Question about Kenmore 24.8 cu. ft. TRIO Bottom Freezer Refrigerator
Water dispenser the water dispenser has froze up once again. why does it do that?
  • Anonymous Mar 31, 2008
    I have the same problem. It makes ice without a problem but the water doesn't even begin to drip. I purchased a new filter and installed it properly; however, I still have not had any luck. HELP!
  • chickysue50 Mar 30, 2009
    Water line to dispenser is located inside refrigerator compartment (behind vegetable bins) is freezing solid. Electronic temperature read out is also inaccurate, about 10 degrees off. So the refrigerator, set at 40 is really 30 degrees. Anybody know what's causing this?
Usually when this problem occurs, i just keep pushing the button and it will after a minute come through. This time, i had to remove the water filter and empty the water out, put the filter back in and pushed the button til it dripped, then a trickle and then it was back to normal.
Posted on Feb 25, 2008
GE profile refrigerator ice maker not working
Ice dispenser doesn't work
  1. Dispenser control board
If the ice dispenser is not functioning at all the most likely cause is going to be the dispenser control board. The dispenser control board governs the major portion of the systematic functions of the dispenser and is less likely to be the issue if only certain components are malfunctioning. If the dispenser control board is at fault, it will need to be replaced.
  1. Water inlet valve & low water pressure from house supply
If the ice dispenser on your refrigerator is not working properly, one of the first things to consider as an issue is the water pressure to your appliance. The ice dispenser cannot properly function with a psi less than 20. If psi is appropriate, proceed to replace the water inlet valve to correct the issue. You may also be dealing with low household water pressure. This low flow can be examined by using a water pressure test gauge. Once the household water pressure is resolved, you can double check your refrigerator connection to ensure it is now flowing properly and that the ice dispenser is functioning.
  1. Water tube in door is frozen
If the ice dispenser is not working on your refrigerator, the issue could be a frozen water supply tube located in the door. Although this may be a tricky problem to locate, the first thing to do is find a connection point in the tube. After this has been found, attempt to blow air through the tube. If the air flows freely through the tube, it is not frozen and this is not the issue. If it does not, the tube is frozen and needs to be removed to thaw out. As it thaws, attempt to ascertain why it froze and correct the positioning of the tubing to prevent the issue from occurring again in the future.
  1. Dispenser switch
If the refrigerator ice dispenser is not working properly you could be dealing with a defective dispenser switch. Activated by the dispenser actuator, the switches are responsible for numerous actions including ice cube disbursement, type of ice, and water controls. The switch can be tested using an ohm meter and should be replaced if it does not reveal continuity.
  1. Door switch
If the refrigerator ice dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the ice dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement.
  1. Dispenser switch
  1. Door switch
Water dispenser doesn't work
If the water dispenser is not functioning at all the most likely cause is going to be the dispenser control board. The dispenser control board governs the major portion of the systematic functions of the dispenser and is less likely to be the issue if only certain components are malfunctioning. If the dispenser control board is at fault, it will need to be replaced.
If the water dispenser on your refrigerator is not working properly, one of the first things to consider as an issue is the water pressure to your appliance. The water dispenser cannot properly function with a psi less than 20. If psi is appropriate, proceed to replace the water inlet valve to correct the issue. You may also be dealing with low household water pressure. This low flow can be examined by using a water pressure test gauge. Once the household water pressure is resolved, you can double check your refrigerator connection to ensure it is now flowing properly and that the water dispenser is functioning.
If the water dispenser is not working on your refrigerator, the issue could be a frozen water supply tube located in the door. Although this may be a tricky problem to locate, the first thing to do is find a connection point in the tube. After this has been found, attempt to blow air through the tube. If the air flows freely through the tube, it is not frozen and this is not the issue. If it does not, the tube is frozen and needs to be removed to thaw out. As it thaws, attempt to ascertain why it froze and correct the positioning of the tubing to prevent the issue from occurring again in the future.
  1. Dispenser switch
If the refrigerator water dispenser is not working properly you could be dealing with a defective dispenser switch. Activated by the dispenser actuator, the switches are responsible for numerous actions including ice cube disbursement, type of ice, and water controls. The switch can be tested using an ohm meter and should be replaced if it does not reveal continuity.
  1. Water filter
If your water dispenser's flow is running slow check to ensure that your water filter is not clogged. If after checking you determine that the filter is clogged, simply replace the filter. Filters should be replaced every six months to ensure clean drinking water.
  1. Door switch
If the refrigerator water dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the water dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement. Appliance Repair Help Troubleshooting and Appliance Parts
Aug 18, 2014 | GE Refrigerators
Water dispenser just stopped working. Ice dispenser still works and the refrigerator has a new filter
two possibilities
1) the water valve is defective it has one inlet from the house plumbing,two outlets, one for i/m one for water dispenser
2) the reservior that chills the water is frozen, it is located behind the lower crisper drawers in the ref. to see if its frozen remove crispers and shelves and tap on it , if hollow sounding it's not froze if solid sounding its froze. to thaw it turn off unit for at least a hour
Jul 21, 2011 | Kenmore Side by Side Refrigerator
PSW26P Dispenses no water, ice, or crushed ice.
Deforst you refrigerator the water line is frozen. However, my refrigerator line froze again and vegtable froze.
Aug 28, 2009 | GE Profile PSW26P Stainless Steel Side by...
Kenmore elite water dispenser not working
We had the same problem after 4 months. A technician came out and told us that our water line within the refridgerator was frozen and that every once in a while we'd have to take a hair dryer to it (!). Of course we told him that was unacceptable so they sent a second tech out who replaced some parts by being walked through the repair over his cell phone. He was unable to tell us what happened or details about the repair. 11 months later our water line froze again and we resorted to a Brita water pitcher.
Aug 04, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
No water but ice is fine
turn freezer side to zero for 1 minute press water dispenser
Mar 29, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
We had a ice storm and power was off for nearly two weeks, wont d
When the power was off for that long period of time all of the ice in the dispenser melted. When the power came back on, any water remaining in the ice cube bin froze into a solid block.
If you raise the wire arm up and leave it up, no new water will come into the icemaker. Do that.
If there is a block of ice in the ice cube bin, use a blow dryer to melt it and discard it. Once the ice is gone, spray the auger with some PAM or other cooking spray to lubricate it a little bit.
Finally lower the wire arm down and wait up to 12 hours to get ice making normally again.
Feb 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Internal water dispenser stopped working
I lowered the temp on the freezer to 4 overnight, by morning water dispenser is working fine. I think that when we changed the temp to 7 (in order to make more ice ) it froze the water pipe going to the dispenser. I am going to keep both fridge and freezer at 5 ,and hope this will not happen again.
Dec 31, 2008 | Amana AFD2535FES Stainless Steel Bottom...
Kenmore Refrigerator stopped dispensing water
Either your water tank in the fridge froze up, the waterline that goes up the freezer door from the bottom hinge froze, or the switch that your glass hits is damaged. Do you hear any humming or noises when you put your glass up to get water?
Oct 27, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water dispenser and ice-maker do not work
open ice maker cover buy pass T_H will move if still water not come in ice maker change fill valve
Sep 03, 2017 | Refrigerators
Kenmore 24.8 cu. ft. TRIO Bottom Freezer Refrigerator Logo
164 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
