Question about Texas Instruments TI-89 Calculator
I have a file I created in notefolio in the main folder on my TI-89 Titanium but I can't seem to locate the file there or anywhere else. Can someone help me retrieve this file?
  • 16 Answers
SOURCE: TI 89 Titanium
well, its juz a broken screen. send for servicing.
Posted on Jul 09, 2008
Flortzweich
  • 8 Answers
SOURCE: TI-89 Won't Turn On
Please don't get your hopes up, but perhaps something in the following few suggestions will work:
For the TI-89 Family, TI-92 Family, and Voyage™ 200:
  1. Adjust the contrast by pressing and releasing the Diamond Key key followed by pressing and releasing the [+] key; repeat as necessary. To adjust or lighten the display, use the [-] key.
  2. Users of the TI-89 Titanium or Voyage 200 should see the following case before performing the following reset procedure to prevent the loss of valuable Apps.
    On the TI-92 family or Voyage 200, hold the [2nd] key and the [hand] key, then press and release the [on] key. On the TI-89 family, press and hold the [2nd] key, left arrow, and right arrow; then press and release the [on] key. This should reinitialize the operating system, in which you should see a progress bar filling on the screen.
  3. Remove one of the AAA or AA batteries. Press and hold the [APPS] key, and while holding the [APPS] key, replace the battery and turn the unit on. TI-89, 92 Plus, or Voyage 200 users should see "Press I to install code...", and should press the [9] key. The calculator should then say, "Waiting to receive...". TI-89 Titanium users should see "Waiting to receive..." or "Waiting to received OS...". You will need to restore the calculator's operating system.
To reinstall the Calculator's operating system, take a look at the following TI site.
http://epsstore.ti.com/OA_HTML/csksxvm.jsp?nSetNumber=12089
I would hunt around on the TI knowledge base to see if there are some more useful suggestions if nothing above works. If I find any more info that could be useful I will post it.
Posted on Jan 30, 2009
Flortzweich
  • 8 Answers
SOURCE: how do you restore a TI-89 Titanium clac
Perhaps one of the following sources will be helpful:
To reset the TI-89 family, TI-92 family and Voyage 200 graphing calculators, press [2nd] [6] (reads MEM over the key). The [F1] menu appears and contains the following options:
  • All RAM - Clears all variables and programs from RAM only. This will not delete items from Archive or Apps.
  • Defaults - Does not clear any files from the calculator. Instead, this option resets the calculator settings to default, including the Mode, Graph Format, Table Setup, and other settings.
  • Vars - Clears all variables from Archive (Flash ROM). This option will NOT delete Apps or variables stored in RAM memory.
  • Apps - Clears all Apps from Archive. This will not delete any variables.
  • Both - Will clear all Apps and Variables from Archive. This will not delete any Variables from RAM.
  • All Memory - Clears everything from RAM and Archive, leaving only the Calculator OS and its components.
For example, I think you will want to follow the last step above... which would be to press [2nd] [6] [F1] [1] [1] [ENTER] [ENTER].
Also, if you are looking to clear all the RAM in another way I would take a look at the guidebook, which is downloadable from the following site in PDF format.
http://education.ti.com/downloads/guidebooks/graphing/89ti/TI89TitaniumGuidebook_Part2_EN.pdf
Take a look at page 951 and 952 for another way to clear the RAM
vladp995
  • 81 Answers
SOURCE: where is 1/x on ti-89 titanium
There is not such button but 1/x=x^-1 so just take it in power -1 it is the same.
Rate me please, thanks.
Posted on Jul 09, 2009
  • 5 Answers
SOURCE: Ti-89 Titanium screen
Mine is the same, I Called TI and they said they would replace the calculator for $75 if I sent the one I have in now even though it doesnt hava a warranty so the answer would be $75
Posted on Oct 26, 2009
Notefolio app not showing in my TI89
Transfer it to the calculator, if you have not done so already. If it has been installed, it should show on the AppsDesktop. To explore the desktop, use the arrow keys. You can also deactivate the AppsDesktop ON on the last page of the MODE, to have a list displayed when you press the Apps key. Once you find the NoteFolio app, select it and press ENTER. Here is how you proceed afterwards.
408bfaec-f5c9-4089-a6b4-c7517055caee.jpg 783a1491-192e-4456-bff2-413dd673ed51.jpg
9788439a-9d78-49af-a872-fb15d9f964ef.jpg bde1a278-c998-42ac-be27-f852b8ceeff9.jpg
Apr 16, 2014 | Texas Instruments TI-89 Calculator
Problem with accessing ticonnect while using ti 89 titanium calculator?
In the View menu type select collapse all and you will see + sign
Nov 29, 2011 | Texas Instruments TI-89 Calculator
My TI-89 Titanium's screen froze. Well actually, the cursor kept blinking but none of the buttons worked. I got it to restart using the (-) and ) button trick, but rather than going back to normal it went...
Hi kelsers,
You need to re-install your calculator's OS. After this process your Ti 89 Titanium will operate properly. If you do the process below make sure you use new batteries.
Warning!!! If you do this procedure make sure that your computer and, calculator are connect. Use Ti Connect software and, make sure you can install the OS on the calculator without any interruption. At any time even at the very beginning of this process, if your computer or, calculator gets interrupted or you have a power failure during the installation of the OS, your calculator will be destroyed. So not attempt this procedure during a thunder storm.
You can use the Ti OS Downloader but, you will have no idea what OS is stored by the Ti OS Downloader. So, I suggest following my instructions and, installing the newest Ti 89 Titanium OS 3.10v.
Procedure to installing the newest Ti 89 Titanium OS 3.10v.
You can also get the latest copy of Ti 89 Titanium OS 3.10v by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 89 Titanium OS 3.10v." Once your at the Ti site click the Download Item, Ti 89 Titanium OS 3.10v. Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti 89 Titanium OS 3.10v. will download to you. Click, "SAVE". And then a folder will pop up. It is probably a folder that you download too. If so, you may want to change it and, "Save as" to this folder, "My Documents \ My TI Data \ Downloads". You can also go back and, download the Ti 89 Titanium guidebook too, if needed.
Link your computer and calculator with the USB cable or, Direct Black Link cable that came with the calculator.
Remove one of the AAA batteries. Press and hold the [APPS] key, and while holding the [APPS] key, replace the battery and turn the unit on. On the older TI-89 you should see "Press I to install code...", and you should press the [9] key to continue. But, on your Ti 89 titanium it should say, "Waiting to receive..." or, "Waiting to received OS...". Now you need to follow the instructions in the paragraph below to restore the calculator's operating system.
Next, drag the Ti 89 Titanium OS 3.10v. that you copied earlier to "My Documents \ My TI Data \ Downloads" out of that folder and, drop it in the "Ti Connect" icon on the desktop. Next the OS Downloader Warning will pop-up. Click, "OK" to continue and, the new OS will begin to install. The Ti Device window should pop up and, click on to the port where your Ti 89 Titanium is located, USB1 cable or Direct Black COM1. Just click, "Select" and, the OS will continue to download. Upon completion the newest Ti 89 Titanium OS 3.01v. will be installed.
Jan 10, 2011 | Texas Instruments TI-89 Calculator
Ti-89 titanium
Having gone over a month with no response, I assume this is no longer a problem.
Jun 26, 2010 | Texas Instruments TI-89 Calculator
Urgenttttt --- when i used notefolio on my computer to transfer notes to my calculator TI-89... i could not find transferred notes on my calculator!! where can find it?? or do i have to download...
You need to install notefolio to your TI-89.
You can download the program from:
http://education.ti.com/educationportal/sites/US/productDetail/us_notefolio_89.html
After you download the program file, you can use TI-Connect to transfer the program file to your calculator (after you connect the calculator to the computer with the USB cable). To transfer the files, simply drag and drop the program file onto the TI-Connect icon on your computer.
To learn more about the Notefolio app, here is the guidebook:
http://education.ti.com/educationportal/downloadcenter/SoftwareDetail.do?website=US&appId=6204&tabId=2
Nov 25, 2009 | Texas Instruments TI-89 Calculator
I want to download apps to calculator... for example... i want to download notefolio on my calculator ti-89 but when i used ti-connect to trasnfer notes to my calculator i couldnt find notes on my...
if you downloaded with a browser like mozila or so ..it will be in a folder named Downloads..on my documents ..if you downloaded it with another one ...you have to check the download director for that program ...for example some makes the download director into my computer ..C drive ..downloads..
but if you are looking and can not find it ..just go to the start ...pres search ..and choose files and folders..and add the name of the file you search it ...if it is on computer it will find it for you ..than on the address bar you will see its location ..( or click right properties and go to file ..)
When I turn the switch on, ti-89 titanium does not turn on.
If you connect calculator to computer using Ti connect device explorer you might be able to see what files are on the calculator. I don't know if you downloaded from the web but, 3rd party programs and shells tent to miss up the calculator. This would able you to delete out possible problems which could be re installed later.
Sep 22, 2009 | Texas Instruments TI-89 Calculator
I keep getting variable or flash application in use on my TI-89 Titanium whever I try to launch any application, what should i do?
I think you have a conflict with another program in the main folder that happens to be a program that may be used by that APP. You may go to main folder and delete or unarchive or unlock programs or varibles that may be used by the APP's. I would go ahead and delete it, but, you can copy it somewhere else. Then again it may because the program/varible is in a folder other than main that is used by APP's. Try and find it and delete it.
Aug 20, 2009 | Texas Instruments TI-89 Calculator
Texas Instruments TI-89 Calculator Logo
557 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
