Question about Brother HL 5150 Laser Printer
Thick black stripe on right edge of every page
I have a 5150D that is printing a thick (at least 1/4") black stripe on the right edge of every page. Any idea on how to make it stop?
    Scholar:
  • 59 Answers
Yes,.. you need to change the print drum unit. The drum light (amber LED) may or may not be on. It is not the only way to tell when the drum unit needs to be replaced. If the failure is premature, it could be caused by an obstruction on that edge of the drum,.. if you pull the drum unit out and look,.. look for small pieces of paper or a failing wiper on the drum. Either way, the drum will need to be replaced and the inside of the printer cleaned.
Here is a link to the manual for your printer. Look at section Routine Maintenance 6-8
If you have anymore questions about this issue, please put them here as comment and I will answer them for you
Posted on Feb 08, 2010
Black stripe in middle of copies 1/2'' thick whole page
Most likely it is a bad drum cleaning blade. It will need to be replaced. This machine is old...good luck.
Jun 25, 2009 | Kyocera Mita Office Equipment & Supplies
Pale vertical stripe on black prints
It sounds like the black drum unit needs to be replaced.
Apr 23, 2009 | Ricoh Aficio CL3500N Laser Printer
Black Vertical Line on the paper
start a print from tray 1/manual feed and just as the trailing edge of paper is entering the machine;quickly open it to stop print and take out the cartridge and look at it's drum and the paper underneath. if the issue is there at that point then it would point to the cartridge. if not then the fuser
Let me know....
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 21, 2009 | Brother HL 5140 Laser Printer
Brother HL 5150D not printing unless I keep pressing Go
its not the problem of toner cartridge.its the problem of gears which pulls the paper they r worn out or may be cracked internally.exactly what happens when you u give the print for the first time the printer gets command and the gears starts spinning and the paper gets pulled because it gets a pressure internally and after 2 pages that pressure gets low and it stops pulling the paper.some times changing the paper thickness solves the problem temporvarily .i mean use the thick quality paper instead of thin.
Jan 08, 2009 | Brother HL 5150D Laser Printer
MP830 prints a black stripe down the back of the paper
the waste ink pads are full ..when the black line appears it is an indicator that the waste ink pads are full it is usualy because the printer has reached its life expectancy the solution is either buy a new printer or pay a tech about 170 dollars to repair it
Jan 07, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Light print and leaves a blank stripe
Try the blue corona wire on top of the drum unit. If it is not right back to the left it will leave a line on every page.
Jan 04, 2009 | Brother HL 5040 Laser Printer
1 inch black stripe down edge of page
can you try to post a copy of what you see wrong . and try to do an internal printout " function-6-4-start- under the fax button. "
Nov 21, 2008 | Panasonic DP-150FX Laser Printer
Samsung CLP-510 Print Quality problem
The following can cause bands (vertical on a normal page)
Faulty Toner cartridge
Faulty Drum Unit
Faulty Transfer Belt
Contaminated Fuser
Damaged or dirty LSU glass
I've also seen this sort of thing caused by a crusty build-up of toner on a wiiper blade on the Transfer Belt, and or Drum.
Dec 01, 2007 | Samsung CLP-510 Laser Printer
Brother HL 5150 Laser Printer Logo
510 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
