Question about BRASS CRAFT SERVICE PARTS Brass Craft #ST1149 S3-1UEW Fauc Cartridge
I think the leak I get is from the seats/springs inside the faucet handles of my shower. There are 2 handles to control the water. What would the part # be for the seats? also, one of the handles is missing the spring washer that goes around the cartridge.
  • 349 Answers
Most of them are standard like deltas have can you take the other one with spring to lowes or Home depot or plumbing supply they should have one for it.
Posted on May 17, 2010
How to stop water getting inside a single leaver shower faucet?
quite possibly there is a broken O ring inside the faucet .
Jul 17, 2015 | Home
Tip
Ball-Type Single Lever Faucets
BALL-TYPE SINGLE-LEVER FAUCETS
  • The single-handle faucet with a ball inside to control both hot and cold water may either leak at the spigot or at the handle. A handle leak is usually caused by improper adjusting-ring tension. Simply adjust the tension to stop the leak. Leaks at the handle can also result from a worn cam gasket. Dripping from the spigot is usually caused by worn spring-loaded, soft rubber seat assemblies.
  • Parts for ball-type faucets are available in kits. Get the spring/seats kit for spigot leaks, or the complete kit for handle leaks. It may be advisable to use the complete kit to replace all working parts of the faucet at the same time. In any case, you'll need a kit containing the spanner/hex wrench for removing the handle (hex end) and turning the adjusting ring (spanner end).
  • Without turning the water off, loosen the handle set screw. Slide the handle from its stem.
  • For a handle leak, try using the spanner wrench to tighten the adjusting collar. Tighten it by turning the wrench and collar clockwise until the faucet doesn't leak when it is turned on and off. If the adjustment is too loose, the faucet will leak. If you turn it too tight, the handle will be hard to move. When the adjusting ring cannot be turned with the wrench, it is corroded. At this point, you will need to remove the cap to free the adjusting ring. (See next step.) You must turn the water off before removing the cap! Apply penetrating oil to the threads, remove the ring and clean all parts before reassembling.
  • Install the seats. For faucet leaks at the spigot, you must install new rubber seats and springs. You must turn off the water to make this repair. Unscrew the chrome cap by turning it counterclockwise. If it won't turn easily, wrap electrical tape around the cap and turn it with pliers. The adjusting ring, which is threaded into the cap's center, will come off with it. For a seats/springs replacement, pull the ball up and out by its stem. The gasketed cam will come with it. Now you can locate the two rubber seats and springs inside the faucet body. Remove them with pliers or yours fingers and install the new ones. The springs go into the holes first, and the cupped sides of the seats fit over the springs.
  • Service the ball. If the ball is dirty or coated with scale, clean it or replace it with a new one. Both plastic and brass balls are available, but use a plastic one if your home has hard water.
  • Reassembly. Put the ball and cam back into the faucet with the slot in the side if the ball fitting over the pin in the faucet body. Then make sure the tab on the cam slips down into the notch in the body. Not aligning the tab and notch is the number one cause for a faucet leaking after it is repaired. Finally, screw on the cap and adjust the ring as described in Step 2. If a properly adjusted ball-type faucet leaks at the cap, the cam and gasket must be replaced.
  • Swing spouts. If a single-lever ball faucet leaks at the base, you should replace the O-rings. Remove the spout-retaining parts, as well as the spout. Wrap the spout-retaining nut with electrical tape to protect it, and remove the nut with a wrench or pliers by turning counterclockwise. Remove the spout by pulling it up and side-to-side. One or more O-rings should now be exposed. Take the O-rings to your hardware or home center store to get matching O-rings for replacement. Clean any scale that appears on the spout base, faucet body, and the inside of the swinging spout. Install the new O-rings and reverse the steps above to reassemble the faucet.
on Jan 16, 2010 | Plumbing
Two faucet shower control hot water faucet leaks- I took of the cap, handle, and unscrewed the long screw and there was a long white place stem. Is this where the seal goes.
You will need to remove the cartridge that the screw was attached to and underneath there is a rubber cup washer with a small cone shaped spring. You need to replace the rubber washer which is called a seat and the spring ,then put cartridge and handle back on and you should be good to go. Thank you.
Feb 17, 2011 | Delta Home
MY DELTA SCALD GUARD FAUCET WILL NOT TURN OFF HOW DO I REPAIR
When a Delta Scald Guard will not turn off, more than likely it is because the seats have worn out. Turn off the water supply and open any faucets lower stream of the shower unit. Using an allen key, locate the set c=screw in the handle and back it out. Next,Remove the Phillips screw holding the handle in place.Next turn the retaining ring counter clockwise and pull the catridge out of the faucet.Some catridges have two parts front and back. Behind the back part id two small rubber washers called seats and two springs. Install two new seats and springs and everything else in reverse order.
Not hot water should not exceed 120 degrees. If it does it will continue to melt the seats.
Feb 02, 2011 | Delta & Single Handle Shower Faucet
Repairing two handle shower faucet with replacement part RP1740 and need a step by step diagram of the repair?? Can't understand how to repair without diagram. Hot water tap won't shut off!
No diagram available, but I should be able to walk you through the process easy enough. First, make sure your water is off and you have relieved the existing pressure by opening a nearby faucet until the water stops running. Then remove the handle. Under the handle there will be a nut that can be removed with an adjustable crescent wrench or water pump pliers (if you use the pliers be careful not to mar the surface.) Make note of which way the stopper for the handle is sitting, this is the raised piece of plastic on top of the stem. Then after the nut is removed, you can use some pliers to grab the center of the stem and pull straight out. Once the stem is out, inside the faucet you will see the seat (the rubber piece) sitting down in a little hole and under that a spring. These two pieces are typically the culprit for the leaking faucet so make sure you replace these as well or the faucet will continue leaking. Then working in reverse order, put the new items back in place and then before tightening the handle in place, turn the water back on and check for leaks at the handle as well as the spout. If you have any leaks, tighten the nut at the handle if that is what is leaking, or turn off the water and start the process again to reposition the seat and spring. Good luck, you can do it.
Aug 17, 2010 | Delta Home
I put a new shower valve on a delta shower faucet with a handle for volume control and a handle for temp. control. When I turn the water supply on, the water runs continuously and I cannot shut it off no...
The first thing I would do is to start over Remove the cartridge and look behind it to make sure the Quad seal and seats and springs are all in place, It sounds like a least one of the seats fell out of their home. Also double check that the spring are in correctly with the tapered end pointing towards the cartridge. The link below may or may not be helpful.
http://www.deltafaucet.com/customersupport/documentation/1724-74.html?document=pd&documentIndex=0
Jun 02, 2010 | Delta & Single Handle Shower Faucet
Leaky single lever bath tub faucet
Faucet is leaking due to seats bad.
1- Turn water off first and remove handle and remove collar that holds stem and remove it..
2- in valve there are seats that looks like caps they may be in valve body or the end of stem itself.
3- Remove them and the springs and replace them this will take care of the leaking problem.
May 21, 2010 | Delta & Single Handle Shower Faucet
Leaking shower faucet
I do believe that Delta guarantees their faucets for life. Go online to get the 800 number and call them, have the model number ready. They actually sent my girlfriend a replacement for her $300 kitchen faucet and also the guts to 2 bathroom faucets. They come with diagrams also. Of course I had to install them, but they stand behind their stuff.
Nov 20, 2009 | Delta & Single Handle Shower Faucet
Water comes out the shower head without the faucet lever being engaged
the whole faucet is bad it has an internal leak replace the whole thing
Jul 03, 2009 | Home
Moen shower head leak
Single handle shower controls always have some water trapped inside. It has probably freeze damaged the cartridge
Apr 29, 2009 | Moen & One Handle Tub & Shower Faucet
BRASS CRAFT SERVICE PARTS Brass Craft #ST1149 S3-1UEW Fauc Cartridge Logo
62 people viewed this question
Top BRASS CRAFT SERVICE PARTS Home Experts
Donni Steen
Tom Chichester
Are you a BRASS CRAFT SERVICE PARTS Home Expert? Answer questions, earn points and help others
