Question about Ricoh Aficio 220 Laser Printer
My Ricoh Aficio 220 has routine paper jams. I have never found any jammed paper in it.At times the first sheet in the paper tray is bend, but not always.
  • 62 Answers
Needs new feed rollers in the paper tray. You can try and clean them but it probably will need replacing.
Posted on Feb 10, 2010
Red light is constantly blinking and when try to print, there is always a paper jam
Every time there is paper jam, the printer knows the job is not completed and hence tries to re-print after the paper is removed and cover is shut.
Clear the print job from computer.
Power off the printer and Clear the paper jam (if any)
I would try to use different tray. The paper pickup roller in one path may be worn out.
eg Sheet feeder or multipurpose tray.
Load paper in new tray
Set the application to use new tray
Ensure you sue the right thickness (gsm) of the paper. Quality of paper is crucial. Too thin; too thick can affect functioning.
Mar 16, 2016 | Ricoh Aficio Sp 3300DN Laser Printer
Paper jam c
Unable to print troubleshooting and routine maintanance chapter in user's guide
Mar 23, 2013 | Ricoh Aficio SP-C210SF Printer
Ricoh SP C410 DN jam from bypass
If you can take off the bypass unit, two screws and a harness, you may be able to check the shaft, bushings and rollers. Sometimes removing jammed paper cause parts to get out of normal position. The grinding noise for example, gears not meshing together correctly. If it worked before the jam, then that is where I would look.
Apr 20, 2017 | Ricoh Aficio SP C410DN Laser Printer
We have a Ricoh Aficio CL3500N and every time we print the paper jams and we get the "Remove Misfeed A: Internal Path". I remove the jam and when it tries to print again we get the same thing,...
There may be an obstruction inside the printer. Try this....remove the paper from the paper tray and put paper in the handfeed tray (front of the machine) If it feeds from that tray it means that the feed rollers in the bottom cassette are worn.
Dec 17, 2010 | Ricoh Aficio CL3500N Laser Printer
Ricoh Aficio CL3500N printer phantom misfeed
It seems that the sensor is having dust or toner settled upon it. Kindly remove the toner and clean the residual toner. Take a hard stock paper and give one copy command and push it while it tries to pull the paper. Paper misfeed is not the same as paper jam. Paper misfeed refers to the blank paper tray and paper jam refers to paper which has been taken from the tray and now inside the unit.
May 19, 2010 | Ricoh Aficio CL3500N Laser Printer
The bypass tray is contantly jamming when we try to print.
Hi, i'd start with cleaning any rubber rollers in the paper path, if its picking multiple sheets and then jamming, it will need a pick roller and seperation pad, hope this is helpful ,M.
Jul 03, 2009 | Ricoh Aficio SP C811DN-DL Printer
Ricoh copy machine 3025 paper jams every time we try to print
Make sure the paper that is in the drawer matches the orientation and size indicated on thje Op Panel Display, If NOT, MAKE IT MATCH.
Mar 31, 2009 | Ricoh Aficio 3025P Black and White Copier
Paper Jam
There is a small clear plastic sheet that is suppose to be in front of the black friction pad in the paper tray. if that sheet is under the pad instead of in front of it you will get this error.
Mar 24, 2009 | Ricoh Aficio SP C410DN Laser Printer
703 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
