Question about Vanguard International Vanguard BY Rheem G91-200LP Gas Water Heater
Do i nned to drain water tank to change out
Do i need to drain water tank to change out thermostat
  • 409 Answers
Yes you will need to drain it to replace thermostat
Posted on Mar 10, 2010
Our hot water will last for about 5- 10 minutes then turn luke warm. I have replaced both elements but problem remains . Do you hink it is the thermostat ? thanks chazz
If you have not done so already then turn thermostats up to 140 degrees. You may also try to drain and flush tank to clean out any mineral deposits that could be hurting your effiency. To do this shut off electrical power to heater then connect garden hose to drain valve on the bottom of tank. Run hose to floor drain or other safe area and open drain valve. If it drains good with the water on then let it flush for a couple of mins. then shut incoming water supply off. Let tank drain as far as it will. You may need to open a faucet on the hot side of nearby fixture to break vacumn.
Drain it completly then close drain valve and hot side of faucet.Turn water supply back on and let tank refill. Do this 2-3 times to get inside of tank as clean as possible. Hope this helps you and thanks. P.S. You may need to replace thermostat also.
Mar 28, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Tip
How to Change the Gas Valve and Thermostat on a Hot Water Heater
<p>If you are having<b> trouble with the temperatures</b> of your <b>gas hot water heater</b> fluctuating too much, or after <b>changing the thermocouple</b> of your gas <b>hot water heater</b> then you may need to change the complete <b>gas valve and thermostat assembly</b>. Also if you have changed the <b>thermocouple</b> and the pilot still will not stay lit, then the gas valve could be bad or the <b>ECO (Emergency Cutout)</b> may have activated and is open. This is a onetime device and cannot be replaced.<br /> <p><br /> <p>These instructions are for the older style <b>gas valve and thermostat combination</b>. These commonly have a large red knob that adjusts the temperature of the water. Also note that the burner tube nut for <b>natural gas</b> is right hand thread, but if you have <b>LP or propane gas</b> the burner tube nut is left hand thread.<br /> <p><br /> <p>The newer <b>gas valve thermostat combinations</b> that have come out recently are similar, but they have a well in the tank that the sensor slides into. The assembly is held fast with a set screw. With this type of <b>gas valve and thermostat unit </b>the tank does not need to be drained, but most of the rest of the change out is similar.<br /><br />To change a <b>gas hot water heater thermostat</b> you will need to first buy a new gas valve for your <b>hot water heater</b>. The <b>gas valve</b> and the <b>thermostat</b> are integrated into one unit.<br /><br />To <b>replace the thermostat on a gas hot water heater</b> you must follow these procedures....<br /><br />1. Turn off the incoming water and<b> drain the hot water heater</b>.<br /><br />2. Remove the <b>pilot tube</b>, the <b>burner gas tube</b> and the thermocouple from the gas valve. Turn off the <b>gas line</b> and remove from the gas valve.<br /><br />3. Get a <b>pump pliers</b> or a<b> wrench</b> in behind the gas valve and turn the whole assembly CCW to remove it from the tank.<br /><br />4. After applying pipe dope or tape to the new gas valve threads, turn the new gas valve into the tank by turning in a CW direction. Be careful not to damage the small wires to the <b>ECO</b>. They are the little red wires on the back. If you break them the assembly is irreparably damaged.<br /><br />5. Reinstall the gas line, thermocouple, burner tube, and the pilot tube to the gas valve.<br /><br />6. Fill tank with water. Make sure to open a <b>hot water faucet</b> and <b>purge all air from the tank.<br /><br /></b>7. <b>Check for leaks</b> where the gas line hooks up with soapy water.<br /><br />8. Relight pilot light and check operation.<br /><br />9. Set the new temperature setting to a medium setting and then adjust the temperature to your liking from there and adequate time for heating completely<br /> <p>
on Feb 25, 2011 | Water Heaters
I have a reliance 501 propane gas water heater how do i change a thermostate
To change a gas hot water heater thermostat you will need to first buy a new gas valve for your hot water heater. The gas vaive and the thermostat are integrated into one unit.
To replace the thermostat on a gas hot water heater you must follow these procedures....
1. Turn off the incoming water and drain the water heater.
2. remove the pilot tube, the burner gas tube and the thermocouple from the gas valve. Turn off the gas line and remove from the gas valve.
3. get a pump pliers or a wrench in behind the gas valve and turn the whole assembly CCW to remove it from the tank.
4. After appliying pipe dope or tape to the new gas valve threads, turn the new gas valve into the tank by turning in a CW direction. Be careful not to damage the small wires to the ECO. They are the little red wires on the back. If you break them the assembly is irreparably damaged.
5. reinstall the gas line, thermocouple, burner tube, and the pilot tube to the gas valve.
6. Fill tank with water. Make sure to open a hot water faucet and purge all air from the tank.
7. Check for leaks where the gas line hooks up with soapy water.
9. Set the new temperature setting to a medium setting and then adjust the temperature to your likeing from there and adequate time for heating completely.
heatman101
Feb 23, 2011 | RELIANCE ELECTRIC WATER HEATER
I have a Rheem model number is 81V52D and I think I need to check the thermostat. Do I need to drain the unit in order to check the thermostat?
No you do not need to drain water heater when checking or replacing thermostats:
Water heater is drained when replacing elements or cleaning sediment out of tank.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Also look at following links: These links can teach you everything about fixing ordinary tank-type electric water heater using generic parts from hardware store.
http://waterheatertimer.org/How-electric-water-heater-works.html
http://waterheatertimer.org/How-to-replace-element-and-clean-sediment-out-of-electric-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 20, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Relief valve on my water heater is dripping.Can I fix this?
There are two solutions:
1) Replace TP valve with same temperature/pressure as existing TP valve.
Buy the TP valve at hardware store or home center or plumbing supply.
Turn off water heater so water cools.
Hot water inside a tank is explosive ... so open the TP valve and test water temperature.
If TP is on top of tank, you don't need to drain much water before unscrewing
If TP is on side of tank, use the TP valve to drain water -or- use the drain valve
Unscrew TP to remove.
Put teflon tape on new valve threads so it will seal against leak.
2) If the new TP replacement starts doing the same thing, there may be a thermostat problem -or- thermostat is set too high.
If you keep the water temperature set high, you can add expansion tank to incoming cold water line.
Home Depot sells expansion tanks. Plumbing supply carries them,
The tank for residential water heaters is about same diameter as a football and it goes on cold water line.
Oct 31, 2010 | Water Heaters
What cause the water heater to take more than an hour to heated up and unable to last longer. Usually its take about 15 min. to heat up and can last longer.
'Rheem 81VP15S point of use' is a single-element, 15 gallon, 120V electric.
Other 'point-of-use' sizes range from 2-1/2 to 6 gallon to 20 gallon.
Electric water heaters have 2 parts: thermostat and element. One is not functioning correctly. Most likely the element caused by sediment build-up.
How to determine if tank has element or thermostat problem:
Do not turn off water going into tank. Put hose on drain valve. Open drain valve. Does water come out like open spigot? If water does not flow, then heater is likely clogged with sediment.
Solution 1: If water flows out like a spigot, the thermostat is probably bad. Read: How to replace thermostat.
Solution 2: Water does not flow, so element is surrounded by sediment build-up and cannot heat water. You need to clean out tank with shop vac, and put in new element ... plan full day and 3 trips to hardware store. Simply draining tank will not remove sediment. Sediment is chunky and will not come out voluntarily.
Buy element before starting:
-Turn off electricity
-Open cover on side of tank, remove insulation (these have to be put back for proper operation of thermostat)
-The are 2 electrical parts >>the element and the thermostat which is located above element
-Element wattage is printed on element and also shows on label on side of tank
-I think Rheem element is held in place with 4 hex bolts
-Take photo of element to hardware store so you have part on hand before removing old element
-If element is 1-1/2' diameter hex type, you need inexpensive element wrench from hardware store + the element
Drain tank and clean sediment:
-Read: To open drain on water heater so water comes out
-Read: How to clean sediment out of water heater
Sep 29, 2010 | Rheem 81VP15S Point-of-Use Electric Water...
Gas hot water heater will not automatically heat water, i have to manually start the burner to heat the water
Sounds like you have a bad thermostat. You can change the thermostat, but if the heater is more than 8 or 10 years old you might be better off to replace the entire heater. Thermostat replacement is easy:
1 turn off the gas 2 drain the heater 3 unscrew pilot, main burner, and thermocouple lines from bottom of thermostat. 4 unhook gas line from thermostat. 5 unscrew thermostat from heater tank. Use pipe sealer when you install new thermostat, and gas line fittings. burner and thermocouple lines seal on a taper seat and do not need sealer. after reassembly check for leaks with soapy water, not a match, light the pilot and turn up the temp. The heater may sweat quite a bit while it is heating up the first time, this is due to the cold water on the inside and the fire on the outside. some water may drip in the bottom of the heater and you might think you have a leak, but let it heat up completly, if the water is still dripping after the tank is hot then you need to find the leak.
Jun 18, 2010 | Water Heaters
I own a Bradford White Corp. Electric Hot Water Heater. It has two thermostats, one upper and one lower. Model # M-1-40S6DS 13, ser# XK0300351. My problem is the red button on the upper control trips...
Hello. If you turn off the power and drain the tank then examine each of the heating elements you will find that the upper element is deteriorated. The fix is to replace the heating element. Actually though my practice is when one is bad the other isn't far behind so for a few dollars I change both when I have the tank drained. Joe
Feb 28, 2010 | Water Heaters
Hot water does not last long. Model 82vh40-2 mnf. 05/2005
If the lower heating element burns out the upper element will heat the top part of the tank then shutoff. homw depot/lowes etc should carry elements. 1 turn off breaker, remove element access cover (the 2 panels on the front of the heater) test for electricity at the reset button ( uppermost device in upper panel) to make sure power is off. 2 turn off water (I usually turn off the cold water main to stop water cross feeding into hot supply line back into heater) 3 disconnect the 2 wires on the lower element, test with continuity tester. shhould be no continuity between terminals and tank, but around 10 ohms between the 2 terminals. Check the thermostat for continuity if tank is cold thermostat should be closed ie zero ohms across the 2 terminals.
If stat is bad replace stat; disconnect wires push it up out of the spring clip insert new stat reconnect. If element is bad: drain tank. connect garden hose to tank drain valve, open tank drain valve turn water main on to clear rust sediment and get water flowing. Next remove filter screen from a hot water faucet then turn on ( a hot faucet upstairs or higher than tank drain). Now turn water main off, air will now go in through hot faucet and tank will drain, takes about an hour. Use a water heater element wrench about$10 to remove element(s) make sure no bits of rubber gasket are left in element opening- dig em out with a screwdriver if needed. Insert new element with its gasket and tighten. reconnect wires DO NOT TURN ON ELECTRICITY! BE SURE TO FILL WATER HEATER WITH WATER ! Turn water main back on -air will come out of the hot faucet for several minutes. When water runs without any air sputtering, turn off faucet and replace the faucet filter screen. check element(s) for leaks. turn breaker back on.
Feb 17, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Heating element cycling on and off fairly often
Yes, unfortunelty elextric water heaters do cycle a lot. They are a little bit different from gas water heaters, in the fact that they run differently and seem to run out of hot water faster, then gas water heaters. Just make sure, that the thermostat is set at 120 F. The thermostat will be behind a panel, and under the electrical wire connections. You will have to use a flathead screw driver, to change the temp. settings, if they need changing. Also, make sure that once a year, that you flip the Pressure relief valve to equalize the pressure and to drain at least 2 gallons of water out of the tank.
Jan 20, 2009 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Vanguard International Vanguard BY Rheem G91-200LP Gas Water Heater Logo
48 people viewed this question
Top Vanguard International Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Vanguard International Water Heater Expert? Answer questions, earn points and help others
