CHANGE VANGUARD VN3000C HEATER FROM NATURAL GAS TO PROPANE GAS ,IS THERE A KIT AND WHERE CAN I GET IT WITH A MANUAL
  • Heating & Co... Master
  • 2,523 Answers
Hi google vanguard heating products they have a wed site try that
Posted on Feb 08, 2010
Hayward H200P1 Pool Heater- need to convert propane to natural gas
all the parts needed will be in the kit. usually, its the control valve and the jets that get replaced. my manual shows its the same part all units. HAXCNK0002
Aug 09, 2014 | Hayward H Series Pool & Spa Heater 200k...
Hello, my name is Jerry I have a vanguard wall heater that is propane but want to use it as a natural gas
Somewhere is an "orifice" that will fix the problem.
This part, if it is accessible, should be near the end of the pipe where the gas is attached to the heater.
Orifices have tiny holes of different sizes depending on the type of gas and pressure used.
Even if you find the orifice and managed to remove it, finding a different one for a different gas may not be easy, or impossible.
Be blessed.
Nov 05, 2013 | Vanguard Heating & Cooling
I have a desa vn3000c how so I tell id its natural gas or propane was gave to me thanks
Look for a METAL PLATEon the heater is will have NG for nat gas orl lp for lpg could be on the bottom or inside the heater.
Jan 18, 2013 | Heating & Cooling
Can I convert a vanguard vp1600tc from propane to natural gas?
I believe yes but you do require a gas fitter to do so. the change requires to change the orifice simple and cheap but the gas fitter may be greedy. Check with your utility company they may even come out and change it for you.
Sep 18, 2012 | Vanguard International Infra Red - Medium...
I like to know how to change from natural gas to propipe
You must buy first the appropriate conversion kit for your fryer, you can check and order only with the authorized parts dealer. Conversion kit consists of burner and pilot orifice and gas valve spring and stickers (propane) and installation manual. Propane orifice has smaller bore than natural and gas valve spring is for propane is thicker than natural gas valve spring.
Jun 03, 2011 | Welbilt Kitchen Appliances - Others
Pilot light too big, how do we adjust pilot light on a Vanguard KV1800?
There is no adjustment for a Pilot Flame's Length on a Vent-free Gas Appliance. However, if you're using Natural Gas and it's a Natural Gas Heater, the normal length of the pilot flame is 2 to 2 1/2".
If it's a Propane Gas Heater and the pilot flame is as long as previously stated, you probably have a pressure problem from your tank. Contact your Propane provider to have them check the pressure on their tank regulator.
Jan 31, 2011 | Vanguard Heating & Cooling
Change from natural gas to propane
You could do it but it would be very expensive. You would need to change the ODS pilot and the gas valve itself. I am not sure even then it would work correctly. These are not conversion ready.
Jul 26, 2010 | Vanguard International Blue Flame - Large...
How do I convert vanguard VMH26TPA wall heater from propane to natural gas?
You would have to get a conversion kit, which usually
is new orfices and a spring that goes into the gas valve. The kit would probably be cheaper than buying a gas valve and the orfices seperately
Feb 10, 2010 | Vanguard International Infra Red - Medium...
Burner flame is high on low setting brand new procom ml 250
could be that it has a natural gas orfice in it and you are using propane. check your owners manual or have someone with propane experience check it for you.
Jan 15, 2010 | Vanguard International Infra Red - Large...
Convert a procom heater from propane to natural
you need to find a place that makes your type of heater and they will have a change over kit all it is different orfices and jetcovers for each gas jet from your heater its self explanitory once you see the parts,sometimes there are different gas comp. that if you use there service they will change you over at no or little cost. hope this helps
Sep 14, 2009 | Procom ML300TBA Heater
Heating & Cooling Logo
121 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
