Question about Mitsubishi CS-40307 40" TV
Mitsubishi CS-40307 40" TV : weight?
How much does this TV weight (in lbs)?
5 Suggested Answers
techman
  • 3130 Answers
SOURCE: Mitsubishi CS-35805 TV
Sorry to be the one to inform you Sheri, but this set is known to have several bad capacitors in the sweep as well as the power supply. Unless you have an ESR type capacitor checker, your going to have to take it in for service, by a pro. Hope yopu did'nt pay to much for it. Good Luck
Posted on Jul 24, 2006
SOURCE: Universal Code for Mitsubishi CS-26201TV
After searching the web for hours this is the one that worked for me , if you have the same remote i have it should work for you too.
Code # 10150
Posted on Dec 21, 2008
SOURCE: weight
360 pounds
Posted on Mar 12, 2009
  • 17 Answers
SOURCE: model CS- 40307 40 inch Mitsubishi TV will not turn on
continue to push power button until light turns green. verie rate of push and hold
Posted on Jul 15, 2009
What is the weight
Mitsubishi WS-55615 - 55" rear projection TV
Weight: 214.9 lbs
Jan 24, 2015 | Mitsubishi Televison & Video
Weight how much does a 32 inch flat screen weight
Hello, the tv weighs 40.7 lbs with the base on it, and 33 lbs without the base....thanks
Aug 05, 2014 | HP Lc3272n 32 in. LCD Television
I am shipping my tv to my new location, need to know the weight
Which model TV do you have?
The TVs in the LD-325 line are 14.55 pounds with the stand, but is 13.45 lbs without. If you have the original shipping container and all the accessories, the LD-3255VX weighed 21.83 lbs. The LD-3255AR is 23.2 lbs in the box.
The EW32S3PW with the stand is 15 pounds and 1.5 pounds lighter without the stand.
The older model SK-32H640G is 23.9 pounds with the stand. Removing the stand takes 1.4 lbs off the TV weight. When in the original box with accessories, the TV weighed 27.0 pounds.
There are a number of other models, so please add a comment with the model number and if the stand and accessories are going to be in the same box. I hope this gives you some help.
Nov 10, 2012 | Westinghouse 32" Flat Panel LCD HDTV
How much does the tv weight in us lbs
Model Weight Height Width Depth
WS-48511 175.5 lbs. 49" 44.5" 24"
WS-55511 238 lbs. 50.3" 50.6" 28"
WS-55711 266 lbs. 50.3" 50" 28"
WS-65511 337 lbs. 61.9" 59" 28.1"
WS-65611 336.5 lbs 61.9" 59" 28.1"
WS-65711 356 lbs 61.6" 58.2" 28"
WS-65712 251 lbs. 61.7" 58.2" 28.4"
WS-73711 410 lbs 65.7" 65.2" 30"
WS-B55 238 lbs. 50.3" 50.6" 28"
Oct 20, 2012 | Mitsubishi WS-55511 55" Rear Projection...
I own a Samsung DLP 56" TV for which I purchased a swivel wall mounting bracket that holds up to 160 Lbs of weight. However when looking at the back of the tv set and the such smal size screws that...
Yes it will hold,the wall mount u bought it design for weight of 160 LBS and 50"-60" screen sized right?Just make sure hook up the wall mount on and over a wall area with strong woods beams supports have many fours by fours woods beams lumbers to take off the stress of the holding of the tv by those screws alone of the screen frame screws supports only.
Jun 30, 2011 | Samsung HL-T5676S Television
What is the weight of model TX-42F430S Television. I am mounting it on the wall. Thank You!
I found 2 different sources online that list the weight as either 61.1 lbs or 68.1 lbs. I think the 61.1 is more accurate for the bare TV without the stand or anything attached. But keep in mind that when mounting a flat panel TV to a wall, you should secure it with hardware rated for much higher weight tolerances. Many mounting brackets for TVs of this size are rated for 150 - 200 lbs, and for good reason. Consider a situation where someone trips and catches his balance on the wall-mounted TV. The TV is already putting 61 lbs of pressure on the bracket, so any force from any other contact is added to that. It doesn't take much to add up to 100 lbs or more. If the mount breaks free from the wall, you'll have damage to the TV, the wall, the mount, and any furniture or flooring beneath the TV, so the best advice is to mount it as if it weighed about 150 lbs. The 7 lbs +/- difference in reported weights won't matter at all.
Jan 25, 2011 | Westinghouse Televison & Video
What is the weight of this unit?
product weight is 149 lbs and shipping weight with box ect....would have been 174 lbs hope this helps you lol
Dec 21, 2010 | Panasonic CT-36D32 36" TV
I do not have a manual for my set
Howdy,
That Model is:
Height: 15 13/32
Width: 42 13/16
Depth: 22 19/32
Weight: 183 lbs.
I hope this information was helpful.
Good Day, Big Irish.
Nov 23, 2009 | Mitsubishi VS-50800 50" Rear Projection...
Televison & Video Logo
225 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
