Question about Apple iLive IBCD3816DT Portable 2.1 Channel CD Boombox with AM/FM Stereo Radio, iPod Dock and Remote Contr... Boombox
I NEED THE IPOD MOUNTING BRACKETS THAT HOLD THE I POD
SOLVED
Posted on Feb 09, 2010
Why wont i tunes recognize my i pod and sync my music to it
Your ipod may be corrupted and will need to be wiped and restored.
First of all try another lead to connect your ipod to pc.
Also look inside bottom of ipod to check no bent pins in ipod dock.
Also reinstall itunes incase of program corruption.
If still not working you will have to put ipod in disk mode.
Switch ipod off then switch hold button on and off then hold down centre putton and bottom pause button until TICK appears.You are in Disk mode.
Go to file explorer and right click your ipod if shown,Chose FORMAT then chose restore device defaults and restore. Once formatted open itunes and connect ipod with good lead.Ipod can now be restored from backup or a clean restore can be done
Sep 01, 2014 | Apple 160 GB iPod Classic (Silver) +...
I have a problem in my I-pod A1136 30GB only logo in the screen.... pleas help me what is the best solution in my i-pod... thanks and advance...
Make sure the hold is off, then push the center button and menu button simultaneously and hold for about 10 seconds. This should reset your ipod.
Hope this helps!
Jun 16, 2011 | Apple iPod MA446LL/A MP3 Player
Need to turn off i pod
Hold the lock and home button for 10 seconds, or hold the lock button after the iPod is unlocked and than slide the power tab that comes up over. Or let the iPod die.
Hope this helps ^^. Please dont forget to rate, Thanks
Mar 05, 2010 | Apple iPod MA446LL/A MP3 Player
I pod is disable , unable to unlock using password
  1. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPod touch to turn off.
  2. Press and hold the Home button while reconnecting the USB cable to iPod. When you reconnect the USB to iPod, the device should then power on.
  3. Continue holding the Home button while iPod starts up. While starting up, you will see the Apple logo.
  4. When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message:
  5. Restore and it'll download ~240mb firmware and you're done
Warning: you will lose all your data
Sep 22, 2009 | Apple iPod touch
I dont have the computer that I orginally synced my i-pod with.
YES SHUT YOUR I POD OFF, THEN CONNECT YOUR USB CABLE TO YOUR PC AND TO YOUR IPOD THEN HOLD THE POWER AND HOME BUT UNTIL YOU SEE THE ITUNES ICON AND THE USB CABLE RIGHT UNDER IT ON THE IPOD SCREEN AS SOON AS THAT POP'S UP LET GO AND IT SHOULD SYNC INTO ITUNES, IF YOU HAVE NO PC THEN YOUR WELL OUT OF LUCK.
RATE ME PLZ
May 02, 2009 | Apple iPod touch
My i pod has frozen
First thing you do is to switch the hold button on then off, and then when the ipod is not on hold you press the center button and the, and the play/pause button at the same time. then hold on to them two buttons to where to ipod symbol shows up. then you wait and it will go back to normal!
Nov 30, 2008 | Apple iPod nano
My i pod wheel has frozen. None of the buttons work on my Ipod only the hold button when it is slides across causing the screen to light up. The i pod is 60gb and has not been dropped or exposed to...
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
That should get rid of the freeze.
If your unproperly disconnecting the ipod from your computer before the itunes
sofware disconnects it for you, then that could be your problem with the freeze ups.
Oct 23, 2008 | Computers & Internet
I Pod 4 Gb
Just charge the battery until the indicator says the battery is full.
well since its been connected for more than enought, disconnect it, you can also try reseting the ipod incase it has frozen
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Tip:
  • If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
  • If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
May 18, 2008 | Apple iPod nano
Unknown device.
What do you mean by "the hold button wouldn't go off"? Was the orange light still on? Either way, you should try restarting your iPod if you haven't done so already.
Jan 06, 2008 | Apple iPod MA446LL/A MP3 Player
I pod freezes after initial start up
To reset an iPod with a Click Wheel, including: ipodnano3.jpg ipodclassic.jpg icon_ipod_5g.gif ipodnano2.jpg ipodnano.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
Dec 05, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iLive IBCD3816DT Portable 2.1 Channel CD Boombox with AM/FM Stereo Radio, iPod Dock and Remote Contr... Boombox Logo
127 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
