Question about Saws
Table saw moter burnt out.
I require location of ryobi ets-1825 table saw moter (stockist or rewind )
    Brigadier General:
  • 4,088 Answers
Sears carries a good selection of capacitor-start replacement motors that should fit your saw. Most of these motors can easily be converted to 230 volt operation which is a recommended procedure (almost instant starting!). Don't try to have the original motor rewound as it would cost several times the replacement cost. That service is only used for very expensive high-horsepower 3-phase motors as a rule. Hope this helps!
Posted on Feb 08, 2010
Testimonial: "yes great at least i won't waste time & money on a rewind."
How do I get the burned out motor out of my ets 1825 table saw
torx screwdriver or bits to unscrew it.
Sep 23, 2016 | Saws
RYOBI ETS-1825 Blade will not return fully to zero, so will not now cut square, how do i correct this problem please ?
Owner's manual trouble shooting?
Something is "caught" or being blocked in the return mechanism. Try to find the blockage. Cleaning and wd-40 may help.
Mar 18, 2015 | Ryobi Saws
Where can I get a manual for ETS 1825 saw (Ryobi)1835
I can't online but you can try email the manufacturer.
Oct 14, 2014 | Saws
Ryobi ets 1825 table saw cuts out
Sounds as it is overheating. When have you last changed your blade. Also cut slower may help if your blades are dull or if the thickness of what you are cutting is too thick. Don't use an extension cord neither. Hope this helps.
Nov 10, 2012 | Audio Players & Recorders
I cannot find supplier for a replacement throat plate for my Ryobi ETS 1825 folding Bench Saw. The part number is 0800 5300 1001
I had the same problem. Try www.powertoolspares.com/index.php/index.php/tool/ryobi/spares-and-accessories-for-ets1825/ets1825/
or just www.powertoolspares.com and follow the links for ryobi spares.
Nov 28, 2010 | Saws
I THINK IVE BURNT THE BRUSHES OUT ON MY RYOBI ETS 1825,FOLDING TABLE SAW, SERIAL NO 06011539 HOW CAN I CHANGE THEM. OR FIND OUT WHATS WRONG, THE MOTOR STARTED TO SMOKE ? REGARDS NJ
You can change the brushes easy enough but I don't think that is the problem. The brushes are a standard size, can be bought at any hardware store. Just pull the caps off and remove the brush, slide in the new one, all set. But,,, I have a feeling the motor went kapooie, The brushes usually don't smoke, but a burned out field or armature will. Check the motor to make sure it spins free with the belt off, or the blade off if it is direct drive, then do the brush change, if that doesn't do it, you will have to take out the armature and have it checked for ground, and then check for loose wires, burned rotor, and if that checks out then the field is shot. One of the 3. But it could be a bearing. Hope this helps.
Jul 24, 2010 | Saws
Where to buy a rip guide for Ryobi table saw ETS 1536AL
Do a google search for "Ryobi tablesaw ETS 1536AL
Sep 28, 2009 | Saws
Where to buy a new motor for ryobi ets 1825 table saw
I have been in contact with Ryobi and they tell that this is a bad model number could you please recheck or call Ryobi direct at 1-800-525-2579
Jul 16, 2009 | Ryobi Saws
Saws Logo
445 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
