Question about LG Flatron L1718S LCD Monitor
I have a LG Flatron L1718S-BN and need to get to power supply inside monitor. I need instructions to remove the base and swivel stand. So monitor can be repaired.
  • 60 Answers
SOURCE: LG swivel base
Just look at where the base goes in. There should be 4 screws that are holding it on.
Posted on Apr 21, 2008
  • 53 Answers
SOURCE: LG flatron L1718s monitor switches on for a split second then goes off
check that the monitor is indeed the problem, plug the montior into a different pc or laptop and see if it works.
if so then borrow a monitor from somewhere plug it in to your pc and see what happens if it does not produce a picture then check that your graphics card is seated correctly in your motherboard.
also this is where it gets tricky, but if the graphics card is AGP make sure that your bios is set to use the AGP (not PCI) as it's primary or vice versa if it's a PCI graphics card.
(I say tricky because you may not be able to view anything if you don't have or can't borrow a different type of graphics card ie try a PCI one if you have AGP) to do this step you will need to install a spare card.
if you still have no joy but you get the monitor to display something when it is plugged into the different PC, at least you know the monitor is not at fault.
Posted on Nov 04, 2008
  • 12 Answers
SOURCE: LG 1718S-BN comp monitor, power light off; monitor won't display.
I know this may seem simple to you, and I'm not talking about the power light. Your monitor tilts up and down at the top of the stem connected to the base. At the top, where the stem connects to the back of the monitor is the hinge that allows the monitor to tilt up and down and it should be covered in plastic. You should be able to see what looks like a metal rod going through the stem and the monitor. If you squeeze together the plastic on both sides, they should come off to reveal the screws that hold the stem to the monitor.
As far as the power goes ... my first thought is a fuse (won't turn on and no power LED) or something has blown your power supply.
After you get it open let me know what you see.
borna49er@yahoo.com
Posted on Mar 08, 2009
Darkseid007
  • 29 Answers
SOURCE: Request LG monitordriver for LG FLATRON L1952S to
i am hoping that one of these 2 links will help you to get what you are needing vijay.
http://driverscollection.com/?H=L1952S&By=LG download here
http://members.driverguide.com/driver/detail.php?driverid=654392
seems they are a little hard to comeby nowadays.
but i hope this helps.
DARK
Posted on Jun 20, 2009
SOURCE: LG Studioworks model (500G)CRT Monitor flickers most of the time
lg 500g studioworks green color
Posted on Sep 03, 2009
How to remove back of monitor
is there a fuse inside a lg monitor
Apr 14, 2013 | LG Flatron L1718S LCD Monitor
I have a LG Flatron L1718S; the screen display for 2 sec and then turn Black.
If the power light remains on after it goes black, the problem is the inverter board that powers the back light behind the screen, the cause is usually bad capacitors. To fix it, the board must be replaced or attempt made to repair the inverter board.
Feb 10, 2011 | LG Flatron L1718S LCD Monitor
When i turn my computer on the monitor flickers for a second then just goes black. at the start i can see the desktop but after that it goes black lg flatron l1718s
You may have problem in the power supply, common causes are the bad capacitors (bulging top/seal, or leaking). That will be the first place to check. I will assume that you have already try it with another PC and it still does not work. See pictures here for a guide so you know what to look for inside:
http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Post back what you find so it will help out other people also.
Apr 06, 2010 | LG Flatron L1718S LCD Monitor
How to remove the back panel on lg 1718s-bn
scaillos, Try YOUTUBE for video clips of "lcd monitor disassembly" and or "lcd monitor repair". Don't use any sharp edged cutting tools like kitchen knives or you will incur additional monitor repair costs that will be paid to local hospital "ER" !!! Might find interesting stuff at www.ccl-la.com/badcaps.htm and www.badcaps.net , www.lcdparts.net , www.ccfldirect.com Start at lower edge of monitor and look for small slot to inset something to pry with. Good luck. Be careful. 12fixlouie
Mar 28, 2010 | LG Flatron L1718S LCD Monitor
Not funcion
I had to fix my LG L246WP-BN Flatron monitor. It had two bulging 3300uF 10V capacitors in the 5V section of the power supply. I made a complete repair tutorial video on how to fix. Try this:
http://www.youtube.com/watch?v=qJhkLiMR12g
Feb 27, 2010 | LG L246WH-BN Monitor
Need to remove back cover of LG Monitor
All he wants to know is how to remove the back and we get totally irrelevant replies e,g, how to swivel the monitor on its stand, ridiculous !
Feb 07, 2009 | LG Flatron L1718S LCD Monitor
Monitor Stand
You have to lay the monitor face down, then pull the column hard at an angle until one side clicks out, then pull to get the whole thing off. It's detailed in the manual on the LG website.
Dec 13, 2007 | LG Flatron L1718S LCD Monitor
LG Flatron L1718S LCD Monitor Logo
221 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
