Question about Ricoh Aficio CL7000 Laser Printer
Ricoh CL7100 The CL7100 said to replace the Fuser Oil Unit. I ordered 1, followed the directions to a "T" and when I turn the machine back on it says to "Reset Fuser Oil Unit Correctly". As far as I can tell there's nothing else to do in the manual. Please Help. Shawn
  • quennie732 May 11, 2010
    Did you get a fuser oiler (it goes on the hot roll) or the oil collection bottle behind the front door lower left?
  • Bernard D'Souza May 11, 2010
    did u remove both the tapes in order.
    also remove fuser and see if it is sitting properly
  • 183 Answers
THe oil unit is not entered correctly
Posted on Jul 16, 2009
I have a Ricoh CL7100 printer. It has for some time displayed a red error lamp and a message "replace fuser oil unit (type g)" I was advised a while ago that I could continue to use printer (and have...
OPEN FRONT DOOR OF COPIER LEFT SIDE SHOULD BE A CLEAR CONTAINER WITH OIL IN IT. THAT IS WASTE OIL FROM FUSER. HAS FILLED UP. EMPTY IT OR FIND A RICOH DEALER THAT CAN SELL ONE TO YOU. try ebay saw one on there
Apr 18, 2017 | Ricoh Office Equipment & Supplies
Ricoh CL7100- Black Dots on all printouts
What are the correct colour settings for optimum colour printing for Ricoh Aficio Cl7200
Apr 12, 2010 | Ricoh Aficio CL7200 Laser Printer
How to refill oil Fuser at unit at Ricoh Aficio 2232c/2238c
These machines use oil supply units located on top of the fuser unit. They are not refillable order another and replace... continueing to run this machine without fuser oil will cause the fuser to fail and copies to look terrible
Dec 17, 2009 | Ricoh Aficio CL7000 Laser Printer
Ricoh CL 7100 fuser jam.
The grinding noise is the clashing of gears. The fuser is composed of 2 rollers, a metal or ceramic with a heater inside (bulb) and a silicon roller to apply pressure. The 'hot' roller is geared and the silicon roller can be geared or free floating. There is at least 1 paper sensor in the the fuser to let the unit know whether paper is there and there when it should or should not be. Sometimes, the sensor gets slightly dislodged and can actually cause a jam. If you are hearing a gear clash, the paper is being pushed through the machine and instead of being pushed through the fuser, it stops because the fuser rollers are not turning. The rest of the machine keeps pushing, crinkling the paper.
If there is crinkling, then gears that drive the fuser need to be checked. It is this gear cluster and/or the fuser that need to be replaced.
Aug 03, 2009 | Ricoh Aficio GX5050 GelSprinter InkJet
Ricoh Aficio Cl7100 - Getting SC 552 error. Ideas?
Hot section problems Replace the fusing unit Its a kit make sure to put a new oil unit DO NOT USE THE OLD ONE, (sorry I yelled but new fuser failure sucks) -Carl
Jul 13, 2009 | Ricoh Aficio 450 Copier
My nasuatec dsc 435 displays sc 440-02.I don't know what to do
That code is color drum motor lock (cmy). 440-1 is for black. Pull each drum unit out and look at the drum surface if one is not turning good it will have toner all over it. Could be that the drum is full of waste toner, but usually it is a backed up waste toner auger system. If that machine uses a fuser oil the oil has leaked down into the waste toner auger system and clogged it up.
Jun 15, 2009 | Ricoh Aficio CL7100 Printer
Doesn't go past warmup.
you need check:
1) there are two fuses in the fuser unit, big possible one of them broken. change fuse if you can, should be fixed.
2) if check (use meter) all fuse good, so the heat lamp damaged,
you may change it also can fix it,
fuser unit maybe expansive.
hope hep you fix it, please feedback any question any time, pleaae take a rating let me know how much helped you thanks!
May 22, 2009 | Ricoh Aficio CL7100 Printer
At start-up printer codes out a sc541 turn off then on
It's a fuser error. Fuser may need replacing, and fuser codes can only be reset by a technician, to prevent further damage
Feb 26, 2009 | Ricoh Aficio CL7100 Printer
Ricoh Aficio 2238c: Fuser Oil Unit
you really can not refill the bottle but I would recommend two things. One find a fuser oil unit on ebay and order it quickly. Next hit the yellow clear modes button, then hit the numbers 1 0 7 , then hold the red clear stop button till the display panel changes. hit copy sp, select 7 data log. now use the page down arrows located in the middle of the disply till you see 7804 push it then go to #10 oil supply and hit execute. this will reset the oil counter and allow you to use the machine till you get the new unit.
Oct 25, 2008 | Ricoh Aficio CL7000 Laser Printer
Ricoh Aficio CL7000 Laser Printer Logo
327 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
