Question about HP ScanJet 3200C Flatbed Scanner
Hp scanjet 3200 stuck!!
Ahhhh was working fine before i moved now it sounds(and looks)like it's stuck. When the light goes down only gets about 1/3 of the way then it stops and clicks. How can i unstick it?
  • 181 Answers
I would say the most likely cause of the issue is either that the scanner is no longer functioning or that it is experiencing power issues. Make sure that the scanner is plugged in directly to the wall and not into a surge protector or a power strip. The scanner does not share power well and pulls it in large amounts - when it can't get it it throws little power fits and sometimes will not turn on at all. Try another wall outlet and see if you can get it to power on and then do a scan to see if the light goes on.
If not it may be a bad scanner and then I would try and call hp and see if they have any upgrade units available - usually refurbished but they come with a 1 yr warranty and are significantly cheaper than buying a new unit from the store. They will also take your unit and pay to have it returned to go to an environmental recycling facility.
Posted on Feb 28, 2008
My scanner is not returning it seems to be stuck
I have had good luck fixing that problem by opening up the scanner and cleaning the rails with alcohol then very lightly lubricating them.
Feb 28, 2015 | HP Scanjet G2410 Flatbed Scanner
The scanner is not scanning in photo scan mode and
that's hardware related problem, you need to open the machine and lubricate all moving parts specially in bulb image receiver side.
Feb 08, 2010 | HP ScanJet 2400 Flatbed Scanner
HP scanjet 5590 pulls the paper half the way in and then starts pulling sideways and then gets stuck.
Have you checked to make sure there isn't previously jammed paper in the feeder?
It sounds like the paper is getting stuck on just one side which is causing the paper to start going sideways.
Oct 15, 2009 | HP Scanjet 5590 Flatbed Scanner
Scanjet 4890 prepared to scan, but will not work
Uninstall the Driver Software, switch off the Computer and reinstall the driver software again. This should work.
S. Mohan
Oct 12, 2009 | HP Scanjet 4890
Hp scanjet 3970 won't power on
Is the AC adapter getting warm when it's plugged in?
No fuses inside.
Jun 10, 2009 | HP ScanJet 3970 Flatbed Scanner
Green and yellow verticle stripes on preview and scanned images
You need to check the specifications of the old scanner. Was it designed to work with Windows 98? If it wasn't then there's little you can do to get it to work with 98. What you could do is look around for the nearest HP scanner that was the next model up after the 3200. A search of E-Bay for old scanners should come up with a cheap second hand model that still works with Windows 98.
Mar 27, 2017 | HP Scanjet 4470c Flatbed Scanner
Having HP scanjet 3200 C scanner. Its interface cable is required. Also pl make available its guide/manual
This scanner uses a parallel port interface, so you need a db25 cable, both sides male.
Support and drivers? http://www.hp.com
Mar 07, 2009 | HP ScanJet 3200C Flatbed Scanner
HP ScanJet 3200C Flatbed Scanner Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
