Question about Canon PIXMA MP210 Photo All-In-One Printer
Paper jam; can't see the paper jam. When I pulled out the paper jam a piece of the sheet from the left hand corner was missing and I can't see it but the printer keeps telling me I have a paper jam.
  • 30 Answers
Try to double check the paper sensor, maybe dis alligned from the sensor follow the flow of the paper and then if you can see the black stick try to straight it..........
Posted on Feb 13, 2010
How to clear a paper jam in the document feeder
Open the covers and remove the jammed sheet. ALL the pieces have to come out if you rip it while removing it. A little corner of paper left behind can trigger a sensor to show a jam.
Aug 13, 2014 | Office Equipment & Supplies
Canon mp220 pulling paper to the right and jamming
This is caused either by a small piece of paper left in the printer after a paper jam where the majority of a sheet of paper has been pulled out but with a corner torn off and still left in the printer or it can be from a foreign object dropped into the paper feed tray. Sometimes turning the printer upside down and shaking it can dislodge the object, if it doesn't, you will need to take the printer apart to look for the problem. A few philips head screws around the printer will need to be removed first then carefully 'pop' the plastic clips apart using a small flat screwdriver.
Sep 11, 2011 | Office Equipment & Supplies
Paper jam - I can see the jam, but don't know how to remove the paper.
Hello
Open the top cover of the printer.
If you can see the jammed paper, take one or more sheets of paper and pull them toward you.
While pulling the paper, press the RESUME button to turn the paper feed rollers.
If the paper needs to be fed in the opposite direction, release the RESUME button and then press it again.
If the paper is still jammed, turn the printer off or remove the power cord from the printer. Then turn the printer back on or plug the power cord in.
The printer will run through a reset cycle, which may clear the paper jam.
If the paper is still jammed or if several (8 to 10) sheets are jammed, take hold of a sheet in the middle of the stack using both hands.
With firm, even pressure, pull the sheet toward you.
Usually, removing one or two sheets from the middle of the stack will release the pressure and the rest of the stack can be removed.
Make sure no scraps of paper are left in the printer.
Close the top cover of the printer.
Try printing again.
Apr 16, 2011 | HP PSC 750 All-In-One InkJet Printer
The paper keeps jamming, I cant see anything in the way. any help is appreciated.
If paper doesn't feed correctly when printing, remove it and fan the edges of the paper to separate the sheets. Reload the paper against the right side and slide the edge guide against it. Do not load too many sheets at once.
If paper has jammed: 1. Press x Start to eject the jammed paper. 2. If paper is still jammed, gently pull it out from the output tray or sheet feeder. If paper is stuck inside, press the P On button to turn off the printer. Then lift the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the printer back on.
If documents don't feed correctly in the Automatic Document Feeder, make sure the corners of the paper are not bent, folded, or curled up. Do not load more than 10 sheets of legal-size paper at a time. If documents have jammed: 1. Open the ADF cover and pull any paper out to the left. Caution: Do not try to remove the paper without opening the ADF cover first, or you could damage the mechanism. 2. Select Yes or press OK to clear any messages on the display screen. 3. Reload the paper.
Feb 28, 2011 | Epson WorkForce 600 All-In-One InkJet...
Printer tried to take half of the stack of paper and jammed up. Can't get the paper unstuck.
Unlatch and pull out the paper tray. Try pulling out the sheets in the middle of the "half stack" first. You should have less friction there. While you have the paper tray out, examine the rectangular cork paper separator strip on the right-hand side of the back corner. If it's worn or missing, that would explain how the jam got started.
Dec 06, 2010 | HP DeskJet 820Cse Printer
I had one sheet jam. I pulled it out and a corner
Switch off.
Open all access panels.
Need a good torch light and the longest pair of tweezers you can find.
Then go hunting? Torch should show small piece of paper up. Be gentle but firm, most likely it might tear again, just keep at it.
When clear, do your self a favour, don't use economy paper, its not worth the hassle, a few pence more, little or no hassle.
Good Luck, rem be gentle!!
Nov 15, 2009 | OKI B4350 Laser Printer
Paper jam
The print roller can be turned by hand but do not move the print head by head to the left or right -just make the roller turn either way. Try line feeds first. Steve Medley
Oct 27, 2008 | Epson Stylus Photo 950 InkJet Printer
Paper jam!!
Please perform the below steps.
1. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
put the cables back and switch on
Aug 25, 2008 | Brother HL-2070N Laser Printer
Paper jam
please give more info. do you see the paper? does it say paper jam when just turned on? does it feed then jam?
Nov 08, 2007 | HP LaserJet 1320n Printer
Canon PIXMA MP210 Photo All-In-One Printer Logo
173 people viewed this question
old marine
old marine
