Doc to Go v6 because it was making my computer unstable. Doc to GO V10 works with Vista but requires Palm OS6. Garmin says that Palm OS6 can't be installed on the Garmin iQue because they added proprietary software to OS4. I believe my sync problems will disappear after I reload the Palm Software.
Feb 18, 2008 | Garmin iQue 3600 GPS Receiver
Why will my Garmin not sync into my computer?
First, right click the hotsync button in the task bar and make sure "USB" is selected (assuming you're using USB...).
If that doesn't work, let me know.
Oct 06, 2007 | Garmin iQue 3600 GPS Receiver
Garmin IQUE 3600 unable to HotSync, Windows XP
I think I have solved this problem.
Try this:
Go to my computer, right click -> Properties -> Hardware -> Device Manager.
Locate your IQUE 3600, or Palm.
Now, if your palm has a Yellow Exclamation mark on it, that means that your computer is not recognizing the Palm. Select
Driver details. Re-install the driver off the "Setup CD" that came with your IQUE 3600.
This worked for me.
Sep 21, 2007 | Garmin iQue 3600 GPS Receiver
Garmin iQue 3600 GPS Receiver Logo
508 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
