Question about GE 27GT722 27" TV
Need Operators Manual for GE 27GT722
Need an Operators Manual for GETV, Model 27GT722 .
Found a manual online and that described the situation. Thanks.
Posted on Feb 09, 2010
Brought a GE model 27gt722 tv...can not pick up all channels on cable. Usually once you hook up cable wire to tv cable is automatically on least that is how it was on old tv
Depending on the cable company, some like Comcast have gone mostly digital meaning when you connect the TV directly to cable without a cabe box you will only get around 35 channels. The only way to get around that is to get a cable box. If you have Comcast service already they offer what they call a DTV cable adaptor which will allow you to get most cable channels. These DTV adaptors in most areas are free for the first two per household. I hope that helps : )
Jul 25, 2011 | GE 27GT722 27" TV
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Mar 03, 2011 | GE 27GT722 27" TV
Blurry tv screen
If you are comfortable on doing adjustment with working TV then take off back cover of TV and check flyback transformer, there you would see 2 control knobs, upper knob if to adjust focus. rotate it CW or CCW to obtain maximum focus on TV screen.
Put back cover and enjoy.
Feb 10, 2009 | GE Televison & Video
27GT722 Blows Fuse
There should be a part designation written on the board under that part. FOr example Qxxx or Dxxx. Can you post that here please? I can cross reference that designation using the model number to get you the part number, cost and description.
Sep 17, 2008 | GE 27GT722 27" TV
You need to measure the size of your screen just the area thats visible they include the extra that fits in the frame. Just measure top to bottom and side to side then go to the following link and send them an email indicating the size screen your looking for and they will contact you usually within an hour or two letting you know if they have it. Also for the schematic let me know the chassis number as thomson builds GE so I can locate the service manual for you by chassis number.
Heres the link for the screen
Mar 31, 2008 | GE 46GW947 46" Rear Projection Television
27gt722 sound ok, no video
I found one of these that had an inductor coil which is in series with the hoizontal output transistor base open up. It had a bad solder connection where it goes through the circuit board. This might be what happened to your tv. If so, it needs to be resoldered. What happens is that you loose horizontal drive and since the voltage that lights the filiament of the picture tube is derived from the flyback transformer this voltage is gone. Another possibility is that you may have an opem filiament (rare) or a loose connection on the picture tube driver board which is mounted on the neck of the tube. Stargazer
Feb 23, 2007 | GE 31GT740 31" TV
GE 27GT722 Picture problem
Regarless of the reason I will give you ,call a service tech for an estimate since is the safe way to correct the problem. First when you loose the pix put your forearm in the face of picture tube and if the hair in your arm stands up is a good sign because you are not loosing high voltage to the picture tube but if the hair does not stand up it means the crt looses high voltage and for that you need a service tech to troubleshoot.The other reason might not be as expensive If you have high voltage by doing the previus test it might just be a loose conection in the crt board.Do not remove the back cover unless you know what are you doing.Is not safe.
Sep 14, 2006 | GE 27GT722 27" TV
GE model 27GT722
Sorry, the board is not available as a replacement. That connector can be replaced by a skilled tech.
Aug 19, 2006 | GE 27GT722 27" TV
Open Questions:
GE 27GT722 27" TV Logo
129 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
