Question about HP Digital Sender 9250c scanner Printer
Our scanner says check supplies and will not scan. What does this mean?
Make sure you have a network connection and can ping the unit. Had one today that only shown Check Supplies and Administration. Found loose patch cable and then Email option appeared.
Posted on May 19, 2010
Scans, but doesn't recognize the document. It only scans white
Are you sure you have the paper the correct way - that is face down on a flat bed scanner or face up on a document feed.
Mar 21, 2016 | Office Equipment & Supplies
How do I scan a document to my computer
  • First open the program that control the scanner.
  • Look for a command or section that say scanner or scan and click it.
  • Put the document to scan in the scanner.
  • Click the command in the program for scan the document
You can also use the scan tool that Windows provide that is really easy to use.
Jun 08, 2011 | Computers & Internet
Scan from printer to computer
check if the scanner is installed on your pc... if not you cannot detect the scanner... install the scanner type and then scan it..it will work...
there mite also be some loose connection.. check it there is red light blinking on the scanner , means it is not connected. if its green means it connected.... If neither of the problem occurs for you.. then you have make the scanner checked from n electronic shop...
thanks for rating please.......
Good luck
Jan 05, 2011 | Computers & Internet
Scanner showing error 04 and cant let me scan
Disconnect the power supply from the back of the scanner base.
Disconnect the USB Interface cable and the ADF Accessory cable from the back of the scanner.
Press and hold the E-mail and Copy buttons at the same time. While pressing the E-mail and Copy buttons, reconnect the power supply to the scanner.
Reconnect the power supply and turn on the scanner.
Press the Scan Doc button. the carriage will start moving back and forth in the full scan bed length. To exit test, disconnect the power supply.
now try to scan the document ..........
Dec 14, 2009 | HP ScanJet 7650 Flatbed Scanner
Are you able to please give me the reset instructions for a symbol scanner? model: LS4278
Hi, I would be happy to assist you in resetting your LS4278, but it would be helpful to know how you are connected. The Set Defaults barcode will reset all of the scanner settings, but it will also cause you to lose the "pair" (communications) between the scanner and cradle. If you try scanning a barcode at this point you will receive a single beep followed by four error beeps. This just means the scanner is not talking to the cradle. Scan the barcode on top of the cradle. The scanner should give a high low high low series of beeps followed by a short low short high. The short low short high indicates the scanner is talking to the cradle again and you are ready to scan.
If you are connected through the USB port and scan a barcode and get one beep, but do not see data on your host try unplugging the black power supply cable from the cradle. Try scanning your barcode again and it should show up on the host.
Jul 09, 2009 | Symbol Cobra LS1902 Handheld
Scanner not scanning
PSC 1401 will print but it will not scan
Jun 30, 2009 | HP PSC 1401 All-In-One Printer
MP145 Scanning Problem
hi Fulminater.
this is all i could find out from the internet.
Scanner driver will be closed : Code 2250.
Take it to a Canon Repair company, It has a 1 year warranty and needs to be replaced or call 1-800-ok canon.
check can't work the scanner because the cartridge are not inserted.
this is all i could find out.
Nov 29, 2017 | Canon PIXMA MP150 All-In-One InkJet...
MP145 with E42 22 ?
E42 means scanner error. It's posible to be dirt scanner timing sensor or the whell. You can check videos on youtube to find how can fix this issue in detailed mode.
All the best !
Oct 08, 2017 | Canon PIXMA MP150 All-In-One InkJet...
HP Digital Sender 9250c scanner Printer Logo
258 people viewed this question
Ben Johnson
