Question about Whirlpool LER5636P Electric Dryer
FUEL LIKE ORDER COMING FROM ELECTRIC DRYER POWERE BY FUSES
WHEN DRYER IS TURNED ON, ALMOST IMMEDIATELY A STRONG FUEL OR OILY smell fills the air.
  • 240 Answers
Have you recently painted anywhere in your home. And I mean anywhere? Paint fumes or other chemical type cleaners or solvents will get in the elements and put off that whole gas or oil smell. If no, have you put any type of clothes in the dryer that may have had some paint or anything else petroleum based on them to dry. That also could have caused this smell as well. If your hot water heater runs on propane or natural gas, check it careful for leaks. This could be a serious situation as a major explosion could happen if it is leaking. Leave the house and call 911 immediatly from a safe distance. I doubt that this is the problem, but be safe than sorry. Let me know if none of these are the culprits. Thanks and let me know.
Posted on Feb 23, 2008
I have a kenmore electric oven, which is 13 years old. i used it two weeks ago, and it was fine. now when i turn on the oven, there is a strong gas smell coming from it that not only envelopes the...
Hello Cheryl Davis...
Your posting came in UNDER A DUAL FUEL
ELECTRIC - GAS combination...
If you are smelling gas... you are in immediate DANGER.
PLEASE turn OFF the gas at the wall...
The gas is not only toxic it is highly EXPLOSIVE ...
Do not experiment with your health & safety...!!
GAS appliances are very dangerous...
A single HOT-SURFACE ignition failure
should have caused the GAS to not flow...
If it is flowing ... you are in EXTREME DANGER.
Aug 12, 2017 | Whirlpool SF315 Dual Fuel (Electric and...
Maytag Neptune Dryer with strong "burned electrical wiring" smell
Sounds like the motor went out. Before trying to start it it needs to be inspected. If you are not comfortable opening up the cabinet then I would would recommend calling a service tech. If you need further assistance please let me know.
Ken
Mar 17, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Our dryer gave out a burn smell like a belt had broken, and even though plugged in, it will not come on. We took it a part some and didn't see anything wrong. We only took down the front facing to see the...
Dryers have a thermal fuse... typically a ceramic assembly 2-3 inches filled with resin and wires attached...usually near the motor. This may account for the burn smell. Turn the power off and replace .
Dec 08, 2009 | Crosley CDE6000 Electric Dryer
Strong fuel smell from AC
If you're experiencing a strong fuel smell, there's most likely a leak in the engine compartment. The AC will cool incoming air unless the "recirculate" button is pressed. The incoming air is what has the fuel smell, indicating a leak in the engine compartment. CAUTION: leaking fuel in the engine compartment is extremely dangerous and can lead to a fire. Please have the car diagnosed by a professional immediately.
Oct 25, 2009 | 2004 Volvo XC90
There is a strong oil smell in the dryer
If you have recently painted or varnished inside your home the fumes in the air can create a hydrocarbon type smell in your dryer. This should stop as soon as the house is aired out.
Oct 17, 2009 | Whirlpool LTE6234D Top Load Stacked...
High fuel consumption/ strong smell of fuel
you could have a injector stuck in open loop and or a bad o2 sensor these are the two most common problems i see with stated issues that you are having . hope this helps you!!
May 30, 2009 | 1992 Volkswagen GTI
Dryer burning smell
Have you painted or stained in your house or apartment recently? The smell gets everywhere, dryer, stove, heating unit. I recently primed with Kilz and the clothes from my dryer smelled burned. When I called for service, it was the first question the service person asked and said they made a lot of useless trips only to find nothing wrong with the appliance. That was my case. I had to rewash clothes and let the dryer run with towels for a while
Jan 22, 2008 | Dryers
Dryer smells of natural gas
Of course, this applies to gas dryers only. If you smell natural gas near your gas dryer, do not light matches or a lighter and don't operate electrical switches or anything that might spark, igniting an explosion. Immediately shut off the gas valve that serves the dryer. If the smell is mild, ventilate the area, wait until the air is clear, and re-light your pilot light. If the smell is strong, move everyone outside, leaving the doors open to ventilate the house. Turn off the gas supply valve --located by the gas meter on the gas inlet pipe-- by rotating the valve one quarter turn with an adjustable wrench. The valve's oblong stem should be perpendicular (at a right angle) to the inlet pipe to stop the flow of gas. Call your gas supplier (or the fire department) from a neighbor's phone or a cellular phone outside the house.
Jan 18, 2006 | AEG T57800 Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
213 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
