Question about Microsoft Xbox 360 Console
Switched on console and i have no signal.cant get a picture but sound ok. have changed cables and monitor but no change. still have green lights
    Problem Solver:
  • 9 Answers
Try a lens cleaner
Posted on Feb 08, 2010
Monitor turns green
This sounds like a problem with the cable. Monitors have Red, Green, and Blue signals. I have seen it where the cable has a short, or the plug has a bent or loose pin, and this causes the monitor to turn green.
It is also possible, but doubtful, that the video card is trying to run it as a Black and White monitor. B&W signal is sent over the green channel.
Jul 29, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
No signal from xbox to tv
Try resetting resolution and then tweakin sound setting in menu.
Look Here: http://cocaman.ch/wp/2006/12/reset-xbox360-resolution/
Jan 10, 2009 | Microsoft Xbox 360 Console
LG Monitor Display Problem
1. Mostly Loose contacts in video section that means CRT Neck board dry points checke it.
2.Pl check VGA Cable RGB signal pins 123 to ground 75 Ohms (on OK condition).
3.check 5v supply
4.check SDL and SCL signals.
Oct 05, 2008 | LG Studioworks 563N 15" CRT Monitor
No picture yet i can hear sound green effect before it happend
First thing would be to make sure that you're only using the yellow, red, and white cables, but seeing as how you said you had picture before, I'm guessing that's not the problem. The 360 uses an automatic recognition for the hardware to make sure that it is set to the right input. So, in essence, it won't be that the settings were changed. I would say go pick up a new cable and see if that's the problem, it sounds like it is. If the cable doesn't solve it then I would say it's time to call Microsoft. For the guest with nothing working, call up Microsoft, I really don't know what else the problem could be except for hardware.
Oct 04, 2008 | Microsoft Xbox 360 Console
Can't find video signal
If screen says "Signal cable not connected " all the time till power led switches to Amber chances are monitor is ok and problem is with graphic card or cpu.Connect to Known working CPU and confirm that monitor is the problem.
If same problem persists on another working cpu after changing signal cable,the interface board in the monitor could be defective.
Samir
PLease rate solution and provide feedback.
Jun 09, 2008 | BenQ FP731 17" LCD Monitor
Picture goes to a lime green fuzz and then no piture or sound!
which AV connection are you using? HDMI or the cable supplied with the PS3, If using HDMI, you have to set the PS3 visual settings to HDMI, to do this, use the cable supplied with the PS3, and have the HDMI cable plugged in. Then while using the cables supplied with the PS3, switch the settings over to HDMI, then change the TV's input selector to your HDMI and confirm the settings changes. Hope it helps take care
Oct 17, 2007 | Sony Playstation 3 (PS3) Console
Neovo x17a monitor
Are the settings on the video output correct? Is there a green or orange light illuminated. There is a difference between the Power LED and the Signal LED which is green. If you have no signal the LED will remain orange or yellow but not green. If the LED is green, then a signal is getting from the PC but not necessarily good. Check the signal with another monitor or TV if you can. Check the cable.
Aug 15, 2007 | Neovo AG 17" LCD Monitor
Greeen!!!!!!!!!
You can try to Degauss the monitor. It still sounds like the video cable is bad. That last part you mentioned about the OSM (on-screen Menu) having normal colors comes from the monitor and has nothing to do with the cable or pc. That tells me its the video cable, or the video cable connector (pins maybe bad) or a bad connection somewhere. There could be a bad connector inside the monitor where the video cable is attached to the electronics board. Sometimes those contacts just get oxidized and quit transmitting a signal. They need a good cleaning.
Jul 01, 2007 | HP Pavilion M703 17" CRT Monitor
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
